    我装的ros2的foxy,然后colcon build报这个错有人知道咋解决吗
    colcon build 报错
    • 11753587671
      supreme@supreme:~/Desktop/ws01_plumbing$ colcon build
      [0.174s] ERROR:colcon.colcon_core.package_augmentation:Exception in package augmentation extension 'python': 'NoneType' object is not iterable
      File "/usr/lib/python3/dist-packages/colcon_core/package_augmentation/init.py", line 97, in augment_packages
      retval = extension.augment_packages(
      File "/usr/lib/python3/dist-packages/colcon_installed_package_information/package_augmentation/python.py", line 54, in augment_packages
      desc.dependencies['run'].update(
      TypeError: 'NoneType' object is not iterable
      S Z 2 条回复 最后回复 回复 引用 0
      • S
        skyun2012 @1175358767
        @1175358767 这两天ubuntu22.04装humble,ubuntu20.04装foxy,galactic版本都遇到了类似的问题。不知道怎么回事。
        • 9273885929
          柒墨
          我也是
          系统:ubuntu20.04.5
          ros2:ros2 foxy
          报错:ERROR:colcon.colcon core.package augmentation:Exception in package augmentationextension "python':'NoneType' object is not iterable
          • Z
            zhangbird32 @1175358767
            @1175358767 请问解决了吗?我前两天正常的,今天编译命令也是这个问题,不过好像可以正常编译
