    ROS1的一键安装用不了
    一键安装 未满足依赖关系
    1.2k
    • K
      kong
      请输入[]内的数字以选择:3
      RUN Choose Task:[请输入括号内的数字]
      请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
      [1]:noetic(ROS1)桌面版
      [2]:noetic(ROS1)基础版(小)
      [0]:quit
      请输入[]内的数字以选择:1
      Run CMD Task:[sudo apt search aptitude ]
      [-]Result:success r Debiandevelopment files)on
      []升级了 0 个软件包,新安装了 0 个软件包, 要卸载 0 个软件包,有 290 个软件包未[-]Result:success
      正在读取软件包列表... 完成
      正在分析软件包的依赖关系树
      正在读取状态信息... 完成
      下列信息可能会对解决问题有所帮助:
      下列软件包有未满足的依赖关系:
      ros-noetic-desktop-full : 依赖: ros-noetic-perception 但是它将不会被安装
      [/] 依赖: ros-noetic-urdf-sim-tutorial 但是它将不会被[-]Result:code:100
      请注意我,检测你在安装过程中出现依赖问题,请在稍后输入n,再选择y,即可解决(若无法解决,清在稍后手动运行命令: sudo aptitude install ros-noetic-desktop-full)
      确认了解情况,请输入回车继续安装
      Run CMD Task:[sudo aptitude install ros-noetic-desktop-full]
      下列“新”软件包将被安装。
      comerr-dev{a} cython3{a} fltk1.3-doc{a} fluid{a} fonts-lato{a}
      fonts-lyx{a} freeglut3{a} freeglut3-dev{a} gazebo11{a} gazebo11-common{a}
      gazebo11-plugin-base{a} gdal-data{a} google-mock{a} googletest{a}
      graphviz{a} hddtemp{a} hdf5-helpers{a} ignition-tools{a}
      javascript-common{a} krb5-multidev{a} libaec-dev{a} libaec0{a} libann0{a}
      libapr1{a} libapr1-dev{a} libaprutil1{a} libaprutil1-dev{a}
      libarmadillo-dev{a} libarmadillo9{a} libarpack2{a} libarpack2-dev{a}
      libassimp-dev{a} libassimp5{a} libassuan-dev{a} libavcodec-dev{a}
      libavdevice-dev{a} libavfilter-dev{a} libavformat-dev{a}
      libavresample-dev{a} libavutil-dev{a} libblas-dev{a} libblas3{a}
      libboost-all-dev{a} libboost-atomic-dev{a} libboost-atomic1.71-dev{a}
      libboost-atomic1.71.0{a} libboost-chrono-dev{a}
      libboost-chrono1.71-dev{a} libboost-chrono1.71.0{a}
      libboost-container-dev{a} libboost-container1.71-dev{a}
      libboost-container1.71.0{a} libboost-context-dev{a}
      libboost-context1.71-dev{a} libboost-context1.71.0{a}
      libboost-coroutine-dev{a} libboost-coroutine1.71-dev{a}
      libboost-coroutine1.71.0{a} libboost-date-time-dev{a}
      libboost-date-time1.71-dev{a} libboost-dev{a} libboost-exception-dev{a}
      libboost-exception1.71-dev{a} libboost-fiber-dev{a}
      libboost-fiber1.71-dev{a} libboost-fiber1.71.0{a}
      libboost-filesystem-dev{a} libboost-filesystem1.71-dev{a}
      libboost-graph-dev{a} libboost-graph-parallel-dev{a}
      libboost-graph-parallel1.71-dev{a} libboost-graph-parallel1.71.0{a}
      libboost-graph1.71-dev{a} libboost-graph1.71.0{a}
      libboost-iostreams-dev{a} libboost-iostreams1.71-dev{a}
      libboost-locale-dev{a} libboost-locale1.71-dev{a} libboost-log-dev{a}
      libboost-log1.71-dev{a} libboost-log1.71.0{a} libboost-math-dev{a}
      libboost-math1.71-dev{a} libboost-math1.71.0{a} libboost-mpi-dev{a}
      libboost-mpi-python-dev{a} libboost-mpi-python1.71-dev{a}
