    在jupyter中运行ROS2节点程序时出错
    jupyter miniconda ros2-foxy
    2.9k
    • 刘豪刘
      豪哥
      最后由 刘豪 编辑
      请教下大家:
      我在jupyter中运行ROS2中的 from rclpy.node import Node后一直提示有错误,请见图片所示。
      不知道是那里的问题。
      我的系统信息如下:
      1、我是按照小鱼foxy版ROS2教程的第7.12章节操作的,只是在小鱼给出的miniconda下载地址中没有找到教程里面说的这里“小鱼推荐选择Python3.8 Miniconda3 Linux 64-bit” 这个版本,就下载了个相近的3.9
      2、我的系统是ubuntu20.04.6 amd64bit
      3、ROS2版本是foxy
      以下为文字版错误log信息:
      ModuleNotFoundError Traceback (most recent call last)
      Cell In[2], line 1
      ----> 1 from rclpy.node import Node
      File /opt/ros/foxy/lib/python3.8/site-packages/rclpy/node.py:42
      40 from rclpy.callback_groups import MutuallyExclusiveCallbackGroup
      41 from rclpy.callback_groups import ReentrantCallbackGroup
      ---> 42 from rclpy.client import Client
      43 from rclpy.clock import Clock
      44 from rclpy.clock import ROSClock
      File /opt/ros/foxy/lib/python3.8/site-packages/rclpy/client.py:22
      20 from rclpy.callback_groups import CallbackGroup
      21 from rclpy.context import Context
      ---> 22 from rclpy.impl.implementation_singleton import rclpy_implementation as _rclpy
      23 from rclpy.qos import QoSProfile
      24 from rclpy.task import Future
      File /opt/ros/foxy/lib/python3.8/site-packages/rclpy/impl/implementation_singleton.py:31
      15 """
      16 Provide singleton access to the rclpy C modules.
      17
      26 # ...
      27 """
      29 from rclpy.impl import _import
      ---> 31 rclpy_implementation = _import('._rclpy')
      32 rclpy_action_implementation = _import('._rclpy_action')
      33 rclpy_logging_implementation = _import('._rclpy_logging')
      File /opt/ros/foxy/lib/python3.8/site-packages/rclpy/impl/init.py:28, in _import(name)
      23 try:
      24 # Since Python 3.8, on Windows we should ensure DLL directories are
      25 # explicitly added to the search path.
      26 # See https://docs.python.org/3/whatsnew/3.8.html#bpo-36085-whatsnew
      27 with add_dll_directories_from_env('PATH'):
      ---> 28 return importlib.import_module(name, package='rclpy')
      29 except ImportError as e:
      30 if e.path is None:
      File ~/miniconda3/lib/python3.9/importlib/init.py:127, in import_module(name, package)
      125 break
      126 level += 1
      --> 127 return _bootstrap._gcd_import(name[level:], package, level)
      ModuleNotFoundError: No module named 'rclpy._rclpy'
      The C extension '/opt/ros/foxy/lib/python3.8/site-packages/rclpy/_rclpy.cpython-39-x86_64-linux-gnu.so' isn't present on the system. Please refer to 'https://index.ros.org/doc/ros2/Troubleshooting/Installation-Troubleshooting/#import-failing-without-library-present-on-the-system' for possible solutions*
        小鱼 技术大佬 @刘豪
        @刘豪 右上角搜这个 linux-gun.so 一大堆答案
        你不给文字版的log,我就不能帮你直接搜了
        刘豪刘 2 条回复 最后回复 回复 引用 0
        • 刘豪刘
          豪哥 @小鱼
          不好意思,我现在送上文字版log,感谢感谢!
          如下:
          Cell In[2], line 1
          15 """
          17
          26 # ...
          27 """
          23 try:
          125 break
          126 level += 1
          • 刘豪刘
            豪哥 @小鱼
