    Could not find a package configuration file provided by [cmake] "village_interfaces" with any of the following names: village_interfacesConfig.cmake
    cmakelist 自定义接口
    • 1218974981
      zhjr2023
      系统:Win11+WSL2-Ubuntu22.04
      VSCode编译报错信息:
      [main] 正在配置项目: zhjrROS2
      [proc] 执行命令: /usr/bin/cmake --no-warn-unused-cli -DCMAKE_BUILD_TYPE:STRING=Debug -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=TRUE -DCMAKE_C_COMPILER:FILEPATH=/usr/bin/gcc -DCMAKE_CXX_COMPILER:FILEPATH=/usr/bin/g++ -S/mnt/c/Users/zhjr/zhjrProjects/zhjrROS2/src/village_wang_cpp -B/mnt/c/Users/zhjr/zhjrProjects/zhjrROS2/build -G Ninja
      [cmake] Not searching for unused variables given on the command line.
      [cmake] -- Found ament_cmake: 1.3.6 (/opt/ros/humble/share/ament_cmake/cmake)
      [cmake] -- Found rclcpp: 16.0.7 (/opt/ros/humble/share/rclcpp/cmake)
      [cmake] -- Found rosidl_generator_c: 3.1.5 (/opt/ros/humble/share/rosidl_generator_c/cmake)
      [cmake] -- Found rosidl_adapter: 3.1.5 (/opt/ros/humble/share/rosidl_adapter/cmake)
      [cmake] -- Found rosidl_generator_cpp: 3.1.5 (/opt/ros/humble/share/rosidl_generator_cpp/cmake)
      [cmake] -- Using all available rosidl_typesupport_c: rosidl_typesupport_fastrtps_c;rosidl_typesupport_introspection_c
      [cmake] -- Using all available rosidl_typesupport_cpp: rosidl_typesupport_fastrtps_cpp;rosidl_typesupport_introspection_cpp
      [cmake] -- Found rmw_implementation_cmake: 6.1.1 (/opt/ros/humble/share/rmw_implementation_cmake/cmake)
      [cmake] -- Found rmw_fastrtps_cpp: 6.2.5 (/opt/ros/humble/share/rmw_fastrtps_cpp/cmake)
      [cmake] -- Using RMW implementation 'rmw_fastrtps_cpp' as default
      [cmake] CMake Error at CMakeLists.txt:14 (find_package):
      [cmake]   By not providing "Findvillage_interfaces.cmake" in CMAKE_MODULE_PATH this
      [cmake]   project has asked CMake to find a package configuration file provided by
      [cmake]   "village_interfaces", but CMake did not find one.
      [cmake]
      [cmake]   Could not find a package configuration file provided by
      [cmake]
      [cmake]     village_interfacesConfig.cmake
      [cmake]     village_interfaces-config.cmake
      [cmake]
      [cmake]   Add the installation prefix of "village_interfaces" to CMAKE_PREFIX_PATH or
      [cmake]   set "village_interfaces_DIR" to a directory containing one of the above
      [cmake]   files.  If "village_interfaces" provides a separate development package or
      [cmake]   SDK, be sure it has been installed.
      [cmake]
      [cmake]
      [cmake] -- Configuring incomplete, errors occurred!
      [cmake] See also "/mnt/c/Users/zhjr/zhjrProjects/zhjrROS2/build/CMakeFiles/CMakeOutput.log".
      [proc] 命令“/usr/bin/cmake --no-warn-unused-cli -DCMAKE_BUILD_TYPE:STRING=Debug -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=TRUE -DCMAKE_C_COMPILER:FILEPATH=/usr/bin/gcc -DCMAKE_CXX_COMPILER:FILEPATH=/usr/bin/g++ -S/mnt/c/Users/zhjr/zhjrProjects/zhjrROS2/src/village_wang_cpp -B/mnt/c/Users/zhjr/zhjrProjects/zhjrROS2/build -G Ninja”已退出,代码为 1
      CMakeList.txt
      project(village_wang_cpp)
      endif()
      # find dependencies
      find_package(rclcpp REQUIRED)
      find_package(village_interfaces REQUIRED)
      if(BUILD_TESTING)
      endif()
      ament_package()
      add_executable(wang2 src/wang2.cpp)
      ament_target_dependencies(wang2 rclcpp std_msgs village_interfaces)
      install(TARGETS wang2 DESTINATION lib/${PROJECT_NAME})
      install(DIRECTORY launch DESTINATION share/${PROJECT_NAME})
      package.xml
      <?xml version="1.0"?>
      <package format="3">
        <name>village_wang_cpp</name>
        <version>0.0.0</version>
        <maintainer email="*********@qq.com">zhjr</maintainer>
        <license>Apache-2.0</license>
        <depend>rclcpp</depend>
        <depend>std_msgs</depend>
        <depend>village_interfaces</depend>
        <export>
        </export>
      </package>
