    ros2 message filter
    ros2 humble messagefilter
    1.3k
    • yudonghou123Y
      小猴同学
      系统UBUNTU22.04,ROS2 HUMBLE
      各位大佬,我使用Message filter想做时间软同步,代码如下:
      #include <memory>
      #include <stdio.h>
      #include <stdlib.h>
      #include <string>
      #include <cstring>
      #include "rclcpp/rclcpp.hpp"
      #include <message_filters/subscriber.h>
      #include <message_filters/time_synchronizer.h>
      #include <message_filters/synchronizer.h>
      #include <message_filters/sync_policies/approximate_time.h>
      #include "dvl_msgs/msg/odom.hpp"
      #include "ahrs_msgs/msg/fn70_auxa.hpp"
      #include "plc_msgs/msg/sensor.hpp"
      using namespace message_filters;
      using std::placeholders::_1;
      using std::placeholders::_2;
      using std::placeholders::_3;
      class AUVSENSORS_MESSAGES : public rclcpp::Node
      public:
          AUVSENSORS_MESSAGES() : Node("auvsensors_message")
              odom_sub_.subscribe(this,"/dvl/odom");
              imu_sub_.subscribe(this,"/ahrs/raw");
              depth_sub_.subscribe(this,"/plc");
              sync_ = std::make_shared<message_filters::TimeSynchronizer<dvl_msgs::msg::Odom, ahrs_msgs::msg::Fn70Auxa, plc_msgs::msg::Sensor>>(odom_sub_, imu_sub_, depth_sub_,10);
              sync_->registerCallback(std::bind(&AUVSENSORS_MESSAGES::disparityCb, this, _1, _2, _3));
      private:
          void disparityCb(const dvl_msgs::msg::Odom::ConstSharedPtr& dvl_msg, const ahrs_msgs::msg::Fn70Auxa::ConstSharedPtr& imu_msg,const plc_msgs::msg::Sensor::ConstSharedPtr& ph_msg)
              const char *t_1 = std::to_string(dvl_msg->linear.x).c_str();
              const char *t_2 = std::to_string(dvl_msg->linear.x).c_str();
              const char *t_3 = std::to_string(dvl_msg->linear.x).c_str();
              const char *t_4 = std::to_string(imu_msg->altitude).c_str();
              const char *t_5 = std::to_string(ph_msg->depth).c_str();
              RCLCPP_INFO(this->get_logger(), "消息:%s,%s,%s,%s,%s", t_1,t_2,t_3,t_4,t_5);
          message_filters::Subscriber<dvl_msgs::msg::Odom> odom_sub_ ;
          message_filters::Subscriber<ahrs_msgs::msg::Fn70Auxa> imu_sub_;
          message_filters::Subscriber<plc_msgs::msg::Sensor> depth_sub_;
          std::shared_ptr<message_filters::TimeSynchronizer<dvl_msgs::msg::Odom, ahrs_msgs::msg::Fn70Auxa, plc_msgs::msg::Sensor>> sync_;
          rclcpp::init(argc, argv);
          rclcpp::spin(std::make_shared<AUVSENSORS_MESSAGES>());
          rclcpp::shutdown();
          return 0;
      我想输出几个实例数据,因此我运行记录数据的bag包,其能够正常play,
      os2 bag play rosbag2_2023_12_08-15_36_13
      [INFO] [1702044100.446161521] [rosbag2_storage]: Opened database 'rosbag2_2023_12_08-15_36_13/rosbag2_2023_12_08-15_36_13_0.db3' for READ_ONLY.
      [INFO] [1702044100.446240068] [rosbag2_player]: Set rate to 1
      [INFO] [1702044100.456354394] [rosbag2_player]: Adding keyboard callbacks.
      [INFO] [1702044100.456406646] [rosbag2_player]: Press SPACE for Pause/Resume
      [INFO] [1702044100.456417656] [rosbag2_player]: Press CURSOR_RIGHT for Play Next Message
      [INFO] [1702044100.456426625] [rosbag2_player]: Press CURSOR_UP for Increase Rate 10%
      [INFO] [1702044100.456434797] [rosbag2_player]: Press CURSOR_DOWN for Decrease Rate 10%
      [INFO] [1702044100.456868918] [rosbag2_storage]: Opened database 'rosbag2_2023_12_08-15_36_13/rosbag2_2023_12_08-15_36_13_0.db3' for READ_ONLY.
      但是我订阅其话题并实现时间同步输出实例参数的终端报以下错误,这是怎么回事,怎样解决呢?
      terminate called after throwing an instance of 'std::runtime_error'
        what():  can't compare times with different time sources
      [ros2run]: Aborted
      芜湖
