    使用tool__box建图,按照步骤来的,前面都没错,但是运行ros2 launch slam_toolbox online_async_launch.py后,启动rviz2就开始报错
    移动机器人制作
    fishbot建图 toolbox
    • 25241673162
      今朝
      User
      olh@olh-desktop:~$ ros2 launch slam_toolbox online_async_launch.py
      [INFO] [launch]: All log files can be found below /home/olh/.ros/log/2024-05-04-21-51-00-836468-olh-desktop-4350
      [INFO] [async_slam_toolbox_node-1]: process started with pid [4351]
      [async_slam_toolbox_node-1] [INFO] [1714830661.215165715] [slam_toolbox]: Node using stack size 40000000
      [async_slam_toolbox_node-1] [INFO] [1714830661.373611485] [slam_toolbox]: Using solver plugin solver_plugins::CeresSolver
      [async_slam_toolbox_node-1] [INFO] [1714830661.374160134] [slam_toolbox]: CeresSolver: Using SCHUR_JACOBI preconditioner.
      [async_slam_toolbox_node-1] [INFO] [1714830661.696277555] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1714830661.507 for reason 'discarding message because the queue is full'
      [async_slam_toolbox_node-1] [INFO] [1714830661.862008135] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1714830661.672 for reason 'discarding message because the queue is full'
      可能是use_sim_time=true的问题,但是我不知道是不是要在雷达启动的launch文件加use_sim_time=true还是
        小鱼 技术大佬 @2524167316
        @2524167316 请问使用的是什么平台和固件
