    自定义接口RCLPY ModuleNotFoundError
    动手学ros2 modulenotfound
    • 5
      DJMAX-动起来MU
      最后由 569390370 编辑
      [标题: No module named 'example_ros2_interfaces']
      运行时无法找到example_ros2_interfaces此模块
      具体细节和上下文:
      使用以下命令:
      cat@lubancat:~/ros/d2lros2/chapt3/chapt3_ws$ ros2 run example_interfaces_rclpy example_interfaces_robot_02
      报错内容:
      File "/home/cat/ros/d2lros2/chapt3/chapt3_ws/install/example_interfaces_rclpy/lib/example_interfaces_rclpy/example_interfaces_robot_02", line 33, in <module>
      sys.exit(load_entry_point('example-interfaces-rclpy==0.0.0', 'console_scripts', 'example_interfaces_robot_02')())
      File "/home/cat/ros/d2lros2/chapt3/chapt3_ws/install/example_interfaces_rclpy/lib/example_interfaces_rclpy/example_interfaces_robot_02", line 25, in importlib_load_entry_point
      return next(matches).load()
      File "/usr/lib/python3.10/importlib/metadata/init.py", line 171, in load
      module = import_module(match.group('module'))
      File "/usr/lib/python3.10/importlib/init.py", line 126, in import_module
      File "<frozen importlib._bootstrap>", line 1050, in _gcd_import
      File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
      File "<frozen importlib._bootstrap>", line 1006, in _find_and_load_unlocked
      File "<frozen importlib._bootstrap>", line 688, in _load_unlocked
      File "<frozen importlib._bootstrap_external>", line 883, in exec_module
      File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
      File "/home/cat/ros/d2lros2/chapt3/chapt3_ws/install/example_interfaces_rclpy/lib/python3.10/site-packages/example_interfaces_rclpy/example_interfaces_robot_02.py", line 4, in <module>
      from example_ros2_interfaces.msg import RobotStatus
      ModuleNotFoundError: No module named 'example_ros2_interfaces'
      问题补充:
      使用的是python3.10
      系统是Ubuntu 22.04
