    odom->base_footprint的TF转换没有成功
    仿真
    gazebo仿真插件之两轮差速 ros2 humble tf树 小车仿真 机器人控制
    4.7k
    • Y
      yangyy
      基础环境:
      ubuntu 22.04
      ros2-humble
      gazebo-Fortress
      目的:
      我使用gazebo仿真一个四轮小车,差速转向,发布TF的过程中发现odom->base_footprint的转换没有成功,调试了很久,查阅了很多资料,也没有找到具体原因,所以来社区请教。
      使用命令查看TF树:
      查看topic
      /clicked_point
      /clock
      /cmd_vel
      /entropy
      /front_mid_lidar/pc2
      /front_mid_lidar/points
      /front_middle_camera/raw
      /goal_pose
      /imu
      /initialpose
      /joint_states
      /keyboard/keypress
      /map
      /map_metadata
      /odom
      /parameter_events
      /robot_description
      /rosout
      /scan
      /tf
      /tf_static
      查看odom,tf的话题都有数据的输出:
      /tf
      transforms:
      - header:
          stamp:
            sec: 0
            nanosec: 0
          frame_id: map
        child_frame_id: odom
        transform:
          translation:
            x: 0.0
            y: 0.0
            z: 0.0
          rotation:
            x: 0.0
            y: 0.0
            z: 0.0
            w: 1.0
      transforms:
      - header:
          stamp:
            sec: 0
            nanosec: 0
          frame_id: map
        transform:
          translation:
            x: 0.0
            y: 0.0
            z: 0.0
          rotation:
            x: 0.0
            y: 0.0
            z: 0.0
            w: 1.0
      transforms:
      - header:
          stamp:
            sec: 1731555131
            nanosec: 253951340
          frame_id: base_link
        child_frame_id: wheel_front_left
        transform:
          translation:
            x: 0.19999999999999998
            y: 0.225
            z: 0.1
          rotation:
            x: 0.0
            y: 0.0
            z: 0.0
            w: 1.0
      - header:
          stamp:
            sec: 1731555131
            nanosec: 253951340
          frame_id: base_link
        child_frame_id: wheel_front_right
        transform:
          translation:
            y: -0.225
            z: 0.1
          rotation:
            x: 0.0
            y: 0.0
            z: 0.0
            w: 1.0
      - header:
          stamp:
            sec: 1731555131
            nanosec: 253951340
          frame_id: base_link
        child_frame_id: wheel_rear_left
        transform:
          translation:
            x: -0.19999999999999998
            y: 0.225
            z: 0.1
          rotation:
            x: 0.0
            y: 0.0
            z: 0.0
            w: 1.0
      - header:
          stamp:
            sec: 1731555131
            nanosec: 253951340
          frame_id: base_link
        child_frame_id: wheel_rear_right
        transform:
          translation:
            y: -0.225
            z: 0.1
          rotation:
            x: 0.0
            y: 0.0
            z: 0.0
            w: 1.0
      查看odom
      header:
        stamp:
          sec: 1336
          nanosec: 800000000
        frame_id: diff_vehicle_wheel_robot/odom
      child_frame_id: diff_vehicle_wheel_robot/base_footprint
      pose:
        pose:
          position:
            x: 6.147483913270831e-12
            y: 5.126962272481519e-13
            z: 0.0
          orientation:
            x: 0.0
            y: 0.0
            z: 0.45940532564658004
            w: 0.8882267428801949
        covariance:
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
      twist:
        twist:
          linear:
            x: 0.0
            y: 0.0
            z: 0.0
          angular:
            x: 0.0
            y: 0.0
            z: -1.3999999998001538
        covariance:
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
        - 0.0
      代码是launch文件启动,代码如下:
          pkg_four_wheel_robot = get_package_share_directory('four_wheel_robot')
          gz_world_path = PathJoinSubstitution([pkg_four_wheel_robot, 'worlds'])
