    将需要GPU计算的代码改为用CPU计算
    pytorch cuda
    • 16870285121
      最近需要将一个gpu上跑的小车的控制代码改为在cpu上跑,按如上标题搜索后进行了两处更改:将torch.device改为'cpu',在torch.device的参数中添加map_location='cpu',但仍显示如下报错。
      原代码配置:Ubuntu18双系统+gpu
      现在我的配置:虚拟机Ubuntu18+cpu
      请问是pytorch的版本不匹配吗?
      (base) xxx@xxx-virtual-machine:~/catkin_ws/src$ python run.py
      torch:1.8.2
      torchvision:0.9.2
      device:cpu
      Process Process-2:
        File "/home/xxx/anaconda3/lib/python3.8/multiprocessing/process.py", line 315, in _bootstrap
          self.run()
        File "/home/xxx/anaconda3/lib/python3.8/multiprocessing/process.py", line 108, in run
          self._target(*self._args, **self._kwargs)
        File "/home/xxx/catkin_ws/src/Node.py", line 263, in create_node
          importlib.import_module('.main', package=p[-3] + '.' + p[-2])
        File "/home/xxx/anaconda3/lib/python3.8/importlib/__init__.py", line 127, in import_module
        File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
        File "<frozen importlib._bootstrap>", line 991, in _find_and_load
        File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
        File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
        File "<frozen importlib._bootstrap_external>", line 783, in exec_module
        File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
        File "/home/xxx/catkin_ws/src/image/main.py", line 25, in <module>
          model.load_state_dict(torch.load('weight.pt'),map_location='cpu')
        File "/home/xxx/anaconda3/lib/python3.8/site-packages/torch/serialization.py", line 592, in load
          return _load(opened_zipfile, map_location, pickle_module, **pickle_load_args)
        File "/home/xxx/anaconda3/lib/python3.8/site-packages/torch/serialization.py", line 851, in _load
          result = unpickler.load()
        File "/home/xxx/anaconda3/lib/python3.8/site-packages/torch/serialization.py", line 843, in persistent_load
          load_tensor(data_type, size, key, _maybe_decode_ascii(location))
        File "/home/xxx/anaconda3/lib/python3.8/site-packages/torch/serialization.py", line 832, in load_tensor
          loaded_storages[key] = restore_location(storage, location)
        File "/home/xxx/anaconda3/lib/python3.8/site-packages/torch/serialization.py", line 175, in default_restore_location
          result = fn(storage, location)
        File "/home/xxx/anaconda3/lib/python3.8/site-packages/torch/serialization.py", line 151, in _cuda_deserialize
          device = validate_cuda_device(location)
        File "/home/xxx/anaconda3/lib/python3.8/site-packages/torch/serialization.py", line 135, in validate_cuda_device
          raise RuntimeError('Attempting to deserialize object on a CUDA '
      RuntimeError: Attempting to deserialize object on a CUDA device but torch.cuda.is_available() is False. If you are running on a CPU-only machine, please use torch.load with map_location=torch.device('cpu') to map your storages to the CPU.
      16870285121 1 条回复 最后回复 回复 引用 0
      • 16870285121
        - @1687028512
        最后由 1687028512 编辑
        @1687028512
        自查了一下是代码位置添加错了
        不是
        而是
          model.load_state_dict(torch.load('weight.pt',map_location='cpu')
        问题解决
        • 16870285121 1687028512 将这个主题标记为已解决,在
          小鱼 技术大佬 @1687028512
          @1687028512 👍 👍
