    在Debian Bullseye(11)ARM上安装ros2-humble
    ros2 debian11
    988
    • 31782613053
      ᯤ⁹⁹ᴳ⁺
      在进行安装ros2时出现个别依赖找不到的问题,一直解决不了,求帮助。
      安装ros2:
      1.准备环境
      1. 更新系统:
        sudo apt update
        sudo apt upgrade
      2. 安装依赖:
        首先,安装一些必需的工具和库:
        sudo apt install -y build-essential cmake git wget curl lsb-release gnupg2
      3. 安装其他依赖:
        sudo apt install -y python3-colcon-common-extensions python3-rosdep python3-pip
        sudo apt install -y python3-setuptools python3-vcstool
      4. 初始化rosdep:
        sudo rosdep init
        rosdep update
      2.下载ROS 2源码
      1. 创建工作空间:
        mkdir -p ~/ros2_humble_ws/src
        cd ~/ros2_humble_ws/src
      2. 克隆ROS 2 Humble源码:
        git clone https://github.com/ros2/ros2.git -b humble
      3. 获取依赖:
        进入工作空间的根目录,然后使用vcstool获取依赖:
        cd ~/ros2_humble_ws
        vcs import src < src/ros2/ros2.repos
      3.安装依赖库
      1. 使用rosdep安装依赖:
        rosdep install -y --from-paths src --ignore-src --rosdistro humble
      ​ 缺少:
      ​ ign_math ,urdfdom_headers , rti-connext-dds-6.0.1
      出现以下报错:
      orangepi@orangepi5:~/ros2_ws$ rosdep install -y --from-paths src --ignore-src --rosdistro humble
      to system dependencies:
      kdl_parser: No definition of [urdfdom_headers] for OS [debian]
      ignition_cmake2_vendor: No definition of [ignition-cmake2] for OS version [bullseye]
      ignition_math6_vendor: No definition of [ignition-math6] for OS version [bullseye]
      urdf_parser_plugin: No definition of [urdfdom_headers] for OS [debian]
      rti_connext_dds_cmake_module: No definition of [rti-connext-dds-6.0.1] for OS [debian]
      urdf: No definition of [urdfdom_headers] for OS [debian]
      urdfdom: No definition of [urdfdom_headers] for OS [debian]
      之后进行以下尝试仍未解决问题:
      git clone https://github.com/ros/urdfdom_headers.git
      cd urdfdom_headers
      mkdir build
      cd build
      cmake ..
      make -j4
      sudo make install
      git clone https://github.com/gazebosim/sdformat_ignition_cmake2.git
      cd sdformat_ignition_cmake2
      mkdir build
      cd build
      cmake ..
      make -j4
      sudo make install
      #sdformat_ignition_cmake2找不到,所以下载gz-math6
      git clone https://github.com/gazebosim/gz-math6.git
      cd gz-math6
      mkdir build
      cd build
      cmake ..
      make -j4
      sudo make install
      但是仍然没有解决这个问题,希望可以或者一些帮助。
        在Debian Bullseye(11)ARM上安装ROS 2 Humble时遇到依赖问题,特别是在处理ign_math, urdfdom_headers, 和 rti-connext-dds-6.0.1时,确实可能比较复杂。下面是一些可能的解决步骤和建议:
        1. 解决 urdfdom_headers 的问题
        urdfdom_headers 是URDF(统一机器人描述格式)的一部分,通常通过ROS的官方仓库提供。但是,如果rosdep找不到它,你可以尝试直接从ROS 2的源仓库安装整个urdfdom包。
        1. 添加ROS 2官方Debian仓库(如果还没有添加的话):
          按照ROS 2官方文档中的说明,添加ROS 2的Debian仓库到你的系统。这一步通常涉及编辑/etc/apt/sources.list或添加一个新的.list文件到/etc/apt/sources.list.d/目录。
        2. 安装urdfdom和相关包:
          sudo apt update
          sudo apt install ros-humble-urdfdom
          这将安装urdfdom及其头文件。
        2. 解决 ign_math 的问题
        ign_math 是Ignition Robotics Library的一部分。对于ROS 2 Humble,Ignition的某些组件可能需要从源代码构建,或者可能需要特定的Debian包。
        1. 尝试从源代码构建:
