    四次换源失败 有大佬来看看么 感觉是网络问题但是换了好几个网都是这样
    换源失败 安装ros2
    3.1k
    • M
      Mr_lv
      --2024-08-27 15:41:38-- http://fishros.com/install
      Resolving fishros.com (fishros.com)... 47.119.165.169
      Connecting to fishros.com (fishros.com)|47.119.165.169|:80... connected.
      --2024-08-27 15:41:39-- http://fishros.com/install/
      Length: 387 [application/octet-stream]
      Saving to: ‘fishros’
      fishros 100%[==================================>] 387 --.-KB/s in 0s
      2024-08-27 15:41:39 (5.80 MB/s) - ‘fishros’ saved [387/387]
      Reading package lists... Done
      python3-distro is already the newest version (1.9.0-1).
      python3-yaml is already the newest version (6.0.1-2build2).
      0 upgraded, 0 newly installed, 0 to remove and 18 not upgraded.
      /tmp/fishinstall/install.py:96: SyntaxWarning: invalid escape sequence '.'
      book = tr.tr("""
      --2024-08-27 15:41:41-- http://mirror.fishros.com/install/tools/base.py
      Resolving mirror.fishros.com (mirror.fishros.com)... 47.119.165.169
      Connecting to mirror.fishros.com (mirror.fishros.com)|47.119.165.169|:80... connected.
      Length: 51464 (50K) [application/octet-stream]
      Saving to: ‘/tmp/fishinstall//tools/base.py’
      /tmp/fishinstall//tools/ 100%[==================================>] 50.26K 287KB/s in 0.2s
      2024-08-27 15:41:42 (287 KB/s) - ‘/tmp/fishinstall//tools/base.py’ saved [51464/51464]
      [-][0.01s] CMD Result:success
      Run CMD Task:[wget http://mirror.fishros.com/install/tools/translation/translator.py -O /tmp/fishinstall//tools/translation/translator.py --no-check-certificate]
      [/][0.00s] --2024-08-27 15:41:42-- http://mirror.fishros.com/install/tools/translation/translator.p[-][0.20s] CMD Result:success .
      Run CMD Task:[wget http://mirror.fishros.com/install/tools/translation/assets/zh_CN.py -O /tmp/fishinstall//tools/translation/assets/zh_CN.py --no-check-certificate]
      [/][0.00s] --2024-08-27 15:41:44-- http://mirror.fishros.com/install/tools/translation/assets/zh_CN[-][0.21s] CMD Result:success .
      Run CMD Task:[wget http://mirror.fishros.com/install/tools/translation/assets/en_US.py -O /tmp/fishinstall//tools/translation/assets/en_US.py --no-check-certificate]
      [/][0.00s] --2024-08-27 15:41:45-- http://mirror.fishros.com/install/tools/translation/assets/en_US[-][0.20s] CMD Result:success .
      Run CMD Task:[wget https://fishros.org.cn/forum/topic/1733 -O /tmp/t1733 -q --timeout 10 && rm -rf /tmp/t1733]
      [-][0.00s] CMD Result:code:5
      已为您切换语言至当前所在国家语言:zh_CN
      基础检查通过...
      RUN Choose Task:[请输入括号内的数字]
      ---众多工具,等君来用---
      ROS相关:
      常用软件:
      [6]:一键安装:NodeJS环境
      [7]:一键安装:VsCode开发工具
      [8]:一键安装:Docker
      [10]:一键安装:微信(可以在Linux上使用的微信)
      [14]:一键安装:科学上网代理工具
      [15]:一键安装:QQ for Linux
      配置工具:
      [13]:一键配置:python国内源
      请输入[]内的数字以选择:5
      Run CMD Task:[wget http://mirror.fishros.com/install/tools/tool_config_system_source.py -O /tmp/fishinstall/tools/tool_config_system_source.py --no-check-certificate]
      [/][0.00s] --2024-08-27 15:41:54-- http://mirror.fishros.com/install/tools/tool_config_system_sourc[-][0.23s] CMD Result:success .
      Run CMD Task:[wget http://mirror.fishros.com/install/tools/tool_install_ros.py -O /tmp/fishinstall/tools/tool_install_ros.py --no-check-certificate]
      [-][0.29s] CMD Result:success .
      欢迎使用一键更换系统源,本工具由作者小鱼提供
      请选择换源方式,如果不知道选什么请选2
      [1]:仅更换系统源
      [2]:更换系统源并清理第三方源
      0:quit
      请输入[]内的数字以选择:2
      [-][0.00s] CMD Result:success
      删除一个资源文件
      检测到当前系统:ubuntu 架构:arm64 代号:noble,正在为你搜索适合的源...
