    4.2.1章节构建消息功能包错误string index out of range
    facedetector 接口定义
    1.5k
    • 4
      开心
       sensor_msgs/Image image
      int16 number          # 人脸个数
      float32 use_time      # 识别耗时
      int32[] top           # 人脸在图像中的位置
      int32[] right
      int32[] bottom
      int32[] left
      cmakelists.txt
      project(chapt4_interfaces)
      endif()
      # find dependencies
      find_package(sensor_msgs REQUIRED)
        "srv/FaceDetector.srv"
        DEPENDENCIES sensor_msgs
      if(BUILD_TESTING)
      endif()
      ament_package()
      构建错误
      CMake Error at /opt/ros/humble/share/rosidl_adapter/cmake/rosidl_adapt_interfaces.cmake:59 (message):
        execute_process(/usr/bin/python3 -m rosidl_adapter --package-name
        chapt4_interfaces --arguments-file
        /home/tingbo/chapt4/chapt4_ws/src/build/chapt4_interfaces/rosidl_adapter__arguments__chapt4_interfaces.json
        --output-dir
        /home/tingbo/chapt4/chapt4_ws/src/build/chapt4_interfaces/rosidl_adapter/chapt4_interfaces
        --output-file
        /home/tingbo/chapt4/chapt4_ws/src/build/chapt4_interfaces/rosidl_adapter/chapt4_interfaces.idls)
        returned error code 1:
        Error processing ' sensor_msgs/Image image' of
        'chapt4_interfaces/FaceDetector_Request': 'string index out of range'
          File "/usr/lib/python3.10/runpy.py", line 196, in _run_module_as_main
            return _run_code(code, main_globals, None,
          File "/usr/lib/python3.10/runpy.py", line 86, in _run_code
            exec(code, run_globals)
          File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/__main__.py", line 19, in <module>
            sys.exit(main())
          File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/main.py", line 53, in main
            abs_idl_file = convert_to_idl(
          File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/__init__.py", line 24, in convert_to_idl
            return convert_srv_to_idl(
          File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/srv/__init__.py", line 28, in convert_srv_to_idl
            srv = parse_service_string(package_name, input_file.stem, content)
          File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/parser.py", line 859, in parse_service_string
            request_message = parse_message_string(
          File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/parser.py", line 520, in parse_message_string
            Type(type_string, context_package_name=pkg_name),
          File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/parser.py", line 241, in __init__
            self.is_array = type_string[-1] == ']'
        IndexError: string index out of range
        /opt/ros/humble/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:130 (rosidl_adapt_interfaces)
        CMakeLists.txt:13 (rosidl_generate_interfaces)
      小鱼小 2 条回复 最后回复 回复 引用 0
        小鱼 技术大佬 @43996173
        @43996173 在 4.2.1章节构建消息功能包错误string index out of range 中说:
        se
        这个前面的空格是你复制问题,还是代码里就有
          小鱼 技术大佬 @43996173
          前面多了个空格,书籍是代码格式有部分出现缩进错误,我给你的不是终审稿子,还没修复
          4 1 条回复 最后回复 回复 引用 0
          • 4
            开心 @小鱼
            @小鱼 好了谢谢
