    MicroROS自定义接口,电脑端编译报错
    MicroROS
    自定义接口 硬件篇 microros自定义接口
    1.7k
      luo
      [0.288s] WARNING:colcon.colcon_core.package_identification:Failed to parse ROS package manifest in 'arm_servo': Error(s) in package 'arm_servo/package.xml':
      Error(s):
      • The generic dependency on 'rosidl_default_generators' is redundant with: build_depend
        Starting >>> arm_servo
        --- stderr: arm_servo
        CMake Error at /opt/ros/humble/share/rosidl_adapter/cmake/rosidl_adapt_interfaces.cmake:59 (message):
        execute_process(/usr/bin/python3 -m rosidl_adapter --package-name arm_servo
        --arguments-file
        /home/lyt/arm_robot/arm_packages/build/arm_servo/rosidl_adapter__arguments__arm_servo.json
        --output-dir
        /home/lyt/arm_robot/arm_packages/build/arm_servo/rosidl_adapter/arm_servo
        --output-file
        /home/lyt/arm_robot/arm_packages/build/arm_servo/rosidl_adapter/arm_servo.idls)
        returned error code 1:
        File "/usr/lib/python3.10/runpy.py", line 196, in _run_module_as_main
        return _run_code(code, main_globals, None,
        File "/usr/lib/python3.10/runpy.py", line 86, in _run_code
        exec(code, run_globals)
        File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/main.py", line 19, in <module>
        sys.exit(main())
        File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/main.py", line 53, in main
        abs_idl_file = convert_to_idl(
        File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/init.py", line 24, in convert_to_idl
        return convert_srv_to_idl(
        File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/srv/init.py", line 28, in convert_srv_to_idl
        srv = parse_service_string(package_name, input_file.stem, content)
        File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/parser.py", line 859, in parse_service_string
        request_message = parse_message_string(
        File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/parser.py", line 544, in parse_message_string
        msg = MessageSpecification(pkg_name, msg_name, fields, constants)
        File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/parser.py", line 388, in init
        self.base_type = BaseType(
        File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/parser.py", line 205, in init
        raise InvalidResourceName(
        rosidl_adapter.parser.InvalidResourceName: 'Arm_servo_Request' is an
        invalid message name. It should have the pattern '^[A-Z][A-Za-z0-9]*$'
      /opt/ros/humble/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:130 (rosidl_adapt_interfaces)
      CMakeLists.txt:12 (rosidl_generate_interfaces)
      Failed <<< arm_servo [0.38s, exited with code 1]
      Summary: 0 packages finished [0.67s]
      1 package failed: arm_servo
      1 package had stderr output: arm_servo
        luo @17612478530
        project(arm_servo)
        endif()
        "srv/Arm_servo.srv"
        if(BUILD_TESTING)
        endif()
        ament_package()
          luo
          <?xml version="1.0"?>
          <package format="3">
          <name>arm_servo</name>
          <version>0.0.0</version>
          <maintainer email="lyt@todo.todo">lyt</maintainer>
          <license>TODO: License declaration</license>
          <depend>rosidl_default_generators</depend>
          <export>
          </export>
          <build_depend>rosidl_default_generators</build_depend>
          <exec_depend>rosidl_default_runtime</exec_depend>
          </package>
            luo
            服了,喜欢命名带下划线,自定义消息类型名去掉下划线就好了
