    4.5.3 修改其他节点的参数
    节点参数 main调用函数
    • 4
      开心
      遇到问题:
      在PatrolClient类中写入更新服务参数函数update_server_param_k,在main函数中调用(node->update_server_param_k(1.5);)code代码报错:
      函数 "PatrolClient::update_server_param_k" (已声明 所在行数:77) 不可访问,我没有找到代码的毛病,请求老师帮助
      代码如下:
      #include <chrono>
      #include <cstdlib>
      #include <ctime>
      #include "rclcpp/rclcpp.hpp"
      #include "chapt4_interfaces/srv/patrol.hpp"
      #include "rcl_interfaces/msg/parameter.hpp"
      #include "rcl_interfaces/msg/parameter_value.hpp"
      #include "rcl_interfaces/msg/parameter_type.hpp"
      #include "rcl_interfaces/srv/set_parameters.hpp"
      using SetP = rcl_interfaces::srv::SetParameters;
      using Patrol = chapt4_interfaces::srv::Patrol;
      class PatrolClient : public rclcpp::Node
          public:
           PatrolClient() : Node("patrol_client") {
              patrol_client_ = this->create_client<Patrol>("patrol");
              timer_ = this->create_wall_timer(10s,
              std::bind(&PatrolClient::timer_callback, this));
              srand(time(NULL));
          void timer_callback() {
              while (!patrol_client_->wait_for_service(std::chrono::seconds(1)))
                  if(!rclcpp::ok()) {
                      RCLCPP_ERROR(this->get_logger(),"等待服务端过程中被打断...");
                      return;
                  RCLCPP_INFO(this->get_logger(),"等待服务端上线中");
              auto request = std::make_shared<Patrol::Request>();
              request->target_x = rand() % 15;
              request->target_y = rand() % 15;
              RCLCPP_INFO(this->get_logger(), "请求巡逻:(%f,%f)",request->target_x,
              request->target_y);
              patrol_client_->async_send_request(
                  request,
                  [&](rclcpp::Client<Patrol>::SharedFuture result_future) -> void {
                      auto response = result_future.get();
                      if (response->result == Patrol::Response::SUCCESS) {
                          RCLCPP_INFO(this->get_logger(), "目标点处理成功");
                      } else if (response->result == Patrol::Response::FALL) {
                          RCLCPP_INFO(this->get_logger(), "目标点处理失败");
          private:
           rclcpp::Client<Patrol>::SharedPtr patrol_client_;
          std::shared_ptr<SetP::Response> call_set_parameters(
              rcl_interfaces::msg::Parameter &parameter) {
                  auto param_client =
                  this->create_client<SetP>("/turtle_controller/set_parameters");
                  while (!param_client->wait_for_service(std::chrono::seconds(1)))
                      if (!rclcpp::ok())
                       RCLCPP_ERROR(this->get_logger(),"等待服务的过程中被打断...");
                       return nullptr;
                      RCLCPP_INFO(this->get_logger(),"等待参数设置服务端上线中");
                  auto request = std::make_shared<SetP::Request>();
                  request->parameters.push_back(parameter);
                  auto future = param_client->async_send_request(request);
                  rclcpp::spin_until_future_complete(this->get_node_base_interface(), future);
                  auto response = future.get();
                  return response;
               void update_server_param_k(double k) {
                  auto param = rcl_interfaces::msg::Parameter();
                  param.name = "k";
                  auto param_value = rcl_interfaces::msg::ParameterValue();
                  param_value.type = rcl_interfaces::msg::ParameterType::PARAMETER_DOUBLE;
                  param_value.double_value = k;
                  param.value = param_value;
                  auto response = call_set_parameters(param);
                  if (response == nullptr) {
                      RCLCPP_WARN(this->get_logger(),"参数修改失败");
                      return;
                  } else {
                      for (auto result : response->results) {
                          if (result.successful) {
                              RCLCPP_INFO(this->get_logger(),"参数k已修改为:%f", k);
                          } else {
                              RCLCPP_WARN(this->get_logger(),"参数k失败原因:%s", result.reason.c_str());
      int main(int argc, char **argv) {
          rclcpp::init(argc, argv);
          auto node = std::make_shared<PatrolClient>();
          rclcpp::spin(node);
          rclcpp::shutdown();
          return 0;
        小鱼 技术大佬 @43996173
        @43996173 在 4.5.3 修改其他节点的参数 中说:
        private:
                auto param_client =
                    if (!rclcpp::ok())
                     return nullptr;
                return response;
        注意这里的private,表示私有成员,不能通过对象.函数名字访问,请将其修改为public,这是一个基础的C++类的语法问题,请注意。
        4 1 条回复 最后回复 回复 引用 0
        • 4
          开心 @小鱼
          @小鱼 收到,谢谢,