          gz_sim = IncludeLaunchDescription(
              PythonLaunchDescriptionSource(PathJoinSubstitution([pkg_four_wheel_robot, 'launch', 'gz_sim.launch.py'])),
              launch_arguments={
                  'world': PathJoinSubstitution([gz_world_path, LaunchConfiguration('world')]),
              }.items(),
          # RViz2
          rviz = Node(
              package='rviz2',
              executable='rviz2',
              arguments=['-d', os.path.join(pkg_four_wheel_robot, 'rviz', 'four_wheel_robot.rviz')],
              condition=IfCondition(LaunchConfiguration('rviz'))
          # Bridge
          bridge = Node(
              package='ros_gz_bridge',
              executable='parameter_bridge',
              arguments=['/clock@rosgraph_msgs/msg/Clock@ignition.msgs.Clock',
                          '/imu@sensor_msgs/msg/Imu@ignition.msgs.IMU',
                          '/front_mid_lidar/points@sensor_msgs/msg/LaserScan@gz.msgs.LaserScan',
                          "/front_mid_lidar/pc2@sensor_msgs/msg/PointCloud2@gz.msgs.PointCloudPacked",
                          '/front_middle_camera/raw@sensor_msgs/msg/Image@gz.msgs.Image',
                          '/cmd_vel@geometry_msgs/msg/Twist@ignition.msgs.Twist',
                          '/keyboard/keypress@std_msgs/msg/Int32@ignition.msgs.Int32',
                          # "/odom@nav_msgs/msg/Odometry@gz.msgs.OdometryWithCovariance",
                          "/odom@nav_msgs/msg/Odometry@gz.msgs.Odometry",
                          "/tf@tf2_msgs/msg/TFMessage@gz.msgs.Pose_V",
              parameters=[{'qos_overrides./front_mid_lidar/points.subscriber.reliability': 'reliable',
                           'qos_overrides./front_middle_camera/raw.subscriber.reliability': 'reliable'}],
              output='screen'
          robot_state_pub = Node(
                  arguments=[os.path.join(pkg_four_wheel_robot, 'urdf', 'diff_vehicle_wheel_robot.sdf')],
                  output='screen'
          joint_state_pub = Node(
              package="joint_state_publisher",
              executable="joint_state_publisher"
          return LaunchDescription([
              DeclareLaunchArgument('rviz',
                                  default_value='true',
                                  description='Open RViz'),
              DeclareLaunchArgument('world',
                                  default_value='four_wheel_robot.world',
                                  description='World to load into Gazebo'),
              gz_sim,
              rviz,
              bridge,
              robot_state_pub,
              joint_state_pub
      xacro文件写的小车的模型,差速配置如下:
      <plugin
              filename="ignition-gazebo-diff-drive-system"
              name="ignition::gazebo::systems::DiffDrive">
              <left_joint>wheel_front_left_joint</left_joint>
              <left_joint>wheel_rear_left_joint</left_joint>
              <right_joint>wheel_front_right_joint</right_joint>
              <right_joint>wheel_rear_right_joint</right_joint>
              <wheel_separation>0.45</wheel_separation>
              <wheel_radius>0.1</wheel_radius>
              <robot_namespace>/</robot_namespace>
              <topic>/cmd_vel</topic>
              <enable_odom>true</enable_odom>
              <odom_publish_frequency>10</odom_publish_frequency>
              <odom_frame>odom</odom_frame>
              <odom_topic>/odom</odom_topic>
              <base_frame>base_footprint</base_frame>
              <publish_tf>true</publish_tf>
              <tf_prefix>tf</tf_prefix>
              <broadcast_tf>1</broadcast_tf>
              <!-- <lidar_frame>lidar</lidar_frame>
              <lidar_frame>front_mid_lidar</lidar_frame> -->
          </plugin>
      请问我应该如何更改代码?我查阅资料大家说odom->base_footprint是差速器插件自动转换的,所以没有尝试手动写代码进行转换,我还是比较想弄明白我的代码有什么问题?是哪里没有配置好?
