    fishbot雷达建图中断
    fishbot建图 雷达
    6.9k
    • M
      mixllred
      最后由 mixllred 编辑
      标题:fishbot雷达建图中断
      提问:使用激光雷达进行测试建图时,开始建图不到一分钟出现报错,建图中断
      具体细节和上下文:
       ) 驱动雷达
      2) 建图测试
      3) 退出
      #? 1
      UART2SOCKET:8888->/tmp/fishbot_laser
      Prepare to Accept connect!
      3 <socket.socket fd=6, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=0, laddr=('172.17.0.2', 8888), raddr=('192.168.43.165', 62416)> 4
      PTY: Opened /dev/pts/1 for 0.0.0.0:8888
      [YDLIDAR INFO] Current ROS Driver Version: 1.4.5
      [YDLIDAR]:SDK Version: 1.4.5
      [YDLIDAR]:Lidar running correctly ! The health status: good
      [YDLIDAR] Connection established in [/tmp/fishbot_laser][115200]:
      Firmware version: 1.5
      Hardware version: 1
      Model: S4
      Serial: 2020101300002268
      [YDLIDAR]:Fixed Size: 360
      [YDLIDAR]:Sample Rate: 3K
      [YDLIDAR INFO] Current Sampling Rate : 3K
      [YDLIDAR INFO] Now YDLIDAR is scanning ......
      timout count: 1
      [ERROR] [1713344387.186853131] [ydlidar_node]: Failed to get scan
      timout count: 2
      [ERROR] [1713344389.187233959] [ydlidar_node]: Failed to get scan
      [ERROR] [1713344391.188039318] [ydlidar_node]: Failed to get scan
      [ERROR] [1713344393.188949412] [ydlidar_node]: Failed to get scan
      [ERROR] [1713344395.189370541] [ydlidar_node]: Failed to get scan
      [ERROR] [1713344397.190185397] [ydlidar_node]: Failed to get scan
      [ERROR] [1713344399.191660545] [ydlidar_node]: Failed to get scan
      [ERROR] [1713344401.191919681] [ydlidar_node]: Failed to get scan
      [ERROR] [1713344403.192957289] [ydlidar_node]: Failed to get scan
      [ERROR] [1713344405.193506477] [ydlidar_node]: Failed to get scan
      [ERROR] [1713344407.194619107] [ydlidar_node]: Failed to get scan
      [ERROR] [1713344409.195089088] [ydlidar_node]: Failed to get scan
      #? 2
      [INFO] [launch]: All log files can be found below /root/.ros/log/2024-04-21-08-26-05-220524-08d262fab448-251
      [INFO] [laser_x2-1]: process started with pid [252]
      [INFO] [static_transform_publisher-2]: process started with pid [254]
      [INFO] [cartographer_node-3]: process started with pid [256]
      [INFO] [cartographer_occupancy_grid_node-4]: process started with pid [268]
      [INFO] [rviz2-5]: process started with pid [270]
      [static_transform_publisher-2] [WARN] [1713687965.313838746] []: Old-style arguments are deprecated; see --help for new-style arguments
      [static_transform_publisher-2] [INFO] [1713687965.325799112] [static_tf_pub_laser]: Spinning until stopped - publishing transform
      [static_transform_publisher-2] translation: ('0.000000', '0.000000', '0.000000')
      [static_transform_publisher-2] from 'base_link' to 'laser_frame'
      [rviz2-5] QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
      [cartographer_node-3] [INFO] [1713687965.407037161] [cartographer logger]: I0421 08:26:05.000000   256 configuration_file_resolver.cc:41] Found '/workspace/install/fishbot_laser_driver/share/fishbot_laser_driver/config/fishbot_laser_2d.lua' for 'fishbot_laser_2d.lua'.
      [cartographer_node-3] [INFO] [1713687965.407333627] [cartographer logger]: I0421 08:26:05.000000   256 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/map_builder.lua' for 'map_builder.lua'.
      [cartographer_node-3] [INFO] [1713687965.407357973] [cartographer logger]: I0421 08:26:05.000000   256 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/map_builder.lua' for 'map_builder.lua'.
      [cartographer_node-3] [INFO] [1713687965.407391739] [cartographer logger]: I0421 08:26:05.000000   256 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/pose_graph.lua' for 'pose_graph.lua'.
      [cartographer_node-3] [INFO] [1713687965.407410052] [cartographer logger]: I0421 08:26:05.000000   256 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/pose_graph.lua' for 'pose_graph.lua'.
      [cartographer_node-3] [INFO] [1713687965.407506443] [cartographer logger]: I0421 08:26:05.000000   256 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/trajectory_builder.lua' for 'trajectory_builder.lua'.
      [cartographer_node-3] [INFO] [1713687965.407523370] [cartographer logger]: I0421 08:26:05.000000   256 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/trajectory_builder.lua' for 'trajectory_builder.lua'.
