    robot_localization包调用失败
    机械臂运动规划
    ros2 humble 定位
    2.1k
    • tzhT
      tzh
      运行环境: Ubuntu 22.04
      ROS版本: ros2 humble
      出错情况描述: 只使用IMU数据作为robot_localization的输入,启动节点后无报错,但/odometry/filtered话题无输出,也不存在odom->base_link的tf转换。
      robot_localization的配置文件如下:
      ### ekf config file ###
      ekf_filter_node:
          ros__parameters:
              frequency: 30.0
              two_d_mode: false
              publish_acceleration: true
              publish_tf: true
              map_frame: map              # 如果未指定,默认为"map"
              odom_frame: odom            # 如果未指定,默认为"odom"
              base_link_frame: base_link  # 如果未指定,默认为"base_link"
              world_frame: odom           # 如果未指定,默认为odom_frame的值
              imu0: /imu
              imu0_config: [false, false, false,
                            true,  true,  true,
                            true,  true,  true,
                            true,  true,  true]
      robot_localization的launch文件如下:
      import os
      from launch.actions import DeclareLaunchArgument, IncludeLaunchDescription
          imu_tf = Node(
              name='imu_tf',
              package='tf2_ros',
              executable='static_transform_publisher',
              arguments=['0.0', '0.0', '0.0', '0', '0',
                         '0', '1', 'base_link', 'imu']
          imu = IncludeLaunchDescription(
              PythonLaunchDescriptionSource([os.path.join(
                  get_package_share_directory('imu_driver'), 'launch'),
                  '/imu_driver.launch.py']),
          localization = Node(
              package='robot_localization',
              executable='ekf_node',
              name='robot_localization',
              parameters=[
                  "/home/tzh/Projects/it_ws/src/navigation/launch/localization.config.yaml"],
              output='screen'
          return LaunchDescription([
              imu,
              imu_tf,
              localization
      运行robot_localization的launch文件后控制台输出如下:
      [INFO] [launch]: All log files can be found below /home/tzh/.ros/log/2024-10-31-10-23-00-921171-tzh-pc-64155
      [INFO] [witmotion_ros_node-1]: process started with pid [64156]
      [INFO] [static_transform_publisher-2]: process started with pid [64158]
      [INFO] [ekf_node-3]: process started with pid [64160]
      [static_transform_publisher-2] [WARN] [1730341381.030685183] []: Old-style arguments are deprecated; see --help for new-style arguments
      [static_transform_publisher-2] [INFO] [1730341381.056635045] [imu_tf]: Spinning until stopped - publishing transform
      [static_transform_publisher-2] translation: ('0.000000', '0.000000', '0.000000')
      [static_transform_publisher-2] from 'base_link' to 'imu'
      [witmotion_ros_node-1] [INFO] [1730341381.057299339] [witmotion]: Starting node with lib version (1.2.28~dev_1cfcd85).
      [witmotion_ros_node-1] [INFO] [1730341381.057468826] [ROSWitmotionSensorController]: Controller started
      [witmotion_ros_node-1] [INFO] [1730341381.057618467] [MinimalPublisher]: QT spin !!!!!
      /imu话题的输出节选如下:
      header:
        stamp:
          sec: 1730341404
          nanosec: 365809160
        frame_id: imu
      orientation:
        x: -0.022146457388615474
        y: -0.0021896924432268476
        z: -0.0007197822277023602
        w: 0.9997520800606935
      orientation_covariance:
      - 0.0479
      - 0.0
      - 0.0
      - 0.0
      - 0.0207
      - 0.0
      - 0.0
      - 0.0
      - 0.0041
      angular_velocity:
        x: 0.0
        y: 0.0
        z: 0.0
      angular_velocity_covariance:
      - 0.0663
      - 0.0
      - 0.0
      - 0.0
      - 0.1453
      - 0.0
      - 0.0
      - 0.0
      - 0.0378
      linear_acceleration:
        x: 0.043110352009534836
        y: -0.43110352754592896
        z: 9.747729301452637
      linear_acceleration_covariance:
      - 0.0364
      - 0.0
      - 0.0
      - 0.0
      - 0.0048
      - 0.0
      - 0.0
      - 0.0
      - 0.0796
        从你提供的信息来看,你已经正确配置了robot_localization的EKF(扩展卡尔曼滤波器)节点,并且IMU数据也在正常发布。然而,/odometry/filtered话题没有输出,同时也没有odom -> base_link的tf转换,这通常意味着EKF节点没有成功接收到有效的输入数据或者配置有误。以下是一些可能的解决步骤和检查点:
        1. 检查IMU数据格式:
          • 确保/imu话题发布的IMU数据格式与robot_localization期望的格式一致。特别是orientation、angular_velocity和linear_acceleration的协方差矩阵需要正确设置。
          • 协方差矩阵的对角线元素通常表示测量噪声的不确定性,而非对角线元素通常设置为0。检查你的IMU驱动是否正确地设置了这些值。
        2. 检查IMU的tf变换:
          • 你已经使用static_transform_publisher为imu和base_link之间创建了一个静态变换。然而,通常IMU应该直接固定在机器人上,并且其tf变换应该是动态的(通过IMU驱动发布)。如果IMU驱动本身不发布tf变换,你可能需要修改IMU驱动或者继续使用static_transform_publisher(尽管这通常不是最佳实践)。
          • 确认static_transform_publisher是否确实在运行,并且没有错误。
        3. 检查EKF配置:
          • 你的EKF配置文件中,imu0_config数组设置了哪些数据是有效的。根据你提供的配置,看起来你已经启用了所有相关的IMU数据(角速度、线加速度和四元数)。
          • 确保frequency参数与IMU数据的发布频率相匹配或稍高。
        4. 检查日志输出:
          • 查看EKF节点的日志输出,看是否有任何错误或警告信息。这可以通过ROS2的日志系统或使用ros2 node info和ros2 topic list等命令来完成。
          • 特别是检查是否有关于数据订阅或tf变换的错误。
        5. 测试IMU数据:
          • 尝试使用ros2 topic echo /imu来实时查看IMU数据,确保数据在持续发布且格式正确。
          • 你可以尝试使用其他IMU数据生成器或模拟器来测试EKF节点,以排除IMU硬件或驱动的问题。
        6. 检查ROS2环境:
          • 确保你的ROS2环境设置正确,所有依赖包都已正确安装。
          • 尝试在一个干净的ROS2工作空间中重新构建和部署robot_localization和IMU驱动。
        7. 使用调试工具:
          • 使用ros2 topic list -v查看所有话题的详细信息,包括发布者和订阅者。
          • 使用ros2 node info /ekf_node查看EKF节点的详细信息,包括它订阅了哪些话题。
        如果以上步骤都不能解决问题,你可能需要更深入地检查robot_localization的源代码或寻求社区的帮助。在ROS2社区论坛或GitHub仓库中提问时,提供完整的配置文件、日志输出和任何相关的代码片段将有助于他人更快地诊断问题。
        • tzhT
          tzh
          问题已解决!
          原因是配置文件的节点名称和launch文件的节点名称没对上,launch文件中节点名称是robot_localization,而配置文件中是ekf_filter_node,导致配置文件没有生效,所以节点没订阅上/imu话题,导致/odometry/filtered话题无输出。
          1 条回复 最后回复 回复 引用 1
