    使用游戏手柄控制机器人
    手柄 ros-noetic
      华彩Cadenza
      请问一下为什么我安装ros-noetic-joystick-drivers包的时候报错:Some packages could not be installed. This may mean that you have
      requested an impossible situation or if you are using the unstable
      distribution that some required packages have not yet been created
      or been moved out of Incoming.
      The following information may help to resolve the situation:
      ros-noetic-joystick-drivers : Depends: ros-noetic-ps3joy but it is not installable
      Depends: ros-noetic-wiimote but it is not installable
      E: Unable to correct problems, you have held broken packages.
      12999190831 1 条回复 最后回复 回复 引用 0
      • 12999190831
        川口那小子 @1434598701
        @1434598701 解决了吗
