    slam建图问题
    slam 建图
      zxy
      最后由 1209070035 编辑
      QQ图片20240529092948.png 这个是什么情况QQ图片20240529093108.png 我进行到这一步了
      ros2@ros2-virtual-machine:~/桌面$ colcon build --packages-select fishbot_cartographer
      Starting >>> fishbot_cartographer
      Finished <<< fishbot_cartographer [0.75s]
      Summary: 1 package finished [1.79s]
      ros2@ros2-virtual-machine:~/桌面$ source install/setup.bash
      ros2 launch fishbot_description gazebo.launch.py
      Package 'fishbot_description' not found: "package 'fishbot_description' not found, searching: ['/home/ros2/桌面/install/fishbot_cartographer', '/opt/ros/humble']"
        zxy
        微信图片_20240529094703.png 如果不管上面那个问题的话这里也有问题
          zxy
            zxy @1209070035