      搜索到可用源:['https://ports.ubuntu.com/ubuntu-ports', 'https://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports', 'https://ports.ubuntu.com/ubuntu-ports', 'https://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports', 'http://ports.ubuntu.com/ubuntu-ports', 'http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports', 'http://ports.ubuntu.com/ubuntu-ports', 'http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports']
      接下来将进行自动测速以为您选择最快的源:
      • https://ports.ubuntu.com/ubuntu-ports 超时
      • https://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports 超时
      • http://ports.ubuntu.com/ubuntu-ports 超时
      • http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports 超时
        为您选择最快镜像源:https://ports.ubuntu.com/ubuntu-ports
        创建文件:/etc/apt/sources.list
        替换镜像源完成,尝试进行更新....
        [][37.85s] Could not connect to ports.ubuntu.com:443 (::). - connect (111: Connection refused) Co[-][40.99s] CMD Result:success
      搞定了,不信你看,累死宝宝了,还不快去给小鱼点个赞~
      ['Ign:1 https://ports.ubuntu.com/ubuntu-ports noble InRelease', 'Ign:2 https://ports.ubuntu.com/ubuntu-ports noble-updates InRelease', 'Ign:3 https://ports.ubuntu.com/ubuntu-ports noble-backports InRelease', 'Ign:4 https://ports.ubuntu.com/ubuntu-ports noble-security InRelease', 'Ign:1 https://ports.ubuntu.com/ubuntu-ports noble InRelease', 'Ign:2 https://ports.ubuntu.com/ubuntu-ports noble-updates InRelease', 'Ign:3 https://ports.ubuntu.com/ubuntu-ports noble-backports InRelease', 'Ign:4 https://ports.ubuntu.com/ubuntu-ports noble-security InRelease', 'Ign:1 https://ports.ubuntu.com/ubuntu-ports noble InRelease', 'Ign:2 https://ports.ubuntu.com/ubuntu-ports noble-updates InRelease', 'Ign:3 https://ports.ubuntu.com/ubuntu-ports noble-backports InRelease', 'Ign:4 https://ports.ubuntu.com/ubuntu-ports noble-security InRelease', 'Err:1 https://ports.ubuntu.com/ubuntu-ports noble InRelease', ' Could not connect to ports.ubuntu.com:443 (::). - connect (111: Connection refused) Could not connect to ports.ubuntu.com:443 (124.236.16.201), connection timed out', 'Err:2 https://ports.ubuntu.com/ubuntu-ports noble-updates InRelease', ' Unable to connect to ports.ubuntu.com:https:', 'Err:3 https://ports.ubuntu.com/ubuntu-ports noble-backports InRelease', ' Unable to connect to ports.ubuntu.com:https:', 'Err:4 https://ports.ubuntu.com/ubuntu-ports noble-security InRelease', ' Unable to connect to ports.ubuntu.com:https:', 'Reading package lists...', 'Building dependency tree...', 'Reading state information...', "18 packages can be upgraded. Run 'apt list --upgradable' to see them."]
      镜像更新完成.....
      请问是否添加ROS和ROS2源?
      [1]:添加ROS/ROS2源
      [2]:不添加ROS/ROS2源
      0:quit
      请输入[]内的数字以选择:1
      小鱼:检测当前系统ubuntu24.04:noble 支持一键安装ROS
      ============正在添加ROS源密钥=================
      [][37.85s] Could not connect to ports.ubuntu.com:443 (::). - connect (111: Connection refused) Co[-][40.97s] CMD Result:success
      Run CMD Task:[sudo apt search curl ]
      [-][2.25s] CMD Result:success x"
      [-][2.10s] CMD Result:success
      Run CMD Task:[sudo apt search gnupg2 ]
      [-][2.13s] CMD Result:success
      [/][32.76s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[][32.76s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[][32.78s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[][32.89s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[][32.99s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[][33.09s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[][33.19s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[][33.29s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[][33.39s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[][33.49s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[][33.59s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[][33.69s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[|][33.76s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[|][33.79s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[|][33.89s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[|][33.99s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[|][34.09s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[|][34.19s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[|][34.29s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[|][34.39s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[|][34.49s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[|][34.59s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[|][34.69s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[|][34.79s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[|][34.89s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[|][34.99s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[|][35.09s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[|][35.19s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[|][35.29s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[|][35.39s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[|][35.49s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[|][35.59s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[|][35.69s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][35.77s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][35.79s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][35.89s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][35.99s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