      再次感谢大家的指正!!
        在你的情况中,odom 到 base_footprint 的 TF 转换没有成功,这通常与几个因素有关:
        1. Diff Drive 插件配置:
          • 确保你的 diff drive 插件配置正确,特别是 enable_odom, odom_frame, base_frame, publish_tf, broadcast_tf 等参数。
          • 从你的配置来看,enable_odom 是启用的,odom_frame 设置为 odom,base_frame 设置为 base_footprint,publish_tf 和 broadcast_tf 也都是启用的。这些设置看起来是正确的。
        2. TF 树中的时间戳:
          • 在你提供的 /tf 话题数据中,odom 到 map 的转换时间戳为 0,这可能表示这个转换没有更新。确保 Gazebo 中的定位或 SLAM 节点(如 AMCL 或其他定位算法)正在发布有效的 /odom 数据,并且时间戳是更新的。
          • 同时,base_link 到各个轮子(如 wheel_front_left)的转换有时间戳,这表明这些 TF 是由机器人状态发布者或其他节点正确发布的。
        3. URDF/SDF 文件:
          • 确保你的 URDF/SDF 文件中 base_footprint 和 base_link 之间的关系定义正确。通常,base_footprint 是固定在 base_link 下方的一个点,用于表示机器人的地面接触点。
          • 检查是否有其他 TF 发布者在干扰或覆盖 odom 到 base_footprint 的转换。
        4. 机器人状态发布者:
          • robot_state_publisher 节点是否接收到正确的 joint_states?这个节点负责根据 joint_states 和 URDF/SDF 文件构建 TF 树。
          • 确保 joint_state_publisher 节点正在运行,并且接收到了所有必要的关节状态信息。
        5. 调试步骤:
          • 使用 ros2 topic echo /odom 查看 odom 话题的详细内容,确保它包含了有效的位置和姿态信息。
          • 使用 ros2 topic echo /joint_states 查看关节状态信息,确保所有必要的关节都在发布状态。
          • 检查是否有任何日志或错误信息表明 TF 转换失败或存在冲突。
        6. 代码和环境:
          • 确保你的 ROS 2 环境(包括 Gazebo 插件和 ROS 2 桥接器)都是最新的,并且兼容你使用的 ROS 2 版本(Humble)。
        7. 重新启动和清理:
          • 有时候,重新启动你的 ROS 2 节点和 Gazebo 实例可以解决一些不一致的问题。
          • 确保在每次测试前彻底清理之前的会话和日志,以避免旧数据的干扰。
        如果以上步骤都无法解决问题,你可能需要更深入地检查你的 Gazebo 仿真设置,或者考虑是否有其他软件或配置错误影响了 TF 的发布。希望这些步骤能帮助你找到问题的根源并解决它!