      [cartographer_node-3] [INFO] [1713687965.409681341] [cartographer logger]: I0421 08:26:05.000000   256 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/trajectory_builder_2d.lua' for 'trajectory_builder_2d.lua'.
      [cartographer_node-3] [INFO] [1713687965.409753337] [cartographer logger]: I0421 08:26:05.000000   256 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/trajectory_builder_2d.lua' for 'trajectory_builder_2d.lua'.
      [cartographer_node-3] [INFO] [1713687965.409878367] [cartographer logger]: I0421 08:26:05.000000   256 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/trajectory_builder_3d.lua' for 'trajectory_builder_3d.lua'.
      [cartographer_node-3] [INFO] [1713687965.409895396] [cartographer logger]: I0421 08:26:05.000000   256 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/trajectory_builder_3d.lua' for 'trajectory_builder_3d.lua'.
      [cartographer_node-3] [INFO] [1713687965.434317083] [cartographer logger]: I0421 08:26:05.000000   256 map_builder_bridge.cpp:136] Added trajectory with ID '0'.
      [rviz2-5] [INFO] [1713687966.720573653] [rviz2]: Stereo is NOT SUPPORTED
      [rviz2-5] [INFO] [1713687966.721400194] [rviz2]: OpenGl version: 4.1 (GLSL 4.1)
      [rviz2-5] [INFO] [1713687966.757898421] [rviz2]: Stereo is NOT SUPPORTED
      [cartographer_node-3] [INFO] [1713687990.218718154] [cartographer logger]: I0421 08:26:30.000000   256 ordered_multi_queue.cc:172] All sensor data for trajectory 0 is available starting at '638492847902104249'.
      [cartographer_node-3] [INFO] [1713687990.218761352] [cartographer logger]: I0421 08:26:30.000000   256 collated_trajectory_builder.cc:81] scan rate: unknown
      [cartographer_node-3] [WARN] [1713687990.219176106] [cartographer logger]: W0421 08:26:30.000000   256 pose_extrapolator.cc:168] Queue too short for velocity estimation. Queue duration: 0 s
      [cartographer_node-3] [INFO] [1713687990.221447106] [cartographer logger]: I0421 08:26:30.000000   256 pose_graph_2d.cc:148] Inserted submap (0, 0).
      [rviz2-5] [INFO] [1713687990.391474751] [rviz2]: Trying to create a map of size 68 x 91 using 1 swatches
      [rviz2-5] [ERROR] [1713687990.423338297] [rviz2]: Vertex Program:rviz/glsl120/indexed_8bit_image.vert Fragment Program:rviz/glsl120/indexed_8bit_image.frag GLSL link result :
      [rviz2-5] active samplers with a different type refer to the same texture image unit
      [rviz2-5] [INFO] [1713687992.407318504] [rviz2]: Trying to create a map of size 69 x 91 using 1 swatches
      [rviz2-5] [INFO] [1713687993.400064229] [rviz2]: Trying to create a map of size 89 x 118 using 1 swatches
      [rviz2-5] [INFO] [1713687994.391925904] [rviz2]: Trying to create a map of size 90 x 118 using 1 swatches
      [rviz2-5] [INFO] [1713687998.396203407] [rviz2]: Trying to create a map of size 132 x 140 using 1 swatches
      [rviz2-5] [INFO] [1713687999.416110199] [rviz2]: Trying to create a map of size 143 x 140 using 1 swatches
      [rviz2-5] [INFO] [1713688000.212715186] [rviz2]: Message Filter dropping message: frame 'laser_frame' at time 1713687990.210 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
      [cartographer_node-3] [INFO] [1713688005.282019885] [cartographer logger]: I0421 08:26:45.000000   256 collated_trajectory_builder.cc:81] scan rate: 2.22 Hz 4.50e-01 s +/- 5.82e-01 s (pulsed at 100.01% real time)
      [laser_x2-1] timout count: 1
      [laser_x2-1] [ERROR] [1713688009.430782352] [ydlidar_node]: Failed to get scan
      [laser_x2-1] timout count: 2
      [laser_x2-1] [ERROR] [1713688011.431114965] [ydlidar_node]: Failed to get scan
      [laser_x2-1] [ERROR] [1713688013.431611985] [ydlidar_node]: Failed to get scan
      [laser_x2-1] [ERROR] [1713688015.431873842] [ydlidar_node]: Failed to get scan
      [laser_x2-1] [ERROR] [1713688017.432290740] [ydlidar_node]: Failed to get scan
      后面持续同上
      尝试过的解决方法:
      1、重新烧录
      2、更换新的雷达及转接板
      以上方法均失败
      M 1 条回复 最后回复 回复 引用 0
      • M
        mixllred @mixllred