][36.09s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][36.19s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][36.29s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][36.39s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][36.49s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][36.59s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][36.70s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][36.80s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][36.90s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][37.00s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][37.10s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][37.20s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][37.30s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][37.40s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][37.50s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][37.60s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][37.70s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][37.80s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][37.90s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][38.00s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][38.10s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][38.20s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][38.30s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][38.40s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][38.50s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][38.60s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][38.70s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][38.80s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][38.90s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][39.00s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][39.10s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][39.20s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][39.30s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][39.40s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][39.50s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][39.60s] Ign:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[-][39.70s] Err:1 https://ports.ubuntu.com/ubuntu-ports noble/universe arm64 gnupg2 all 2.4.4-2ubunt[/][39.77s] Could not connect to ports.ubuntu.com:443 (::). - connect (111: Connection refused) Co[][39.77s] Could not connect to ports.ubuntu.com:443 (::). - connect (111: Connection refused) Co[-][39.80s] CMD Result:code:100
      正在挑选最快的密钥服务:['https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc', 'https://raw.githubusercontent.com/ros/rosdistro/master/ros.asc']
      • https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc 延时:0.52s
      • https://raw.githubusercontent.com/ros/rosdistro/master/ros.asc 超时
        已自动选择最快密钥服务:https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc
        [][0.90s] Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-ke[-][0.95s] CMD Result:success
      Run CMD Task:[curl -s https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc | sudo gpg --no-default-keyring --keyring gnupg-ring:/etc/apt/trusted.gpg.d/ros.gpg --import]
      [-][0.45s] CMD Result:success
      Run CMD Task:[sudo chmod 644 /etc/apt/trusted.gpg.d/ros.gpg]
      根据您的系统,为您推荐安装源为['http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu/']
      [|][37.85s] Could not connect to ports.ubuntu.com:443 (::). - connect (111: Connection refused) Co[-][40.41s] CMD Result:code:100
      apt更新失败,后续程序可能会继续尝试...,[]
      Run CMD Task:[sudo apt search ros-base ]
      [-][2.23s] CMD Result:success
      根据您的系统,为您推荐安装源为['https://repo.huaweicloud.com/ros2/ubuntu/']
      换源后更新失败,第三次开始切换源,尝试使用https-ROS官方源~!
      根据您的系统,为您推荐安装源为['https://packages.ros.org/ros2/ubuntu/']
      [/][10.19s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected. Could not handshake: Error in the certificate verification. [IP[][10.19s] Certificate verification failed: The certificate is [IP[][30.68s] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected. Could not handshake: Error in the certificate verification. [IP[|][37.85s] Could not connect to ports.ubuntu.com:443 (::). - connect (111: Connection refused) Co[-][40.97s] CMD Result:success
      [-][2.30s] CMD Result:success
      换源后更新失败,第四次开始切换源,尝试更换ROS源为http-ROS官方源!
      根据您的系统,为您推荐安装源为['http://packages.ros.org/ros2/ubuntu/']
      [|][37.89s] Could not connect to ports.ubuntu.com:443 (::). - connect (111: Connection refused) Co[-][40.51s] CMD Result:code:100
      四次换源后都失败了,请及时联系小鱼获取解决方案并处理!
      M 1 条回复 最后回复 回复 引用 0
        15913820903_ashin @15913820903_ashin
        @15913820903_WCS 在 四次换源失败 有大佬来看看么 感觉是网络问题但是换了好几个网都是这样 中说:
        解决了吗?我目前也遇到这个问题,我感觉又不像网络的问题,因为同样的网线,我在另一款机子上安装是正常的不会跳出换源的问题
        找到原因了,在我sudo apt update也不正常的时候,换了几个源也不行,发现是自身时间问题,系统时间与远程仓库的时间不一致,导致系统认为仓库的Release文件尚未生效。修改自身时间为正确时间就行。
        • M
          Mr_lv @Mr_lv
          最新配置了一个Ubuntu24.04版本的Ubuntu,用在树莓派4B上面
          用小鱼一键换源时,换源失败,不能换源,更换了网络,插上了网线依旧失败
          具体细节和上下文:
          先是使用wget http://fishros.com/install -O fishros && . fishros
          然后选择5一键配置系统源
          之后2 更换系统源并清理第三方源
          尝试过的解决方法:
          换网,插网卡,重烧系统,用实验室网络自己热点都试过 ,虚拟机里用网络就没问题,但是树莓派上就不行
            15913820903_ashin
              • M
                Mr_lv @15913820903_ashin
                @15913820903_WCS 感谢大佬 修改时间后可以了
                • M Mr_lv 将这个主题标记为已解决,在
