    cartographer运行时报错[SUBSCRIBER Error]
    仿真
    cartographer 仿真
    1.8k
    • 24758873092
      Mona Darling
      标题:cartographer运行时报错[SUBSCRIBER Error]
      硬件平台:nuc x86
      系统版本 ubuntu20.04
      ros版本 foxy
      我在仿真大范围建图的时候将所有话题的数据录制为一个bag数据包后,使用bag播放数据并使用cartographer算法进行离线建图,但运行到一段时间后就会报错,不止离线会这样,在使用gazebo仿真的时候也会偶尔报错,两者区别就是出现频率不一样,离线的会比较高
      [occupancy_grid_node-2] 2024-04-16 10:20:35.857 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
      且在出现这个报错后就不能进行建图的保存。
      rviz日志
      [occupancy_grid_node-2] 2024-04-16 10:18:07.626 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
      [cartographer_node-1] [INFO] [1713233890.841698173] [cartographer_ros]: I0416 10:18:10.000000 37828 constraint_builder_2d.cc:281] 26 computations resulted in 0 additional constraints.
      [cartographer_node-1] [INFO] [1713233890.841770416] [cartographer_ros]: I0416 10:18:10.000000 37828 constraint_builder_2d.cc:283] Score histogram:
      [cartographer_node-1] Count: 57  Min: 0.700015  Max: 0.793795  Mean: 0.731902
      [cartographer_node-1] [0.700015, 0.709393)	                ####	Count: 11 (19.298246%)	Total: 11 (19.298246%)
      [cartographer_node-1] [0.709393, 0.718771)	                ####	Count: 11 (19.298246%)	Total: 22 (38.596493%)
      [cartographer_node-1] [0.718771, 0.728149)	                ####	Count: 10 (17.543859%)	Total: 32 (56.140350%)
      [cartographer_node-1] [0.728149, 0.737527)	                  ##	Count: 5 (8.771930%)	Total: 37 (64.912277%)
      [cartographer_node-1] [0.737527, 0.746905)	                   #	Count: 2 (3.508772%)	Total: 39 (68.421051%)
      [cartographer_node-1] [0.746905, 0.756283)	                  ##	Count: 6 (10.526316%)	Total: 45 (78.947365%)
      [cartographer_node-1] [0.756283, 0.765661)	                  ##	Count: 7 (12.280702%)	Total: 52 (91.228073%)
      [cartographer_node-1] [0.765661, 0.775039)	                    	Count: 1 (1.754386%)	Total: 53 (92.982452%)
      [cartographer_node-1] [0.775039, 0.784417)	                    	Count: 1 (1.754386%)	Total: 54 (94.736839%)
      [cartographer_node-1] [0.784417, 0.793795]	                   #	Count: 3 (5.263158%)	Total: 57 (100.000000%)
      [cartographer_node-1] [INFO] [1713233893.029278000] [cartographer_ros]: I0416 10:18:13.000000 37828 constraint_builder_2d.cc:266] Node (0, 4349) with 100 points on submap (0, 43) differs by translation 0.87 rotation 0.025 with score 70.3%.
      [cartographer_node-1] [INFO] [1713233896.179774102] [cartographer_ros]: I0416 10:18:16.000000 37810 motion_filter.cc:42] Motion filter reduced the number of nodes to 51.2588%.
      [cartographer_node-1] [INFO] [1713233896.186951505] [cartographer_ros]: I0416 10:18:16.000000 37830 constraint_builder_2d.cc:266] Node (0, 4357) with 100 points on submap (0, 43) differs by translation 0.92 rotation 0.024 with score 71.2%.
      [occupancy_grid_node-2] 2024-04-16 10:18:16.628 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
      [occupancy_grid_node-2] 2024-04-16 10:18:17.585 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
      [occupancy_grid_node-2] 2024-04-16 10:18:17.686 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
      [cartographer_node-1] [INFO] [1713233898.988229757] [cartographer_ros]: I0416 10:18:18.000000 37830 constraint_builder_2d.cc:266] Node (0, 4364) with 104 points on submap (0, 43) differs by translation 0.95 rotation 0.023 with score 71.9%.