      libboost-mpi-python1.71.0{a} libboost-mpi1.71-dev{a}
      libboost-mpi1.71.0{a} libboost-numpy-dev{a} libboost-numpy1.71-dev{a}
      libboost-numpy1.71.0{a} libboost-program-options-dev{a}
      libboost-program-options1.71-dev{a} libboost-program-options1.71.0{a}
      libboost-python-dev{a} libboost-python1.71-dev{a}
      libboost-python1.71.0{a} libboost-random-dev{a}
      libboost-random1.71-dev{a} libboost-random1.71.0{a} libboost-regex-dev{a}
      libboost-regex1.71-dev{a} libboost-regex1.71.0{a}
      libboost-serialization-dev{a} libboost-serialization1.71-dev{a}
      libboost-serialization1.71.0{a} libboost-stacktrace-dev{a}
      libboost-stacktrace1.71-dev{a} libboost-stacktrace1.71.0{a}
      libboost-system-dev{a} libboost-system1.71-dev{a}
      libboost-system1.71.0{a} libboost-test-dev{a} libboost-test1.71-dev{a}
      libboost-test1.71.0{a} libboost-thread-dev{a} libboost-thread1.71-dev{a}
      libboost-timer-dev{a} libboost-timer1.71-dev{a} libboost-timer1.71.0{a}
      libboost-tools-dev{a} libboost-type-erasure-dev{a}
      libboost-type-erasure1.71-dev{a} libboost-type-erasure1.71.0{a}
      libboost-wave-dev{a} libboost-wave1.71-dev{a} libboost-wave1.71.0{a}
      libboost1.71-dev{a} libboost1.71-tools-dev{a} libbullet-dev{a}
      libbullet2.88{a} libbz2-dev{a} libcaf-openmpi-3{a} libccd-dev{a}
      libccd2{a} libcdt5{a} libcfitsio-dev{a} libcfitsio-doc{a} libcfitsio8{a}
      libcgraph6{a} libcharls-dev{a} libcharls2{a} libcoarrays-openmpi-dev{a}
      libconsole-bridge-dev{a} libconsole-bridge0.4{a} libcurl4-gnutls-dev{ab}
      libcurl4-openssl-dev{ab} libdap-dev{a} libdap25{a} libdapclient6v5{a}
      libdapserver7v5{a} libdart-collision-bullet-dev{a}
      libdart-collision-ode-dev{a} libdart-dev{a}
      libdart-external-ikfast-dev{a} libdart-external-odelcpsolver-dev{a}
      libdart-utils-dev{a} libdart-utils-urdf-dev{a} libdart6{a}
      libdart6-collision-bullet{a} libdart6-collision-ode{a}
      libdart6-external-odelcpsolver{a} libdart6-utils{a}
      libdart6-utils-urdf{a} libdc1394-22-dev{a} libeigen3-dev{a}
      libepsilon-dev{a} libepsilon1{a} libevent-core-2.1-7{a} libevent-dev{a}
      libevent-extra-2.1-7{a} libevent-openssl-2.1-7{a}
      libevent-pthreads-2.1-7{a} libexif-dev{a} libexif-doc{a} libfcl-dev{a}
      libfcl0.5{a} libflann-dev{a} libflann1.9{a} libfltk-cairo1.3{a}
      libfltk-forms1.3{a} libfltk-gl1.3{a} libfltk-images1.3{a} libfltk1.3{a}
      libfltk1.3-dev{a} libfreeimage-dev{a} libfreeimage3{a} libfreexl-dev{a}
      libfreexl1{a} libfyba-dev{a} libfyba0{a} libgazebo11{a}
      libgazebo11-dev{a} libgdal-dev{a} libgdal26{a} libgdcm-dev{a}
      libgdcm3.0{a} libgeos-3.8.0{a} libgeos-c1v5{a} libgeos-dev{a}
      libgeotiff-dev{a} libgeotiff5{a} libgif-dev{a} libgl2ps-dev{a}
      libgl2ps1.4{a} libglew-dev{a} libglew2.1{a} libgpg-error-dev{a}
