    Fishbot-humble源码编译错误
    fishbot ros2-humble 编译出错
    760
    • 27616077292
      赤诚
      最后由 2761607729 编辑
      编译到cartographer_ros时报错
        小鱼 技术大佬 @2761607729
        @2761607729 注意版本,另外最好复制粘贴提问
        27616077292 1 条回复 最后回复 回复 引用 0
        • 27616077292
          赤诚 @小鱼
          @小鱼 就fishbot的代码https://github.com/fishros/fishbot/tree/humble,humble版本的
          • 27616077292 2761607729 删除了该主题于
          • 27616077292 2761607729 恢复了该主题于
            小鱼 技术大佬 @2761607729
            @2761607729 在 Fishbot-humble源码编译错误 中说:
            请手动下载各个仓库源码,指定humble相关分支:
            [submodule "src/navigation"]
            path = src/navigation
            url = http://github.fishros.org/https://github.com/fishros/navigation2.git
            branch = main
            [submodule "src/cartographer_code/cartographer"]
            path = src/cartographer_code/cartographer
            url = http://github.fishros.org/https://github.com/ros2/cartographer.git
            [submodule "src/cartographer_code/cartographer_ros"]
            path = src/cartographer_code/cartographer_ros
            url = http://github.fishros.org/https://github.com/ros2/cartographer_ros.git
            • 27616077292
              赤诚 @小鱼
              @小鱼 我又重新安装了一遍,先是git clone --recursive https://github.com/fishros/fishbot.git -b humble
              然后按照你的提示将.gitmodules文件改成
              branch = humble
              branch = humble
              branch = humble
              接着在工作空间运行git summodule init 和 git submodule update --recursive更新子模块的内容,在conlcon build编译还是报错,还是同样的情况,但是在colcon build编译前我运行那个rosdep install --from-paths src -y
              也是报错报ERROR: the following packages/stacks could not have their rosdep keys resolved
              to system dependencies:
              fishbot_description: Cannot locate rosdep definition for [ament_python]
              我就直接跳过了,不知道有没有影响
                小鱼 技术大佬 @2761607729
                @2761607729 rosdep这步过不去还是有影响的,另外你要到对应的github仓库去看看有没有humble分支
                • 27616077292
                  赤诚 @小鱼
                  @小鱼 我试了好多次都没解决,那个rosdep提示缺少ament_python的依赖项,我也给安装上了,但是还是报错。我根据这个报错的原因,将cartographer_ros包下面的ros_log_sink.cpp文件中的
                  const std::string message_string = ::google::LogSink::ToString(
                  severity, GetBasename(filename), line, tm_time, message, message_len);
                  中的tm_time改成*tm_time后编译通过了
                    小鱼 技术大佬 @2761607729
                    @2761607729 ok,看样子还是源码bug,我以为是下错版本导致的,源码最好切换到一个release的版本
                    • 27616077292
                      赤诚 @小鱼
                      @小鱼 那意思是这个humble版本还是有问题的吗,我编译后运行第一个指令显示机器人模型ros2 launch fishbot_description display_rviz2.launch.py,看不见机器人,但是添加tf坐标系有显示。
                        小鱼 技术大佬 @2761607729
                        @2761607729 你需要学一个动手学ROS2,从仿真建模开始或者从头开始都可以
