    ros2 run image_tools cam2image后报错
    linux ros2 run失败
    1.1k
    • 6510774876
      幸川
      [ WARN:0] global ../modules/videoio/src/cap_gstreamer.cpp (1758) handleMessage OpenCV | GStreamer warning: Embedded video playback halted; module v4l2src0 reported: Cannot identify device '/dev/video0'.
      [ WARN:0] global ../modules/videoio/src/cap_gstreamer.cpp (888) open OpenCV | GStreamer warning: unable to start pipeline
      [ WARN:0] global ../modules/videoio/src/cap_gstreamer.cpp (480) isPipelinePlaying OpenCV | GStreamer warning: GStreamer: pipeline have not been created
      [ WARN:0] global ../modules/videoio/src/cap_v4l.cpp (887) open VIDEOIO(V4L2:/dev/video0): can't open camera by index
      [ERROR] [1709220829.313137597] [cam2image]: Could not open video stream
      terminate called after throwing an instance of 'std::runtime_error'
      what(): Could not open video stream
        小鱼 技术大佬 @651077487
        @651077487 在 ros2 run image_tools cam2image后报错 中说:
        没权限还是不存在?
        9 1 条回复 最后回复 回复 引用 0
        • 9
          此间 @小鱼
          @小鱼 我也是报了相同的错误,一样的错误 不知道如何解决