      libgpgme-dev{a} libgphoto2-dev{a} libgssrpc4{a} libgtest-dev{a}
      libgts-0.7-5{a} libgts-bin{a} libgts-dev{a} libgvc6{a} libgvpr2{a}
      libhdf4-0-alt{a} libhdf4-alt-dev{a} libhdf5-103{a} libhdf5-cpp-103{a}
      libhdf5-dev{a} libhdf5-mpi-dev{a} libhdf5-openmpi-103{a}
      libhdf5-openmpi-dev{a} libhwloc-dev{a} libhwloc-plugins{a} libhwloc15{a}
      libibverbs-dev{a} libignition-cmake2-dev{a} libignition-common3{a}
      libignition-common3-av{a} libignition-common3-av-dev{a}
      libignition-common3-core-dev{a} libignition-common3-dev{a}
      libignition-common3-events{a} libignition-common3-events-dev{a}
      libignition-common3-graphics{a} libignition-common3-graphics-dev{a}
      libignition-common3-profiler{a} libignition-common3-profiler-dev{a}
      libignition-fuel-tools4{a} libignition-fuel-tools4-dev{a}
      libignition-math6{a} libignition-math6-dev{a} libignition-msgs5{a}
      libignition-msgs5-dev{a} libignition-tools-dev{a}
      libignition-transport8{a} libignition-transport8-core-dev{a}
      libignition-transport8-dev{a} libignition-transport8-log{a}
      libignition-transport8-log-dev{a} libilmbase-dev{a} libjbig-dev{a}
      libjpeg-dev{a} libjpeg-turbo8-dev{a} libjpeg8-dev{a} libjs-jquery{a}
      libjs-jquery-ui{a} libjson-c-dev{a} libjsoncpp-dev{a} libjxr0{a}
      libkadm5clnt-mit11{a} libkadm5srv-mit11{a} libkdb5-9{a} libkml-dev{a}
      libkmlbase1{a} libkmlconvenience1{a} libkmldom1{a} libkmlengine1{a}
      libkmlregionator1{a} libkmlxsd1{a} libkrb5-dev{a} liblab-gamut1{a}
      liblapack-dev{a} liblapack3{a} libldap2-dev{a} liblept5{a}
      liblog4cxx-dev{a} liblog4cxx10v5{a} liblz4-dev{a} liblzma-dev{a}
      libminizip-dev{a} libnetcdf-c++4{a} libnetcdf-cxx-legacy-dev{a}
      libnetcdf-dev{a} libnetcdf15{a} libnl-3-dev{a} libnl-route-3-dev{a}
      libnorm-dev{a} libnuma-dev{a} liboctomap-dev{a} liboctomap1.9{a}
      libode-dev{a} libode8{a} libogdi-dev{a} libogdi4.1{a} libogg-dev{a}
      libogre-1.9-dev{a} libogre-1.9.0v5{a} libopencv-calib3d-dev{a}
      libopencv-calib3d4.2{a} libopencv-contrib-dev{a} libopencv-contrib4.2{a}
      libopencv-core-dev{a} libopencv-dev{a} libopencv-dnn-dev{a}
      libopencv-dnn4.2{a} libopencv-features2d-dev{a}
      libopencv-features2d4.2{a} libopencv-flann-dev{a} libopencv-flann4.2{a}
      libopencv-highgui-dev{a} libopencv-highgui4.2{a}
      libopencv-imgcodecs-dev{a} libopencv-imgcodecs4.2{a}
      libopencv-imgproc-dev{a} libopencv-imgproc4.2{a} libopencv-ml-dev{a}
      libopencv-ml4.2{a} libopencv-objdetect-dev{a} libopencv-objdetect4.2{a}
      libopencv-photo-dev{a} libopencv-photo4.2{a} libopencv-shape-dev{a}
      libopencv-shape4.2{a} libopencv-stitching-dev{a}
      libopencv-stitching4.2{a} libopencv-superres-dev{a}
      libopencv-superres4.2{a} libopencv-ts-dev{a} libopencv-video-dev{a}
      libopencv-video4.2{a} libopencv-videoio-dev{a} libopencv-videoio4.2{a}
