    9章上传错误
    upload-port错误 type-c驱动
    • 4
      开心
      上传错误
      * 正在文件夹 fishbot_motion_control 中执行任务: platformio run --target upload
      Processing featheresp32 (platform: espressif32; board: featheresp32; framework: arduino)
      Verbose mode can be enabled via `-v, --verbose` option
      CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/featheresp32.html
      PLATFORM: Espressif 32 (6.6.0) > Adafruit ESP32 Feather
      HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
      DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-prog, iot-bus-jtag, jlink,
      minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h,
      olimex-jtag-tiny, tumpa)
      PACKAGES:
      - framework-arduinoespressif32 @ 3.20014.231204 (2.0.14)
      - tool-esptoolpy @ 1.40501.0 (4.5.1)
      - tool-mkfatfs @ 2.0.1
      - tool-mklittlefs @ 1.203.210628 (2.3)
      - tool-mkspiffs @ 2.230.0 (2.30)
      - toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
      LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
      LDF Modes: Finder ~ chain, Compatibility ~ soft
      Installing importlib-resources with pip at PlatformIO environment
      /home/tingbo/.platformio/penv/bin/python -m pip install importlib-resources
      Requirement already satisfied: importlib-resources in
      /home/tingbo/.platformio/penv/lib/python3.10/site-packages (6.4.0)
      Installing pyyaml with pip at PlatformIO environment
      /home/tingbo/.platformio/penv/bin/python -m pip install pyyaml
      Requirement already satisfied: pyyaml in
      /home/tingbo/.platformio/penv/lib/python3.10/site-packages (6.0.1)
      Installing markupsafe==2.0.1 with pip at PlatformIO environment
      /home/tingbo/.platformio/penv/bin/python -m pip install markupsafe==2.0.1
      Requirement already satisfied: markupsafe==2.0.1 in
      /home/tingbo/.platformio/penv/lib/python3.10/site-packages (2.0.1)
      PACKAGES:
      Configuring featheresp32 with transport wifi
      micro-ROS already built
      Found 38 compatible libraries
      Scanning dependencies...
      Dependency Graph
      |-- Esp32McpwmMotor @ 0.1.0+sha.145c06d
      |-- Esp32PcntEncoder @ 0.1.0+sha.d9cff54
      |-- micro_ros_platformio @ 0.0.1+sha.1ae444b
      |-- Kinematics
      |-- PidController
      |-- WiFi @ 2.0.0
      Building in release mode
      Retrieving maximum program size .pio/build/featheresp32/firmware.elf
      Checking size .pio/build/featheresp32/firmware.elf
      Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
      RAM: [== ] 23.6% (used 77256 bytes from 327680 bytes)
      Flash: [====== ] 60.9% (used 798649 bytes from 1310720 bytes)
      Configuring upload protocol...
      AVAILABLE: cmsis-dap, esp-bridge, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule,
      olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
      CURRENT: upload_protocol = esptool
      Looking for upload port...
      Error: Please specify `upload_port` for environment or use global `--upload-port` option.
      For some development platforms it can be a USB flash drive (i.e. /media/<user>/<device name>)
      *** [upload] Explicit exit, status 1
      ================================ [FAILED] Took 14.13 seconds
      * 终端进程“platformio 'run', '--target', 'upload'”已终止,退出代码: 1。
      * 终端将被任务重用,按任意键关闭。
        小鱼 技术大佬 @43996173
        @43996173 权限占用问题,已解决
