    9.5.1运行雷达转接板驱动报错
    雷达 驱动报错
    • 4
      开心
      报错日志:
      tingbo@tingbo-i7:~/chapt9/fishbot_ws$ source install/setup.bash
      tingbo@tingbo-i7:~/chapt9/fishbot_ws$ ros2 run ros_serail2wifi tcp_server --ros-args -p serial_port:=/tmp/tty_laser
        File "/home/tingbo/chapt9/fishbot_ws/install/ros_serail2wifi/lib/ros_serail2wifi/tcp_server", line 33, in <module>
          sys.exit(load_entry_point('ros-serail2wifi==0.0.0', 'console_scripts', 'tcp_server')())
        File "/home/tingbo/chapt9/fishbot_ws/install/ros_serail2wifi/lib/python3.10/site-packages/ros_serail2wifi/tcpserver.py", line 76, in main
          node.run()
        File "/home/tingbo/chapt9/fishbot_ws/install/ros_serail2wifi/lib/python3.10/site-packages/ros_serail2wifi/tcpserver.py", line 33, in run
          os.symlink(os.ttyname(slave), self.serial_port)
      FileExistsError: [Errno 17] File exists: '/dev/pts/4' -> '/tmp/tty_laser'