      libopencv-videostab-dev{a} libopencv-videostab4.2{a} libopencv-viz-dev{a}
      libopencv-viz4.2{a} libopencv4.2-java{a} libopencv4.2-jni{a}
      libopenexr-dev{a} libopenjp2-7-dev{a} libopenmpi-dev{a} libopenmpi3{a}
      libopenni-dev{a} libopenni-sensor-pointclouds0{a} libopenni0{a}
      libopenni2-0{a} libopenni2-dev{a} liborocos-kdl-dev{a}
      liborocos-kdl1.4{a} libpathplan4{a} libpcl-apps1.10{a}
      libpcl-common1.10{a} libpcl-dev{a} libpcl-features1.10{a}
      libpcl-filters1.10{a} libpcl-io1.10{a} libpcl-kdtree1.10{a}
      libpcl-keypoints1.10{a} libpcl-ml1.10{a} libpcl-octree1.10{a}
      libpcl-outofcore1.10{a} libpcl-people1.10{a} libpcl-recognition1.10{a}
      libpcl-registration1.10{a} libpcl-sample-consensus1.10{a}
      libpcl-search1.10{a} libpcl-segmentation1.10{a} libpcl-stereo1.10{a}
      libpcl-surface1.10{a} libpcl-tracking1.10{a} libpcl-visualization1.10{a}
      libpgm-dev{a} libpmix2{a} libpoco-dev{a} libpococrypto62{a}
      libpocodata62{a} libpocodatamysql62{a} libpocodataodbc62{a}
      libpocodatasqlite62{a} libpocoencodings62{a} libpocofoundation62{a}
      libpocojson62{a} libpocomongodb62{a} libpoconet62{a} libpoconetssl62{a}
      libpocoredis62{a} libpocoutil62{a} libpocoxml62{a} libpocozip62{a}
      libpoppler-dev{a} libpoppler-private-dev{a} libpostproc-dev{a}
      libproj-dev{a} libproj15{a} libprotobuf-dev{a} libprotobuf-lite17{a}
      libprotoc-dev{a} libprotoc17{a} libpyside2-dev{a} libpyside2-py3-5.14{a}
      libpython3-dev{a} libpython3.8-dev{a} libqhull-dev{a} libqhull-r7{a}
      libqhull7{a} libqt5webkit5-dev{a} libqwt-qt5-6{a} libqwt-qt5-dev{a}
      libraw1394-dev{a} libraw1394-tools{a} libruby2.7{a} libsctp-dev{a}
      libsctp1{a} libsdformat9{a} libsdformat9-dev{a} libshiboken2-dev{a}
      libshiboken2-py3-5.14{a} libsimbody-dev{a} libsimbody3.6{a}
      libsocket++1{a} libsodium-dev{a} libspatialite-dev{a} libspatialite7{a}
      libspnav0{a} libsuperlu-dev{a} libsuperlu5{a} libswresample-dev{a}
      libswscale-dev{a} libsz2{a} libtar-dev{a} libtar0{a} libtbb-dev{a}
      libtesseract4{a} libtheora-dev{a} libtiff-dev{a} libtiffxx5{a}
      libtinyxml-dev{a} libtinyxml2-6a{a} libtinyxml2-dev{a}
      libtinyxml2.6.2v5{a} liburdfdom-dev{a} liburdfdom-headers-dev{a}
      liburdfdom-model{a} liburdfdom-model-state{a} liburdfdom-sensor{a}
      liburdfdom-world{a} liburiparser-dev{a} liburiparser1{a}
      libusb-1.0-0-dev{a} libusb-1.0-doc{a} libvtk6.3{a} libvtk7-dev{a}
      libvtk7-java{a} libvtk7-jni{a} libvtk7-qt-dev{a} libvtk7.1p{a}
      libvtk7.1p-qt{a} libwebp-dev{a} libxerces-c-dev{a} libxerces-c3.2{a}
      libxml2-dev{a} libxmu-dev{a} libxmu-headers{a} libxnvctrl0{a}
      libxss-dev{a} libxt-dev{a} libyaml-cpp-dev{a} libyaml-cpp0.6{a}
      libyaml-dev{a} libzip-dev{a} libzip5{a} libzmq3-dev{a} libzstd-dev{a}
