    依赖问题
    依赖问题 一键安装,ros2
    • C
      cjyiok
      请注意我,检测你在安装过程中出现依赖问题,请在稍后输入n,再选择y,即可解决(若无法解决,清在稍后手动运行命令: sudo aptitude install ros-humble-desktop)
      确认了解情况,请输入回车继续安装
      Run CMD Task:[sudo aptitude install ros-humble-desktop]
      sudo: aptitude: command not found
      Run CMD Task:[sudo aptitude install ros-humble-desktop -y]
      [-][0.01s] CMD Result:code:1
      Run CMD Task:[sudo apt search python3-colcon-common-extensions ]
      [-][0.07s] CMD Result:success
      [][0.05s] python3-colcon-argcomplete : Depends: python3-argcomplete but it is [-][0.05s] Depends: python3-packaging but it is not inst[/][0.05s] python3-colcon-core : Depends: python3-distlib but it is not install[][0.05s] Depends: python3-empy but it is not installabl[|][0.05s] Depends: python3-packaging but it is not insta[-][0.05s] Depends: python3-pytest but it is not installa[/][0.05s] Depends: python3-setuptools but it is not inst[][0.05s] Depends: python3 (>= 3.11) but 3.10.6-1~22.04.[|][0.05s] python3-tomli (>= 1) but it is not in[-][0.05s] python3-toml but it is not installabl[/][0.05s] Recommends: python3-pytest-cov but it is not i[][0.05s] python3-colcon-devtools : Depends: python3-packaging but it is not i[|][0.05s] python3-colcon-notification : Depends: python3-notify2 but it is not[-][0.05s] python3-colcon-package-information : Depends: python3-packaging but [/][0.05s] python3-colcon-python-setup-py : Depends: python3-setuptools but it [][0.05s] python3-colcon-ros : Depends: python3-catkin-pkg-modules (>= 0.4.14)[|][0.05s] python3-catkin-pkg (>= 0.4.14) but it [-][0.05s] CMD Result:code:100
      Run CMD Task:[sudo apt search python3-argcomplete ]
      没有找到包:python3-argcomplete
      [][0.05s] python3-catkin-pkg-modules : Depends: python3-docutils but it is not[|][0.05s] python3-rosdistro-modules : Depends: python3-setuptools but it is no[-][0.05s] CMD Result:code:100
      Run CMD Task:[ls /opt/ros/humble/setup.bash]
      [/][0.00s] ls: cannot access '/opt/ros/humble/setup.bash': No such file or direc[-][0.00s] CMD Result:code:2
        小鱼 技术大佬 @cjyiok
        @cjyiok 在 依赖问题 中说:
        sudo apt install aptitude -y 然后运行上面的命令试试