          你已经尝试从源代码构建gz-math6(Ignition Math 6),但是请确保你使用的是正确的仓库和分支。通常,Ignition的组件会在ign-math仓库中,而不是gz-math6。你可能需要查看Ignition的官方文档或GitHub仓库以获取正确的构建说明。
        2. 使用Ignition的Debian包(如果可用):
          如果Ignition为Debian提供了包,你可以尝试直接从Ignition的Debian仓库安装。这通常涉及添加Ignition的Debian仓库到你的系统并安装所需的包。
        3. 解决 rti-connext-dds-6.0.1 的问题
        rti-connext-dds-6.0.1 是RTI Connext DDS的一个版本,它是一个商业中间件,用于实现数据分发服务(DDS)。
        1. 获取和安装RTI Connext DDS:
          你需要从RTI的官方网站下载并安装RTI Connext DDS。这通常涉及下载一个安装包,然后按照RTI提供的安装指南进行安装。
        2. 配置ROS 2以使用RTI Connext DDS:
          一旦RTI Connext DDS安装完毕,你需要配置ROS 2以使用它作为DDS实现。这通常涉及设置环境变量,如RTI_NCONFIG_PATH,并可能需要在ROS 2的配置文件中指定RTI Connext DDS作为DDS中间件。
        4. 通用建议
        • 确保rosdep是最新的:你已经运行了rosdep update,但请确保你使用的是最新版本的rosdep。
        • 检查网络问题:有时,依赖问题可能是由于网络问题导致的,特别是当你从外部仓库安装软件包时。
        • 查看日志和错误信息:仔细查看构建过程中的日志和错误信息,它们可能会提供关于缺少哪些依赖项或发生了什么的更多线索。
        希望这些步骤能帮助你解决在Debian Bullseye ARM上安装ROS 2 Humble时遇到的问题!如果问题仍然存在,请考虑在ROS社区论坛或相关的GitHub仓库中寻求更具体的帮助。
        31782613053 1 条回复 最后回复 回复 引用 0
        • 31782613053
          ᯤ⁹⁹ᴳ⁺ @小伊
          @小伊 国内国外网络都没有问题,rosdep也是最新的
            在确认国内国外网络都没有问题,且rosdep也是最新版本(例如0.25.1版本)的情况下,如果在使用rosdep时遇到问题,以下是一些可能的解决步骤和建议:
            一、检查rosdep的初始化与更新
            1. 确认初始化与更新的命令:
              • 初始化rosdep:sudo rosdep init
              • 更新rosdep:rosdep update
            2. 检查网络连接:
              • 虽然已确认网络没有问题,但建议再次检查网络连接,确保网络稳定性。
              • 检查是否可以正常访问ROS的官方源或镜像源。
            3. 使用镜像源:
              • 由于网络问题可能导致初始化或更新失败,建议使用国内的镜像源。例如,可以使用清华大学的Tuna镜像源。
              • 设置镜像源的方法可以参考以下步骤:
                • 下载20-default.list文件到/etc/ros/rosdep/sources.list.d/目录:
                  sudo mkdir -p /etc/ros/rosdep/sources.list.d/
                  sudo curl -o /etc/ros/rosdep/sources.list.d/20-default.list https://mirrors.tuna.tsinghua.edu.cn/github-raw/ros/rosdistro/master/rosdep/sources.list.d/20-default.list
                • 设置ROSDISTRO_INDEX_URL环境变量为Tuna镜像源的地址:
                  export ROSDISTRO_INDEX_URL=https://mirrors.tuna.tsinghua.edu.cn/rosdistro/index-v4.yaml
                • 如果希望这个设置永久生效,可以将其添加到~/.bashrc文件中:
                  echo 'export ROSDISTRO_INDEX_URL=https://mirrors.tuna.tsinghua.edu.cn/rosdistro/index-v4.yaml' >> ~/.bashrc
                  source ~/.bashrc
            二、检查Python和pip版本
            • 确保你的Python和pip版本与rosdep兼容。rosdep通常依赖于较新版本的Python和pip。
            • 可以通过运行python --version和pip --version来检查当前版本。
            三、尝试其他解决方案
            • 如果上述方法都不奏效,可以尝试手动下载rosdep所需的文件并手动安装。例如,可以从GitHub上的ROS仓库手动下载rosdep包,并将其内容放到/etc/ros/rosdep/目录下。
            • 也可以考虑使用其他工具或方法,如rosdepc(注意:这是一个非官方工具,使用时请谨慎),它使用的是国内的源,可能有助于解决网络问题。安装和使用rosdepc的方法可以参考相关文档或博客。
            四、查看日志和错误信息
            • 如果rosdep初始化或更新失败,请查看相关日志和错误信息,以便获取更多关于问题的线索。
            • 可以尝试增加日志输出的详细程度,以便更容易地诊断问题。
            五、寻求社区帮助
            • 如果以上方法都无法解决问题,可以考虑在ROS社区论坛或相关博客上寻求帮助。
            • 提供尽可能详细的信息,如rosdep的版本、操作系统信息、错误日志等,以便其他用户或开发者能够更快地帮助你解决问题。
            综上所述,通过检查网络连接、使用镜像源、检查Python和pip版本、尝试其他解决方案以及查看日志和错误信息等方法,通常可以解决rosdep在使用过程中遇到的问题。
            • 31782613053
              ᯤ⁹⁹ᴳ⁺ @3178261305
              目前chatgpt提供的方法,基本都尝试过了