      libzzip-0-13{a} mpi-default-bin{a} mpi-default-dev{a} opencv-data{a}
      openmpi-bin{a} openmpi-common{a} openni-utils{a} proj-bin{a} proj-data{a}
      protobuf-compiler{a} pyqt5-dev{a} python-matplotlib-data{a}
      python3-attr{a} python3-autobahn{a} python3-automat{a}
      python3-catkin-pkg{a} python3-cbor{a} python3-constantly{a}
      python3-cycler{a} python3-defusedxml{a} python3-dev{a} python3-empy{a}
      python3-gnupg{a} python3-hamcrest{a} python3-hyperlink{a}
      python3-incremental{a} python3-kiwisolver{a} python3-lz4{a}
      python3-matplotlib{a} python3-mpi4py{a} python3-nose{a} python3-numpy{a}
      python3-opencv{a} python3-opengl{a} python3-png{a} python3-psutil{a}
      python3-pyasn1{a} python3-pyasn1-modules{a} python3-pycryptodome{a}
      python3-pydot{a} python3-pykdl{a} python3-pyqrcode{a} python3-pyqt5{a}
      python3-pyqt5.qtopengl{a} python3-pyqt5.qtsvg{a}
      python3-pyqt5.qtwebkit{a} python3-pyside2.qtcore{a}
      python3-pyside2.qtgui{a} python3-pyside2.qtsvg{a}
      python3-pyside2.qtwidgets{a} python3-rospkg{a}
      python3-service-identity{a} python3-sip{a} python3-sip-dev{a}
      python3-snappy{a} python3-trie{a} python3-twisted{a}
      python3-twisted-bin{a} python3-txaio{a} python3-u-msgpack{a}
      python3-ubjson{a} python3-vtk7{a} python3-wsaccel{a}
      python3-zope.interface{a} python3.8-dev{a} qttools5-dev{a}
      qttools5-private-dev{a} rake{a} ros-noetic-actionlib{a}
      ros-noetic-actionlib-msgs{a} ros-noetic-actionlib-tutorials{a}
      ros-noetic-angles{a} ros-noetic-bond{a} ros-noetic-bond-core{a}
      ros-noetic-bondcpp{a} ros-noetic-bondpy{a}
      ros-noetic-camera-calibration{a} ros-noetic-camera-calibration-parsers{a}
      ros-noetic-camera-info-manager{a} ros-noetic-catkin{a}
      ros-noetic-class-loader{a} ros-noetic-cmake-modules{a}
      ros-noetic-common-msgs{a} ros-noetic-common-tutorials{a}
      ros-noetic-compressed-depth-image-transport{a}
      ros-noetic-compressed-image-transport{a} ros-noetic-control-msgs{a}
      ros-noetic-control-toolbox{a} ros-noetic-controller-interface{a}
      ros-noetic-controller-manager{a} ros-noetic-controller-manager-msgs{a}
      ros-noetic-cpp-common{a} ros-noetic-cv-bridge{a}
      ros-noetic-depth-image-proc{a} ros-noetic-desktop{a}
      ros-noetic-desktop-full ros-noetic-diagnostic-aggregator{a}
      ros-noetic-diagnostic-analysis{a}
      ros-noetic-diagnostic-common-diagnostics{a} ros-noetic-diagnostic-msgs{a}
      ros-noetic-diagnostic-updater{a} ros-noetic-diagnostics{a}
      ros-noetic-diff-drive-controller{a} ros-noetic-dynamic-reconfigure{a}
      ros-noetic-eigen-conversions{a} ros-noetic-executive-smach{a}
      ros-noetic-filters{a} ros-noetic-forward-command-controller{a}
      ros-noetic-gazebo-dev{a} ros-noetic-gazebo-msgs{a}
      ros-noetic-gazebo-plugins{a} ros-noetic-gazebo-ros{a}