        @mixllred 重复每次还是无法正常建图,不是偶然情况
        • M mixllred 将这个主题转为问答主题,在
        • M mixllred 在 中 引用了 这个主题
          小鱼 技术大佬 @mixllred
          @mixllred https://fishros.org.cn/forum/topic/151/提问前必看-不符合要求的问题拒绝回答
          请注意代码格式,非必要不要截图
          请附带更详细的信息,比如网络结构,雷达板版本,你的系统相关信息
          • M
            mixllred @小鱼
            最后由 mixllred 编辑
            ubuntu使用的是20.04和ros2(foxy)
            雷达是原配雷达,不是其他型号的雷达
            Hardware version: 1
            Model: S4
            网络是桥接模式,使用的笔记本电脑开的热点。
            (后面更换Ubuntu22.04 ROS2 Humble 后仍然有这个问题:建图中断)
            配置好驱动后,进行建图测试,开始建图后,会出现
            timout count: 1
            timout count: 2
            重试后
            和小鱼给的范例输出图片比对,发现进行#2建图测试后,我的输出不一样
            ) 驱动雷达
            2) 建图测试
            3) 退出
            #? 1
            Hardware version: 1
            Model: S4
            timout count: 1
            timout count: 2
            #? 2
            我认为和以下报错有关
            和
            M 小鱼小 2 条回复 最后回复 回复 引用 0
            • M
              mixllred @mixllred
              最后由 mixllred 编辑
              @mixllred
              最新还是无法正常建图
              欢迎鱼香ROS使用雷达驱动系统,注意当前版本为ROS2版本驱动哦~
              1) 驱动雷达
              2) 建图测试
              3) 退出
              #? 1
              3 <socket.socket fd=6, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=0, laddr=('172.17.0.2', 8888), raddr=('192.168.43.165', 62906)> 4
              PTY: Opened /dev/pts/3 for 0.0.0.0:8888
              Hardware version: 1
              Model: S4
              Serial: 2021031800000019
              timout count: 1
              [YDLIDAR]:Fixed Size: 420
              [ERROR] [1714203275.305460386] [ydlidar_node]: Failed to get scan
              timout count: 1
              [ERROR] [1714203277.305937727] [ydlidar_node]: Failed to get scan
                小鱼 技术大佬 @mixllred
                @mixllred 在 fishbot雷达建图中断 中说:
                很想给你画一张结构图,虚拟机用桥接,笔记本开热点,你观察下小车的ip地址和虚拟机的ip,你肯定会发现两者不在同一个网段里。
                小车要想把数据发送给虚拟机(假设桥接模式),需要经过这样一条链路:
                小车-->电脑主机(中间还有网卡转发,更加耗时)-->路由器-->虚拟机
                如果是小车直接连接路由器,电脑桥接或者不是虚拟机,正常链路是:
                小车-->路由器-->虚拟机
                可以找客服要一个常见问题解答视频,里面有关于网络的详细介绍。
                • M
                  mixllred @小鱼
                  最后由 mixllred 编辑
                  ip:192.168.137.47
                  S_ip:192.168.43.199
                  在虚拟机里尝试ping:
                  ~/Desktop$ ping 192.168.137.47
                  PING 192.168.137.47 (192.168.137.47) 56(84) bytes of data.
                  和
                  ~/Desktop$ ping 192.168.143.199
                  PING 192.168.143.199 (192.168.143.199) 56(84) bytes of data.
                  From 192.168.43.165 icmp_seq=1 Redirect Network(New nexthop: 1.43.168.192)
                  From 192.168.43.165 icmp_seq=2 Redirect Network(New nexthop: 1.43.168.192)
                  From 192.168.43.165 icmp_seq=3 Redirect Network(New nexthop: 1.43.168.192)
                  From 192.168.43.165 icmp_seq=4 Redirect Network(New nexthop: 1.43.168.192)
                    小鱼 技术大佬 @mixllred
                    @mixllred 从ip可以看出都不再一个网段里,而且无法直接ping通。符合我提供的不推荐的网络结构,还不如直接让小车连路由,过电脑是多此一举。
                    • M
                      mixllred @小鱼
                      最后由 mixllred 编辑
                      @小鱼 路由器可以连无线网卡吗,校内只有校园内网,只能在一个设备ip使用
                        小鱼 技术大佬 @mixllred
                        @mixllred 原来是校园网,校园网质量是非常差的,你能跑起来就是万幸了,建议买个二手路由器,十来块钱,非常好用。
                        • M
                          mixllred @小鱼
                          最后由 mixllred 编辑
                          @小鱼 是笔记本通过有线网卡连接到路由器上,然后路由器(不上网)相当提供一个局域网吗?因为校内网线接口都需要登陆,连接路由器十分困难
                          谢谢小鱼,我大概理解了
                            小鱼 技术大佬 @mixllred
                            @mixllred 路由器不用上网,能提供一个稳定的内网数据链路就好。
                            • M
                              mixllred @小鱼
                              • M mixllred 将这个主题标记为已解决,在
                              • E eework 在 中 引用了 这个主题