      [occupancy_grid_node-2] 2024-04-16 10:18:19.663 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
      [cartographer_node-1] [INFO] [1713233902.574994615] [cartographer_ros]: I0416 10:18:22.000000 37810 collated_trajectory_builder.cc:72] odom rate: 29.41 Hz 3.40e-02 s +/- 2.50e-16 s (pulsed at 99.29% real time)
      [cartographer_node-1] [INFO] [1713233902.575021898] [cartographer_ros]: I0416 10:18:22.000000 37810 collated_trajectory_builder.cc:72] scan rate: 5.00 Hz 2.00e-01 s +/- 8.46e-04 s (pulsed at 100.25% real time)
      [occupancy_grid_node-2] 2024-04-16 10:18:33.019 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
      [occupancy_grid_node-2] 2024-04-16 10:18:34.406 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
      [cartographer_node-1] [INFO] [1713233916.340383226] [cartographer_ros]: I0416 10:18:36.000000 37810 submap_2d.cc:187] Added submap 50
      [cartographer_node-1] [INFO] [1713233917.686594726] [cartographer_ros]: I0416 10:18:37.000000 37810 collated_trajectory_builder.cc:72] odom rate: 29.21 Hz 3.42e-02 s +/- 2.83e-03 s (pulsed at 99.61% real time)
      [cartographer_node-1] [INFO] [1713233917.686627242] [cartographer_ros]: I0416 10:18:37.000000 37810 collated_trajectory_builder.cc:72] scan rate: 5.00 Hz 2.00e-01 s +/- 7.85e-04 s (pulsed at 99.12% real time)
      [occupancy_grid_node-2] 2024-04-16 10:18:44.333 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
      [cartographer_node-1] [INFO] [1713233929.116405945] [cartographer_ros]: I0416 10:18:49.000000 37830 constraint_builder_2d.cc:281] 50 computations resulted in 3 additional constraints.
      [cartographer_node-1] [INFO] [1713233929.116453399] [cartographer_ros]: I0416 10:18:49.000000 37830 constraint_builder_2d.cc:283] Score histogram:
      [cartographer_node-1] Count: 60  Min: 0.700015  Max: 0.793795  Mean: 0.730867
      [cartographer_node-1] [0.700015, 0.709393)	                ####	Count: 12 (20.000000%)	Total: 12 (20.000000%)
      [cartographer_node-1] [0.709393, 0.718771)	                ####	Count: 12 (20.000000%)	Total: 24 (40.000000%)
      [cartographer_node-1] [0.718771, 0.728149)	                ####	Count: 11 (18.333334%)	Total: 35 (58.333332%)
      [cartographer_node-1] [0.728149, 0.737527)	                  ##	Count: 5 (8.333333%)	Total: 40 (66.666664%)
      [cartographer_node-1] [0.737527, 0.746905)	                   #	Count: 2 (3.333333%)	Total: 42 (70.000000%)
      [cartographer_node-1] [0.746905, 0.756283)	                  ##	Count: 6 (10.000000%)	Total: 48 (80.000000%)
      [cartographer_node-1] [0.756283, 0.765661)	                  ##	Count: 7 (11.666667%)	Total: 55 (91.666664%)
      [cartographer_node-1] [0.765661, 0.775039)	                    	Count: 1 (1.666667%)	Total: 56 (93.333336%)
      [cartographer_node-1] [0.775039, 0.784417)	                    	Count: 1 (1.666667%)	Total: 57 (95.000000%)
      [cartographer_node-1] [0.784417, 0.793795]	                   #	Count: 3 (5.000000%)	Total: 60 (100.000000%)
      [cartographer_node-1] [INFO] [1713233932.712369722] [cartographer_ros]: I0416 10:18:52.000000 37810 collated_trajectory_builder.cc:72] odom rate: 28.94 Hz 3.46e-02 s +/- 4.31e-03 s (pulsed at 99.11% real time)
      [cartographer_node-1] [INFO] [1713233932.712395426] [cartographer_ros]: I0416 10:18:52.000000 37810 collated_trajectory_builder.cc:72] scan rate: 5.00 Hz 2.00e-01 s +/- 8.30e-04 s (pulsed at 100.08% real time)
      [occupancy_grid_node-2] 2024-04-16 10:18:53.486 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
      [occupancy_grid_node-2] 2024-04-16 10:18:53.554 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
      [cartographer_node-1] [INFO] [1713233947.781983307] [cartographer_ros]: I0416 10:19:07.000000 37810 collated_trajectory_builder.cc:72] odom rate: 28.60 Hz 3.50e-02 s +/- 5.65e-03 s (pulsed at 99.47% real time)
      [cartographer_node-1] [INFO] [1713233947.782009956] [cartographer_ros]: I0416 10:19:07.000000 37810 collated_trajectory_builder.cc:72] scan rate: 5.00 Hz 2.00e-01 s +/- 7.40e-04 s (pulsed at 99.62% real time)
      [cartographer_node-1] [INFO] [1713233950.025851001] [cartographer_ros]: I0416 10:19:10.000000 37810 submap_2d.cc:187] Added submap 51
      [cartographer_node-1] [INFO] [1713233962.846597664] [cartographer_ros]: I0416 10:19:22.000000 37810 collated_trajectory_builder.cc:72] odom rate: 28.94 Hz 3.46e-02 s +/- 4.31e-03 s (pulsed at 99.72% real time)
      [cartographer_node-1] [INFO] [1713233962.846625473] [cartographer_ros]: I0416 10:19:22.000000 37810 collated_trajectory_builder.cc:72] scan rate: 5.00 Hz 2.00e-01 s +/- 8.76e-04 s (pulsed at 99.36% real time)
      [occupancy_grid_node-2] 2024-04-16 10:19:23.124 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
      [cartographer_node-1] [INFO] [1713233966.882129331] [cartographer_ros]: I0416 10:19:26.000000 37829 constraint_builder_2d.cc:281] 36 computations resulted in 0 additional constraints.
