    colcon build 出错:显示cannot import name 'generate_py' from 'rosidl_generator_py'
    colcon ros2 colcon build
    • 2974481832
      真的🐇了
      sky0utm@Go:~/yolobot/src$ colcon build
      Starting >>> yolobot_control
      Starting >>> yolobot_description
      Starting >>> yolobot_gazebo
      Starting >>> yolobot_recognition
      Starting >>> yolov8_msgs
      Finished <<< yolobot_gazebo [1.18s]
      Finished <<< yolobot_control [1.34s]
      Finished <<< yolobot_recognition [1.37s]
      Finished <<< yolobot_description [1.52s]
      --- stderr: yolov8_msgs
      File "/opt/ros/humble/share/rosidl_generator_py/cmake/../../../lib/rosidl_generator_py/rosidl_generator_py", line 8, in <module>
      from rosidl_generator_py import generate_py
      ImportError: cannot import name 'generate_py' from 'rosidl_generator_py' (/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_generator_py/init.py)
      gmake[2]: *** [yolov8_msgs__py/CMakeFiles/yolov8_msgs__py.dir/build.make:126:rosidl_generator_py/yolov8_msgs/_yolov8_msgs_s.ep.rosidl_typesupport_fastrtps_c.c] 错误 1
      gmake[1]: *** [CMakeFiles/Makefile2:590:yolov8_msgs__py/CMakeFiles/yolov8_msgs__py.dir/all] 错误 2
      Failed <<< yolov8_msgs [3.77s, exited with code 2]
      Summary: 4 packages finished [4.92s]
      1 package failed: yolov8_msgs
      1 package had stderr output: yolov8_msgs
