    Cartographer警告
    cartographer warning
    • 32535196423
      3253519642
      采用手持雷达Cartographer建图,可以顺利建图,但会触发警告
      [cartographer_node-1] [WARN] [1714496501.215460869] [cartographer logger]: W0501 01:01:41.000000 62509 range_data_collator.cc:82] Dropped 3 earlier points.
      [cartographer_node-1] [WARN] [1714496501.302625350] [cartographer logger]: W0501 01:01:41.000000 62509 range_data_collator.cc:82] Dropped 9 earlier points.
      [cartographer_node-1] [WARN] [1714496501.390131808] [cartographer logger]: W0501 01:01:41.000000 62509 range_data_collator.cc:82] Dropped 8 earlier points.
      [cartographer_node-1] [WARN] [1714496501.480315173] [cartographer logger]: W0501 01:01:41.000000 62509 range_data_collator.cc:82] Dropped 7 earlier points.
      [cartographer_node-1] [WARN] [1714496501.652719469] [cartographer logger]: W0501 01:01:41.000000 62509 range_data_collator.cc:82] Dropped 26 earlier points.
      [cartographer_node-1] [WARN] [1714496501.827615893] [cartographer logger]: W0501 01:01:41.000000 62509 range_data_collator.cc:82] Dropped 4 earlier points.
      [cartographer_node-1] [WARN] [1714496501.914384975] [cartographer logger]: W0501 01:01:41.000000 62509 range_data_collator.cc:82] Dropped 18 earlier points.
      [cartographer_node-1] [WARN] [1714496502.003949874] [cartographer logger]: W0501 01:01:42.000000 62509 range_data_collator.cc:82] Dropped 7 earlier points.
      [cartographer_node-1] [WARN] [1714496502.176990558] [cartographer logger]: W0501 01:01:42.000000 62509 range_data_collator.cc:82] Dropped 24 earlier points.
      [cartographer_node-1] [WARN] [1714496502.351917280] [cartographer logger]: W0501 01:01:42.000000 62509 range_data_collator.cc:82] Dropped 11 earlier points.
      [cartographer_node-1] [WARN] [1714496502.439868920] [cartographer logger]: W0501 01:01:42.000000 62509 range_data_collator.cc:82] Dropped 9 earlier points.
      [cartographer_node-1] [WARN] [1714496502.527763490] [cartographer logger]: W0501 01:01:42.000000 62509 range_data_collator.cc:82] Dropped 6 earlier points.
      [cartographer_node-1] [WARN] [1714496502.614549513] [cartographer logger]: W0501 01:01:42.000000 62509 range_data_collator.cc:82] Dropped 7 earlier points.
      [cartographer_node-1] [WARN] [1714496502.702752650] [cartographer logger]: W0501 01:01:42.000000 62509 range_data_collator.cc:82] Dropped 14 earlier points.
      [cartographer_node-1] [WARN] [1714496502.790368453] [cartographer logger]: W0501 01:01:42.000000 62509 range_data_collator.cc:82] Dropped 1 earlier points.
      [cartographer_node-1] [WARN] [1714496502.880881481] [cartographer logger]: W0501 01:01:42.000000 62509 range_data_collator.cc:82] Dropped 11 earlier points.
      [cartographer_node-1] [WARN] [1714496502.965038746] [cartographer logger]: W0501 01:01:42.000000 62509 range_data_collator.cc:82] Dropped 6 earlier points.
      [cartographer_node-1] [WARN] [1714496503.053814088] [cartographer logger]: W0501 01:01:43.000000 62509 range_data_collator.cc:82] Dropped 12 earlier points.
      [cartographer_node-1] [WARN] [1714496503.139583006] [cartographer logger]: W0501 01:01:43.000000 62509 range_data_collator.cc:82] Dropped 9 earlier points.
      [cartographer_node-1] [WARN] [1714496503.231428410] [cartographer logger]: W0501 01:01:43.000000 62509 range_data_collator.cc:82] Dropped 7 earlier points.
      [cartographer_node-1] [WARN] [1714496503.314349932] [cartographer logger]: W0501 01:01:43.000000 62509 range_data_collator.cc:82] Dropped 4 earlier points.
      [cartographer_node-1] [WARN] [1714496503.401728617] [cartographer logger]: W0501 01:01:43.000000 62509 range_data_collator.cc:82] Dropped 14 earlier points.
      [cartographer_node-1] [WARN] [1714496503.490083507] [cartographer logger]: W0501 01:01:43.000000 62509 range_data_collator.cc:82] Dropped 4 earlier points.
      [cartographer_node-1] [WARN] [1714496503.582543798] [cartographer logger]: W0501 01:01:43.000000 62509 range_data_collator.cc:82] Dropped 2 earlier points.
      [cartographer_node-1] [WARN] [1714496503.751956079] [cartographer logger]: W0501 01:01:43.000000 62509 range_data_collator.cc:82] Dropped 41 earlier points.
      请问大家这个会有什么影响吗,什么操作能解决这个警告
      Z 1 条回复 最后回复 回复 引用 0
      • Z
        zy888 @3253519642
        @3253519642 你好。你解决了吗?我现在也是遇到这个问题了,无语了。我使用的雷达是stl06p,听说好的雷达就不会,我也不清楚这和我使用的转接板是ch340是否有关系,我去换一下试一试
