    相机深度数据转雷达数据
    humble scan
    • 31782613053
      ᯤ⁹⁹ᴳ⁺
      深度数据转雷达数据文件
      depthimage_to_laserscan_node = Node(
      package='depthimage_to_laserscan',
      executable='depthimage_to_laserscan_node',
      name='depthimage_to_laserscan_node',
      remappings=[
      ('depth','/camera/depth/image_raw'),
      ('depth_camera_info', '/camera/depth/camera_info'),
      ('scan', '/scan')
      parameters=[{
      'scan_time': 0.033, #扫描时间间隔,30HZ
      'range_min': 0.45, #投影点的最小距离单位(米),更近的被丢弃
      'range_max': 5.0, #投影点的最大距离单位(米),更远的被丢弃
      'scan_height': 5, #depthimage中用于转成laserscan的行
      'output_frame': 'camera_depth_optical_frame' #发布的帧 ID
      depthimage_to_laserscan_tf = Node(
          package='tf2_ros',
          executable='static_transform_publisher',
          name='depthimage_to_laserscan_tf',
          arguments=['0','0','0','0','0','0','1','camera_link','camera_depth_optical_frame']
      ld = LaunchDescription()
      ld.add_action(depthimage_to_laserscan_node)
      ld.add_action(depthimage_to_laserscan_tf)
      return ld
      出现雷达数据为竖着的,
      但是订阅camera_depth_optical_frame话题,数据又可以是横向的