      ros-noetic-gazebo-ros-control{a} ros-noetic-gazebo-ros-pkgs{a}
      ros-noetic-gencpp{a} ros-noetic-geneus{a} ros-noetic-genlisp{a}
      ros-noetic-genmsg{a} ros-noetic-gennodejs{a} ros-noetic-genpy{a}
      ros-noetic-geometry{a} ros-noetic-geometry-msgs{a}
      ros-noetic-geometry-tutorials{a} ros-noetic-gl-dependency{a}
      ros-noetic-hardware-interface{a} ros-noetic-image-common{a}
      ros-noetic-image-geometry{a} ros-noetic-image-pipeline{a}
      ros-noetic-image-proc{a} ros-noetic-image-publisher{a}
      ros-noetic-image-rotate{a} ros-noetic-image-transport{a}
      ros-noetic-image-transport-plugins{a} ros-noetic-image-view{a}
      ros-noetic-interactive-marker-tutorials{a}
      ros-noetic-interactive-markers{a} ros-noetic-joint-limits-interface{a}
      ros-noetic-joint-state-controller{a} ros-noetic-joint-state-publisher{a}
      ros-noetic-joint-state-publisher-gui{a} ros-noetic-kdl-conversions{a}
      ros-noetic-kdl-parser{a} ros-noetic-laser-assembler{a}
      ros-noetic-laser-filters{a} ros-noetic-laser-geometry{a}
      ros-noetic-laser-pipeline{a} ros-noetic-librviz-tutorial{a}
      ros-noetic-map-msgs{a} ros-noetic-media-export{a}
      ros-noetic-message-filters{a} ros-noetic-message-generation{a}
      ros-noetic-message-runtime{a} ros-noetic-mk{a} ros-noetic-nav-msgs{a}
      ros-noetic-nodelet{a} ros-noetic-nodelet-core{a}
      ros-noetic-nodelet-topic-tools{a} ros-noetic-nodelet-tutorial-math{a}
      ros-noetic-pcl-conversions{a} ros-noetic-pcl-msgs{a}
      ros-noetic-pcl-ros{a} ros-noetic-perception{a}
      ros-noetic-perception-pcl{a} ros-noetic-pluginlib{a}
      ros-noetic-pluginlib-tutorials{a} ros-noetic-polled-camera{a}
      ros-noetic-position-controllers{a} ros-noetic-python-qt-binding{a}
      ros-noetic-qt-dotgraph{a} ros-noetic-qt-gui{a} ros-noetic-qt-gui-cpp{a}
      ros-noetic-qt-gui-py-common{a} ros-noetic-qwt-dependency{a}
      ros-noetic-realtime-tools{a} ros-noetic-resource-retriever{a}
      ros-noetic-robot{a} ros-noetic-robot-state-publisher{a} ros-noetic-ros{a}
      ros-noetic-ros-base{a} ros-noetic-ros-comm{a} ros-noetic-ros-core{a}
      ros-noetic-ros-environment{a} ros-noetic-ros-tutorials{a}
      ros-noetic-rosbag{a} ros-noetic-rosbag-migration-rule{a}
      ros-noetic-rosbag-storage{a} ros-noetic-rosbash{a}
      ros-noetic-rosboost-cfg{a} ros-noetic-rosbuild{a} ros-noetic-rosclean{a}
      ros-noetic-rosconsole{a} ros-noetic-rosconsole-bridge{a}
      ros-noetic-roscpp{a} ros-noetic-roscpp-core{a}
      ros-noetic-roscpp-serialization{a} ros-noetic-roscpp-traits{a}
      ros-noetic-roscpp-tutorials{a} ros-noetic-roscreate{a}
      ros-noetic-rosgraph{a} ros-noetic-rosgraph-msgs{a} ros-noetic-roslang{a}
      ros-noetic-roslaunch{a} ros-noetic-roslib{a} ros-noetic-roslint{a}
      ros-noetic-roslisp{a} ros-noetic-roslz4{a} ros-noetic-rosmake{a}
      ros-noetic-rosmaster{a} ros-noetic-rosmsg{a} ros-noetic-rosnode{a}