      [cartographer_node-1] [INFO] [1713233966.882207071] [cartographer_ros]: I0416 10:19:26.000000 37829 constraint_builder_2d.cc:283] Score histogram:
      [cartographer_node-1] [INFO] [1713233977.849668615] [cartographer_ros]: I0416 10:19:37.000000 37810 collated_trajectory_builder.cc:72] odom rate: 29.14 Hz 3.43e-02 s +/- 3.25e-03 s (pulsed at 100.05% real time)
      [cartographer_node-1] [INFO] [1713233977.849701920] [cartographer_ros]: I0416 10:19:37.000000 37810 collated_trajectory_builder.cc:72] scan rate: 5.00 Hz 2.00e-01 s +/- 7.45e-04 s (pulsed at 99.11% real time)
      [cartographer_node-1] [INFO] [1713233984.597310099] [cartographer_ros]: I0416 10:19:44.000000 37810 submap_2d.cc:187] Added submap 52
      [occupancy_grid_node-2] 2024-04-16 10:19:46.224 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
      [cartographer_node-1] [INFO] [1713233993.012246208] [cartographer_ros]: I0416 10:19:53.000000 37810 collated_trajectory_builder.cc:72] odom rate: 28.40 Hz 3.52e-02 s +/- 6.30e-03 s (pulsed at 99.12% real time)
      [cartographer_node-1] [INFO] [1713233993.012275249] [cartographer_ros]: I0416 10:19:53.000000 37810 collated_trajectory_builder.cc:72] scan rate: 5.00 Hz 2.00e-01 s +/- 6.78e-04 s (pulsed at 100.31% real time)
      [cartographer_node-1] [INFO] [1713233996.793134344] [cartographer_ros]: I0416 10:19:56.000000 37810 motion_filter.cc:42] Motion filter reduced the number of nodes to 51.3444%.
      [cartographer_node-1] [INFO] [1713234006.464229819] [cartographer_ros]: I0416 10:20:06.000000 37829 constraint_builder_2d.cc:281] 49 computations resulted in 0 additional constraints.
      [cartographer_node-1] [INFO] [1713234006.464292317] [cartographer_ros]: I0416 10:20:06.000000 37829 constraint_builder_2d.cc:283] Score histogram:
      [cartographer_node-1] [INFO] [1713234008.053840131] [cartographer_ros]: I0416 10:20:08.000000 37810 collated_trajectory_builder.cc:72] odom rate: 28.94 Hz 3.46e-02 s +/- 4.31e-03 s (pulsed at 98.84% real time)
      [cartographer_node-1] [INFO] [1713234008.053869169] [cartographer_ros]: I0416 10:20:08.000000 37810 collated_trajectory_builder.cc:72] scan rate: 5.00 Hz 2.00e-01 s +/- 8.02e-04 s (pulsed at 100.32% real time)
      [cartographer_node-1] [INFO] [1713234020.341586055] [cartographer_ros]: I0416 10:20:20.000000 37810 submap_2d.cc:187] Added submap 53
      [occupancy_grid_node-2] 2024-04-16 10:20:22.602 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
      [occupancy_grid_node-2] 2024-04-16 10:20:22.685 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
      [cartographer_node-1] [INFO] [1713234023.133855795] [cartographer_ros]: I0416 10:20:23.000000 37810 collated_trajectory_builder.cc:72] odom rate: 28.74 Hz 3.48e-02 s +/- 5.16e-03 s (pulsed at 99.47% real time)
      [cartographer_node-1] [INFO] [1713234023.133882169] [cartographer_ros]: I0416 10:20:23.000000 37810 collated_trajectory_builder.cc:72] scan rate: 5.00 Hz 2.00e-01 s +/- 6.52e-04 s (pulsed at 99.55% real time)
      [occupancy_grid_node-2] 2024-04-16 10:20:23.850 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
      [occupancy_grid_node-2] 2024-04-16 10:20:24.959 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
