    ros2服务调不同,不知道缺什么,节点都可以运行,也source了
    ros2-foxy service
    • 8118775078
      JQK
      ros2 service call /save_map cartographer_ros_msgs/srv/SaveMap "{path: /home/, include_unfinished_submaps: true}"
        File "/opt/ros2/foxy/lib/python3.6/site-packages/rosidl_generator_py/import_type_support_impl.py", line 46, in import_type_support
          return importlib.import_module(module_name, package=pkg_name)
        File "/usr/lib/python3.6/importlib/__init__.py", line 126, in import_module
        File "<frozen importlib._bootstrap>", line 994, in _gcd_import
        File "<frozen importlib._bootstrap>", line 971, in _find_and_load
        File "<frozen importlib._bootstrap>", line 953, in _find_and_load_unlocked
      ModuleNotFoundError: No module named 'cartographer_ros_msgs.cartographer_ros_msgs_s__rosidl_typesupport_c'
        File "/opt/ros2/foxy/bin/ros2", line 11, in <module>
          load_entry_point('ros2cli==0.9.11', 'console_scripts', 'ros2')()
        File "/opt/ros2/foxy/lib/python3.6/site-packages/ros2cli/cli.py", line 67, in main
          rc = extension.main(parser=parser, args=args)
        File "/opt/ros2/foxy/lib/python3.6/site-packages/ros2service/command/service.py", line 41, in main
          return extension.main(args=args)
        File "/opt/ros2/foxy/lib/python3.6/site-packages/ros2service/verb/call.py", line 59, in main
          args.service_type, args.service_name, args.values, period)
        File "/opt/ros2/foxy/lib/python3.6/site-packages/ros2service/verb/call.py", line 83, in requester
          cli = node.create_client(srv_module, service_name)
        File "/opt/ros2/foxy/lib/python3.6/site-packages/rclpy/node.py", line 1249, in create_client
          check_for_type_support(srv_type)
        File "/opt/ros2/foxy/lib/python3.6/site-packages/rclpy/type_support.py", line 29, in check_for_type_support
          msg_type.__class__.__import_type_support__()
        File "/opt/eame/cartographer_ros_msgs/lib/python3.6/site-packages/cartographer_ros_msgs/srv/_save_map.py", line 279, in __import_type_support__
          module = import_type_support('cartographer_ros_msgs')
        File "/opt/ros2/foxy/lib/python3.6/site-packages/rosidl_generator_py/import_type_support_impl.py", line 48, in import_type_support
          raise UnsupportedTypeSupport(pkg_name)
      rosidl_generator_py.import_type_support_impl.UnsupportedTypeSupport: Could not import 'rosidl_typesupport_c' for package 'cartographer_ros_msgs'