      ros-noetic-rosout{a} ros-noetic-rospack{a} ros-noetic-rosparam{a}
      ros-noetic-rospy{a} ros-noetic-rospy-tutorials{a}
      ros-noetic-rosservice{a} ros-noetic-rostest{a} ros-noetic-rostime{a}
      ros-noetic-rostopic{a} ros-noetic-rosunit{a} ros-noetic-roswtf{a}
      ros-noetic-rqt-action{a} ros-noetic-rqt-bag{a}
      ros-noetic-rqt-bag-plugins{a} ros-noetic-rqt-common-plugins{a}
      ros-noetic-rqt-console{a} ros-noetic-rqt-dep{a} ros-noetic-rqt-graph{a}
      ros-noetic-rqt-gui{a} ros-noetic-rqt-gui-cpp{a} ros-noetic-rqt-gui-py{a}
      ros-noetic-rqt-image-view{a} ros-noetic-rqt-launch{a}
      ros-noetic-rqt-logger-level{a} ros-noetic-rqt-moveit{a}
      ros-noetic-rqt-msg{a} ros-noetic-rqt-nav-view{a} ros-noetic-rqt-plot{a}
      ros-noetic-rqt-pose-view{a} ros-noetic-rqt-publisher{a}
      ros-noetic-rqt-py-common{a} ros-noetic-rqt-py-console{a}
      ros-noetic-rqt-reconfigure{a} ros-noetic-rqt-robot-dashboard{a}
      ros-noetic-rqt-robot-monitor{a} ros-noetic-rqt-robot-plugins{a}
      ros-noetic-rqt-robot-steering{a} ros-noetic-rqt-runtime-monitor{a}
      ros-noetic-rqt-rviz{a} ros-noetic-rqt-service-caller{a}
      ros-noetic-rqt-shell{a} ros-noetic-rqt-srv{a} ros-noetic-rqt-tf-tree{a}
      ros-noetic-rqt-top{a} ros-noetic-rqt-topic{a} ros-noetic-rqt-web{a}
      ros-noetic-rviz{a} ros-noetic-rviz-plugin-tutorials{a}
      ros-noetic-rviz-python-tutorial{a} ros-noetic-self-test{a}
      ros-noetic-sensor-msgs{a} ros-noetic-shape-msgs{a}
      ros-noetic-simulators{a} ros-noetic-smach{a} ros-noetic-smach-msgs{a}
      ros-noetic-smach-ros{a} ros-noetic-smclib{a} ros-noetic-stage{a}
      ros-noetic-stage-ros{a} ros-noetic-std-msgs{a} ros-noetic-std-srvs{a}
      ros-noetic-stereo-image-proc{a} ros-noetic-stereo-msgs{a}
      ros-noetic-tf{a} ros-noetic-tf-conversions{a} ros-noetic-tf2{a}
      ros-noetic-tf2-eigen{a} ros-noetic-tf2-geometry-msgs{a}
      ros-noetic-tf2-kdl{a} ros-noetic-tf2-msgs{a} ros-noetic-tf2-py{a}
      ros-noetic-tf2-ros{a} ros-noetic-theora-image-transport{a}
      ros-noetic-topic-tools{a} ros-noetic-trajectory-msgs{a}
      ros-noetic-transmission-interface{a} ros-noetic-turtle-actionlib{a}
      ros-noetic-turtle-tf{a} ros-noetic-turtle-tf2{a} ros-noetic-turtlesim{a}
      ros-noetic-urdf{a} ros-noetic-urdf-parser-plugin{a}
      ros-noetic-urdf-sim-tutorial{a} ros-noetic-urdf-tutorial{a}
      ros-noetic-vision-opencv{a} ros-noetic-visualization-marker-tutorials{a}
      ros-noetic-visualization-msgs{a} ros-noetic-visualization-tutorials{a}
      ros-noetic-viz{a} ros-noetic-webkit-dependency{a} ros-noetic-xacro{a}
      ros-noetic-xmlrpcpp{a} ruby{a} ruby-minitest{a} ruby-net-telnet{a}
      ruby-power-assert{a} ruby-test-unit{a} ruby-xmlrpc{a} ruby2.7{a}
      rubygems-integration{a} sbcl{a} sdformat9-sdf{a} shiboken2{a} sip-dev{a}