      [occupancy_grid_node-2] 2024-04-16 10:20:30.449 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
      [occupancy_grid_node-2] 2024-04-16 10:20:31.380 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
      [occupancy_grid_node-2] 2024-04-16 10:20:32.514 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
      [occupancy_grid_node-2] 2024-04-16 10:20:32.623 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
      [occupancy_grid_node-2] 2024-04-16 10:20:34.802 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
      [cartographer_node-1] [INFO] [1713234038.173438028] [cartographer_ros]: I0416 10:20:38.000000 37810 collated_trajectory_builder.cc:72] odom rate: 29.34 Hz 3.41e-02 s +/- 1.62e-03 s (pulsed at 99.80% real time)
      [cartographer_node-1] [INFO] [1713234038.173469403] [cartographer_ros]: I0416 10:20:38.000000 37810 collated_trajectory_builder.cc:72] scan rate: 5.00 Hz 2.00e-01 s +/- 6.87e-04 s (pulsed at 98.80% real time)
      [rviz2-3] [INFO] [1713234042.514296088] [rclcpp]: signal_handler(signal_value=2)
      [cartographer_node-1] [INFO] [1713234042.514296087] [rclcpp]: signal_handler(signal_value=2)
      [occupancy_grid_node-2] [INFO] [1713234042.523108658] [rclcpp]: signal_handler(signal_value=2)
      [cartographer_node-1] [INFO] [1713234042.561890233] [cartographer_ros]: I0416 10:20:42.000000 37810 node.cc:545] Shutdown the subscriber of [scan]
      [cartographer_node-1] [INFO] [1713234042.561912285] [cartographer_ros]: I0416 10:20:42.000000 37810 node.cc:545] Shutdown the subscriber of [odom]
      [cartographer_node-1] [INFO] [1713234042.562749360] [cartographer_ros]: I0416 10:20:42.000000 37810 map_builder_bridge.cc:149] Finishing trajectory with ID '0'...
      [cartographer_node-1] [INFO] [1713234042.562844572] [cartographer_ros]: I0416 10:20:42.000000 37810 map_builder_bridge.cc:158] Running final trajectory optimization...
      [cartographer_node-1] [INFO] [1713234042.562865087] [cartographer_ros]: I0416 10:20:42.000000 37827 constraint_builder_2d.cc:281] 36 computations resulted in 0 additional constraints.
      [cartographer_node-1] [INFO] [1713234042.562922493] [cartographer_ros]: I0416 10:20:42.000000 37827 constraint_builder_2d.cc:283] Score histogram:
      [cartographer_node-1] [INFO] [1713234042.640047979] [cartographer_ros]: I0416 10:20:42.000000 37827 pose_graph_2d.cc:382] Remaining work items in queue: 1
      [cartographer_node-1] [INFO] [1713234042.640086526] [cartographer_ros]: I0416 10:20:42.000000 37827 constraint_builder_2d.cc:281] 0 computations resulted in 0 additional constraints.
      [cartographer_node-1] [INFO] [1713234042.640123791] [cartographer_ros]: I0416 10:20:42.000000 37827 constraint_builder_2d.cc:283] Score histogram:
      Optimizing: Done.
      [cartographer_node-1] [INFO] [1713234042.689016520] [cartographer_ros]: I0416 10:20:42.000000 37830 constraint_builder_2d.cc:281] 0 computations resulted in 0 additional constraints.
      [cartographer_node-1] [INFO] [1713234042.689151875] [cartographer_ros]: I0416 10:20:42.000000 37830 constraint_builder_2d.cc:283] Score histogram:
      Optimizing: Done.
      [cartographer_node-1] [INFO] [1713234042.692212785] [cartographer_ros]: I0416 10:20:42.000000 37830 constraint_builder_2d.cc:281] 0 computations resulted in 0 additional constraints.
