    控制真实机械臂
    机械臂运动规划
    控制真实机械臂 arduino
    • 26927842122
      猪็้头็้็้
      @小鱼 鱼哥,我现在使用舵机组成的机械臂,想用moveit控制,下面是我的arduino代码
      #include <Servo.h>
      #include <ros.h>
      #include <sensor_msgs/JointState.h>
      ros::NodeHandle nh;
      Servo Joint1Servo;
      Servo Joint2Servo;
      Servo Joint3Servo;
      Servo Joint4Servo;
      const int servo_pins[] = {2, 3, 4, 5};
      // 在Arduino环境中,我们通常使用固定大小数组代表关节名称和位置。
      char *joint_names[] = {"shoulder_pan", "shoulder_lift", "elbow","wrist_flex"};
      float joint_positions[4];
      float joint_actual_positions[4]; // 新增数组存储实际读取的关节位置
      sensor_msgs::JointState joint_state_msg;
      ros::Publisher joint_state_pub("joint_states", &joint_state_msg);
      void servo_cb(const sensor_msgs::JointState& msg);
      ros::Subscriber<sensor_msgs::JointState> trajectory_subscriber("/joint_states", servo_cb);
      void servo_cb(const sensor_msgs::JointState& msg) {
      if (msg.position_length != 4 || msg.name_length != 4) {
      Serial.println("Received JointState message with incorrect number of joints.");
      return;
      for (int i = 0; i < 4; i++) {
      joint_positions[i] = msg.position[i] * 180.0 / M_PI; // 将弧度转为角度
      int angle = joint_positions[i];
      switch(i){
      case 0: Joint1Servo.write(angle); break;
      case 1: Joint2Servo.write(angle); break;
      case 2: Joint3Servo.write(angle); break;
      case 3: Joint4Servo.write(angle); break;
      void readJointPositions() {
      for(int i = 0; i < 4; i++){
      joint_actual_positions[i] = Joint1Servo.read();
      void setup() {
      nh.initNode();
      nh.advertise(joint_state_pub);
      nh.subscribe(trajectory_subscriber);
      joint_positions[i] = 90.0; // 初始化为90度,或者其他中位值
      joint_actual_positions[i] = 90.0; // 初始化实际位置也为90度
      Joint1Servo.attach(servo_pins[0]);
      Joint2Servo.attach(servo_pins[1]);
      Joint3Servo.attach(servo_pins[2]);
      Joint4Servo.attach(servo_pins[3]);
      // 初始化JointState消息
      joint_state_msg.name = joint_names;
      joint_state_msg.position = joint_actual_positions;
      joint_state_msg.name_length = 4;
      joint_state_msg.position_length = 4;
      void loop() {
      readJointPositions();
      joint_state_msg.header.stamp = nh.now();
      joint_state_pub.publish(&joint_state_msg);
      nh.spinOnce();
      delay(10);
      是有什么问题吗,我的机械臂并没有动,moveit部分虚拟控制器关了,
      rostopic echo /arm_controller/follow_joint_trajectory/goal
      WARNING: no messages received and simulated time is active.
      Is /clock being published?
      header:
      seq: 10
      stamp:
      secs: 2758
      nsecs: 188000000
      frame_id: ''
      goal_id:
      stamp:
      secs: 2758
      nsecs: 188000000
      goal:
      trajectory:
      header:
      seq: 0
      stamp:
      secs: 0
      nsecs: 0
      frame_id: "base_link"
      joint_names:
      - elbow
      - shoulder_lift
      - shoulder_pan
      - wrist_flex
      positions: [5.664923982706682e-05, 0.5233865867053824, -0.33860453476439023, -0.5672284925053317]
      velocities: [0.0, 0.0, 0.0, 0.0]
      accelerations: [0.0, 0.0, -0.00406710291139345, 0.0]
      /joint_states也能打印出消息,还需要什么操作才能控制机械臂运动呢
      21978089082 1 条回复 最后回复 回复 引用 0
      • 21978089082
        REAL ME @2692784212
        @2692784212 老哥解决问题没有?机械臂开发好没有?
