    使用fishbot雷达驱动时出错
    雷达驱动 timout count
    1.0k
    • 26932262522
      命里有我
      欢迎鱼香ROS使用雷达驱动系统,注意当前版本为ROS2版本驱动哦~
      1. 驱动雷达
      2. 建图测试
      3. 退出
        #? 1
        UART2SOCKET:8888->/tmp/fishbot_laser
        Prepare to Accept connect!
        3 <socket.socket fd=6, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=0, laddr=('172.17.0.2', 8888), raddr=('192.168.3.137', 62197)> 4
        PTY: Opened /dev/pts/3 for 0.0.0.0:8888
        [YDLIDAR INFO] Current ROS Driver Version: 1.4.5
        [YDLIDAR]:SDK Version: 1.4.5
        [YDLIDAR]:Lidar running correctly ! The health status: good
        [YDLIDAR] Connection established in [/tmp/fishbot_laser][115200]:
        Firmware version: 1.5
        Hardware version: 1
        Model: S4
        Serial: 2021032900010679
        [YDLIDAR]:Fixed Size: 360
        [YDLIDAR]:Sample Rate: 3K
        [YDLIDAR INFO] Current Sampling Rate : 3K
        [YDLIDAR INFO] Now YDLIDAR is scanning ......
        [ERROR] [1711368999.015609277] [ydlidar_node]: Failed to get scan
        timout count: 1
        [ERROR] [1711369001.017133077] [ydlidar_node]: Failed to get scan
        timout count: 2
        [ERROR] [1711369003.018490699] [ydlidar_node]: Failed to get scan
        [ERROR] [1711369005.018813755] [ydlidar_node]: Failed to get scan
        已经切换到WiFi模式,可以ping通雷达,雷达也转
        小鱼 技术大佬 @2693226252
        @2693226252 网络质量较差