      [cartographer_node-1] [INFO] [1713234042.692258087] [cartographer_ros]: I0416 10:20:42.000000 37830 constraint_builder_2d.cc:283] Score histogram:
      [INFO] [rviz2-3]: process has finished cleanly [pid 37814]
      [INFO] [cartographer_node-1]: process has finished cleanly [pid 37810]
      [INFO] [occupancy_grid_node-2]: process has finished cleanly [pid 37812]
      lua配置:
      include "map_builder.lua"
      include "trajectory_builder.lua"
      options = {
        map_builder = MAP_BUILDER,
        map_frame = "map",
        tracking_frame = "base_link",  --base_link
        -- base_link改为odom,发布map到odom之间的位姿态
        published_frame = "odom",   --odom
        odom_frame = "odom",  --odom
        -- true改为false,不用提供里程计数据
        provide_odom_frame = false,
        -- false改为true,仅发布2D位资
        publish_frame_projected_to_2d = true,
        -- false改为true,使用里程计数据
        use_odometry = true,
        use_nav_sat = false,
        use_landmarks = false,
        -- 0改为1,使用一个雷达
        num_laser_scans = 1,
        -- 1改为0,不使用多波雷达
        -- 10改为1,1/1=1等于不分割
        num_subdivisions_per_laser_scan = 1,
        num_point_clouds = 0,
        submap_publish_period_sec = 0.5,   --0.3
        odometry_sampling_ratio = 1.,
        imu_sampling_ratio = 1.,
      -- false改为true,启动2D SLAM
      -- 0改成0.10,比机器人半径小的都忽略
      TRAJECTORY_BUILDER_2D.min_range = 1.0  --0.10
      -- 30改成3.5,限制在雷达最大扫描范围内,越小一般越精确些
      TRAJECTORY_BUILDER_2D.max_range = 30   --5
      -- 5改成3,传感器数据超出有效范围最大值
      TRAJECTORY_BUILDER_2D.missing_data_ray_length = 30. --3.0
      -- true改成false,不使用IMU数据,大家可以开启,然后对比下效果
      -- false改成true,使用实时回环检测来进行前端的扫描匹配
      TRAJECTORY_BUILDER_2D.use_online_correlative_scan_matching = false
      -- 1.0改成0.1,提高对运动的敏感度
      TRAJECTORY_BUILDER_2D.motion_filter.max_angle_radians = math.rad(0.2) --0.1
      -- 0.55改成0.65,Fast csm的最低分数,高于此分数才进行优化。
      POSE_GRAPH.constraint_builder.min_score = 0.7       --0.65
      --0.6改成0.7,全局定位最小分数,低于此分数则认为目前全局定位不准确
      POSE_GRAPH.constraint_builder.global_localization_min_score = 0.65     --0.7
      -- 设置0可关闭全局SLAM
      POSE_GRAPH.optimize_every_n_nodes = 100
      return options
      launch文件配置
      import os
          # 定位到功能包的地址
          pkg_share = FindPackageShare(package='fishbot_cartographer').find('fishbot_cartographer')
          #=====================运行节点需要的配置=======================================================================
          # 是否使用仿真时间,我们用gazebo,这里设置成true
          use_sim_time = LaunchConfiguration('use_sim_time', default='true')
          # 地图的分辨率--0.05
          resolution = LaunchConfiguration('resolution', default='0.08')
          # 地图的发布周期--0.5
          publish_period_sec = LaunchConfiguration('publish_period_sec', default='1')
          # 配置文件夹路径
          configuration_directory = LaunchConfiguration('configuration_directory',default= os.path.join(pkg_share, 'config') )
          # 配置文件
          configuration_basename = LaunchConfiguration('configuration_basename', default='fishbot_2d.lua')
          #=====================声明三个节点,cartographer/occupancy_grid_node/rviz_node=================================
          cartographer_node = Node(
              package='cartographer_ros',
              executable='cartographer_node',
              name='cartographer_node',
              output='screen',
              arguments=['-configuration_directory', configuration_directory,
                         '-configuration_basename', configuration_basename])
          occupancy_grid_node = Node(
              executable='occupancy_grid_node',
              name='occupancy_grid_node',
              output='screen',
              arguments=['-resolution', resolution, '-publish_period_sec', publish_period_sec])
          rviz_node = Node(
              package='rviz2',
              executable='rviz2',
              name='rviz2',
              # arguments=['-d', rviz_config_dir],
              output='screen')
          #===============================================定义启动文件========================================================
          ld = LaunchDescription()
          ld.add_action(cartographer_node)
          ld.add_action(occupancy_grid_node)
          ld.add_action(rviz_node)
          return ld
      24758873092 小鱼小 2 条回复 最后回复 回复 引用 0
      • 24758873092
        Mona Darling @2475887309
        @2475887309 cartographer算法是使用apt安装的,源码安装会报错,一直没解决
          小鱼 技术大佬 @2475887309
          @2475887309 暂时没有看出问题,可能是性能瓶颈,可以试试使用slam_toolbox 进行大场景地图构建。