      tcl{a} tcl-dev{a} tcl-vtk7{a} tcl8.6-dev{a} tk{a} tk-dev{a} tk8.6-dev{a}
      ttf-dejavu-core{a} vtk7{a} x11proto-scrnsaver-dev{a}
      0 个软件包被升级,新安装 803 个,0 个将被删除, 同时 290 个将不升级。
      需要获取 365 MB 的存档。解包后将要使用 2,028 MB。
      下列软件包存在未满足的依赖关系:
      libcurl4-gnutls-dev : 依赖: libcurl3-gnutls (= 7.68.0-1ubuntu2.23) 但是 7.68.1-1ubuntu2.18 已安装
      冲突: libcurl4-openssl-dev 但是 7.68.0-1ubuntu2.23 将被安装
      libcurl4-openssl-dev : 依赖: libcurl4 (= 7.68.0-1ubuntu2.23) 但是 7.68.1-1ubuntu2.18 已安装
      冲突: libcurl4-gnutls-dev 但是 7.68.0-1ubuntu2.23 将被安装
      下列动作将解决这些依赖关系:
        安装 下列软件包:
      1.  libcurl3-nss [7.68.0-1ubuntu2.23 (focal-security, focal-updates)]
      2.  libcurl4-nss-dev [7.68.0-1ubuntu2.23 (focal-security, focal-updates)]
        保持 下列软件包于其当前版本:
      3.  libcurl4-gnutls-dev [未安装的]
      4.  libcurl4-openssl-dev [未安装的]
      5.  libgazebo11-dev [未安装的]
      6.  libignition-fuel-tools4-dev [未安装的]
      7.  ros-noetic-desktop-full [未安装的]
      8.  ros-noetic-gazebo-dev [未安装的]
      9.  ros-noetic-gazebo-plugins [未安装的]
      10. ros-noetic-gazebo-ros [未安装的]
      11. ros-noetic-gazebo-ros-control [未安装的]
      12. ros-noetic-gazebo-ros-pkgs [未安装的]
      13. ros-noetic-simulators [未安装的]
      14. ros-noetic-urdf-sim-tutorial [未安装的]
      是否接受该解决方案?[Y/n/q/?] n
      下列动作将解决这些依赖关系:
        保持 下列软件包于其当前版本:
      1.  libcurl4-gnutls-dev [未安装的]
      2.  libcurl4-openssl-dev [未安装的]
      3.  libdap-dev [未安装的]
      4.  libgazebo11-dev [未安装的]
      5.  libgdal-dev [未安装的]
      6.  libhdf4-alt-dev [未安装的]
      7.  libignition-fuel-tools4-dev [未安装的]
      8.  libnetcdf-cxx-legacy-dev [未安装的]
      9.  libnetcdf-dev [未安装的]
      10. libpcl-dev [未安装的]
      11. libvtk7-dev [未安装的]
      12. libvtk7-qt-dev [未安装的]
      13. ros-noetic-desktop-full [未安装的]
      14. ros-noetic-gazebo-dev [未安装的]
      15. ros-noetic-gazebo-plugins [未安装的]
      16. ros-noetic-gazebo-ros [未安装的]
      17. ros-noetic-gazebo-ros-control [未安装的]
      18. ros-noetic-gazebo-ros-pkgs [未安装的]
      19. ros-noetic-pcl-conversions [未安装的]
      20. ros-noetic-pcl-ros [未安装的]
      21. ros-noetic-perception [未安装的]
      22. ros-noetic-perception-pcl [未安装的]
      23. ros-noetic-simulators [未安装的]
      24. ros-noetic-urdf-sim-tutorial [未安装的]
      是否接受该解决方案?[Y/n/q/?] y
      将不会安装,升级或者删除任何软件包。
      0 个软件包被升级,新安装 0 个,0 个将被删除, 同时 290 个将不升级。
      需要获取 0 B 的存档。解包后将要使用 0 B。
      Run CMD Task:[sudo aptitude install ros-noetic-desktop-full -y]
      libcurl4-openssl-dev : 依赖: libcurl4 (= 7.68.0-1ubuntu2.23) 但是 7.68.1-1ub[/] 冲突: libcurl4-gnutls-dev 但是 7.68.0-1ubuntu2.23 将[-]Result:success 除, 同时 290 个将不升级。
      Run CMD Task:[sudo apt search python3-catkin-tools ]
      [-]Result:success kin.all [已安装]
      [-]Result:success for Robot OS (Python 3)]
      [-]Result:code:2
        小鱼 技术大佬 @kong
        @kong 依赖冲突,依次尝试
        y
        n,y
        n,n,y
        n,n,n,y
        n,n,n,n,y
        n,..............n,y
