    cartographer建图可视化显示no map receiced
    Nav2
    map cartographer建图
    1.4k
    • 31782613053
      ᯤ⁹⁹ᴳ⁺
      在实体机上进行cartographer建图可视化显示no map receiced。
      查看rqt,发现节点、话题的发布订阅没有问题
      查看/map和/submap_list时发现数据为空
      但是查看/scan和/odom是发现是有数据的
      cartographer.launch.py文件如下:
      import os
          # 定位到功能包的地址
          pkg_share = FindPackageShare(package='fishbot_cartographer').find('fishbot_cartographer')
          #=====================运行节点需要的配置=======================================================================
          # 是否使用仿真时间,我们用gazebo,这里设置成true
          use_sim_time = LaunchConfiguration('use_sim_time', default='false')
          # 地图的分辨率
          resolution = LaunchConfiguration('resolution', default='0.05')
          # 地图的发布周期
          publish_period_sec = LaunchConfiguration('publish_period_sec', default='1.0')
          # 配置文件夹路径
          configuration_directory = LaunchConfiguration('configuration_directory',default= os.path.join(pkg_share, 'config') )
          # 配置文件
          configuration_basename = LaunchConfiguration('configuration_basename', default='fishbot_2d.lua')
          rviz_config_dir = os.path.join(pkg_share, 'config')+"/cartographer.rviz"
          print(f"rviz config in {rviz_config_dir}")
          #=====================声明三个节点,cartographer/occupancy_grid_node/rviz_node=================================
          cartographer_node = Node(
              package='cartographer_ros',
              executable='cartographer_node',
              name='cartographer_node',
              output='screen',
              arguments=['-configuration_directory', configuration_directory,
                         '-configuration_basename', configuration_basename])
          cartographer_occupancy_grid_node = Node(
              executable='cartographer_occupancy_grid_node',
              name='cartographer_occupancy_grid_node',
              output='screen',
              arguments=['-resolution', resolution, '-publish_period_sec', publish_period_sec])
          rviz_node = Node(
              package='rviz2',
              executable='rviz2',
              name='rviz2',
              output='screen')
          #===============================================定义启动文件========================================================
          ld = LaunchDescription()
          ld.add_action(cartographer_node)
          ld.add_action(cartographer_occupancy_grid_node)
          ld.add_action(rviz_node)
          return ld
      fishbot_2d.lua参数文件如下:
      include "map_builder.lua"
      include "trajectory_builder.lua"
      options = {
        map_builder = MAP_BUILDER,
        map_frame = "map",
        tracking_frame = "base_link",
        -- base_link改为odom,发布map到odom之间的位姿态
        published_frame = "odom",
        odom_frame = "odom",
        -- true改为false,不用提供里程计数据
        provide_odom_frame = false,
        -- false改为true,仅发布2D位资
        publish_frame_projected_to_2d = true,
        -- false改为true,使用里程计数据
        use_odometry = true,
        use_nav_sat = false,
        use_landmarks = false,
        -- 0改为1,使用一个雷达
        num_laser_scans = 1,
        -- 1改为0,不使用多波雷达
        -- 10改为1,1/1=1等于不分割
        num_subdivisions_per_laser_scan = 1,
        num_point_clouds = 0,
        submap_publish_period_sec = 0.3,
        odometry_sampling_ratio = 1.,
        imu_sampling_ratio = 1.,
      -- false改为true,启动2D SLAM
      -- 0改成0.10,比机器人半径小的都忽略
      TRAJECTORY_BUILDER_2D.min_range = 0.10
      -- 30改成3.5,限制在雷达最大扫描范围内,越小一般越精确些
      TRAJECTORY_BUILDER_2D.max_range = 3.5
      -- 5改成3,传感器数据超出有效范围最大值
      TRAJECTORY_BUILDER_2D.missing_data_ray_length = 3.
      -- true改成false,不使用IMU数据,大家可以开启,然后对比下效果
      -- false改成true,使用实时回环检测来进行前端的扫描匹配
      TRAJECTORY_BUILDER_2D.use_online_correlative_scan_matching = true
      -- 1.0改成0.1,提高对运动的敏感度
      TRAJECTORY_BUILDER_2D.motion_filter.max_angle_radians = math.rad(0.1)
      -- 0.55改成0.65,Fast csm的最低分数,高于此分数才进行优化。
      POSE_GRAPH.constraint_builder.min_score = 0.65
      --0.6改成0.7,全局定位最小分数,低于此分数则认为目前全局定位不准确
      POSE_GRAPH.constraint_builder.global_localization_min_score = 0.7
      -- 设置0可关闭全局SLAM
      -- POSE_GRAPH.optimize_every_n_nodes = 0
      return options
      请问问题出现在哪里?求解
      • 24384131712
        我不和二极管说话
        刚解决一个和你类似的问题,建议检查你urdf文件里定义的link命名,和你launch的节点的frame_ID的命名是不是一样的。就比如遇到这个问题的原因是我urdf 里命名的雷达link name = 'laser_link',而我launch的雷达节点传入的frame_id却是 laser,这就导致出问题了,接受不到雷达数据。虽然不知道为什么。但我修改之后就能正常建图了。你可以着重检查一下你文件里的这些命名是不是对应的
          2010580030 @3178261305
            我的解决了,原因是cartogrepher_ros与fishbot_cartogrepher重复冲突导致的,把cartogrepher_ros删了就好了