        Y 1 条回复 最后回复 回复 引用 0
        • Y
          yangyy @小伊
          @小伊
          使用命令:ros2 topic echo /joint_states 查看该话题数据如下:
          header:
            stamp:
              sec: 1731556308
              nanosec: 154098513
            frame_id: ''
          name:
          - wheel_front_left_joint
          - wheel_front_right_joint
          - wheel_rear_left_joint
          - wheel_rear_right_joint
          position:
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          velocity: []
          effort: []
            从您提供的 ros2 topic echo /joint_states 命令的输出数据中,我们可以看到 /joint_states 话题包含了机器人关节的状态信息。以下是对该输出数据的详细解释:
            1. header:
              • stamp: 时间戳,表示该数据消息被发布的时间。
                • sec: 秒,从1970年1月1日(UTC)开始的秒数,这里是 1731556308 秒。
                • nanosec: 纳秒,用于提供更精确的时间信息,这里是 154098513 纳秒。
              • frame_id: 坐标系ID,这里为空字符串 '',表示没有指定特定的参考坐标系。
            2. name:
              • 这是一个字符串列表,列出了当前发布状态的所有关节的名称。
              • 关节名称包括:
                • wheel_front_left_joint: 前左轮关节
                • wheel_front_right_joint: 前右轮关节
                • wheel_rear_left_joint: 后左轮关节
                • wheel_rear_right_joint: 后右轮关节
            3. position:
              • 这是一个浮点数列表,表示每个关节的位置(通常是角度或位移,取决于关节类型)。
              • 所有关节的位置都是 0.0,表明这些关节当前都处于其初始或参考位置。
            4. velocity:
              • 这是一个空的浮点数列表,表示没有提供关于关节速度的信息。
              • 这可能是因为当前没有监测或发布关节速度数据。
            5. effort:
              • 这也是一个空的浮点数列表,表示没有提供关于关节所施加的努力(如扭矩或力)的信息。
              • 同样,这可能是因为当前没有监测或发布这类数据。
            总结:
            • /joint_states 话题提供了关于机器人四个轮子关节的位置信息。
            • 所有关节的位置均为 0.0,且没有提供速度和努力的数据。
            • 如果需要更多信息(如速度和努力),可能需要检查机器人系统是否配置为发布这些额外的状态信息。
            • Y
              yangyy @小伊
              最后由 yangyy 编辑
              @小伊
              我使用rviz2 打开TF topic发现有问题:
              map->base_frontprint 和odom->baseprint 是没有的,具体截图如下:
                由于我无法直接查看你提供的截图,我将基于你描述的问题提供一些可能的解决方案和检查步骤。你提到在RViz2中打开TF(Transform)topics时发现map->base_frontprint和odom->baseprint这两个转换不存在。这里有几个可能的原因和解决方法:
                1. 检查TF发布:
                  • 确认是否有节点正在发布map->base_frontprint和odom->baseprint这两个转换。你可以使用ros2 topic list查看所有发布的主题,然后使用ros2 topic echo /tf [message_type](通常message_type是tf2_msgs/msg/TFMessage)来查看TF消息的内容。
                  • 确认TF广播的帧名称是否正确。根据你提供的信息,可能存在拼写错误(例如base_frontprint可能应该是base_footprint)。
                2. 检查节点和包:
                  • 确认是否有相关的节点(如定位节点、SLAM节点等)正在运行,并且这些节点负责发布TF转换。
                  • 检查是否有相关的ROS2包被正确安装和配置。
                3. 检查RViz2配置:
                  • 在RViz2中,确保你已经添加了TF显示项(通常是通过Add -> By display type -> TF)。
                  • 检查在RViz2的TF显示设置中,是否选择了正确的坐标系(Fixed Frame)。通常,这可以是map、odom或base_link等。
                4. 检查启动文件或配置文件:
                  • 如果你使用启动文件(如.launch.py或.launch.xml),检查是否所有必要的节点都被正确启动。
                  • 检查是否有任何参数被错误设置,这可能影响到TF的发布。
                5. 查看日志和错误信息:
                  • 使用ros2 node list查看所有活动的节点。
                  • 使用ros2 node info /node_name查看特定节点的详细信息。
                  • 查看ROS2的日志输出(通常通过ros2 console或直接在终端中查看),查找可能的错误信息或警告。
                6. 重启ROS2系统:
                  • 有时候,简单地重启ROS2系统(停止所有节点,然后重新启动它们)可以解决TF相关的问题。
                7. 确保时间同步:
                  • 在使用多节点和TF时,确保所有节点都使用相同的时间源(如ROS2的时间服务)。时间不同步可能导致TF问题。
                如果上述步骤都不能解决问题,你可能需要更详细地检查你的系统配置或寻求来自ROS2社区或特定ROS2包的帮助。
                  liuchang_t
                  请问这个问题后来解决了么?我遇到了类似的问题
