    qt5实验失败
    ros2 run qt出错
      生欢
      在虚拟机上按照书上的步骤做的hello_qt实验是正常的,后面装了双系统之后在新装的系统上无法运行,显示:
      QSocketNotifier: Can only be used with threads started with QThread
      /home/milk/chap3/topic_practice_ws/install/status_display/lib/status_display/hello_qt: symbol lookup error: /snap/core20/current/lib/x86_64-linux-gnu/libpthread.so.0: undefined symbol: __libc_pthread_init, version GLIBC_PRIVATE
      [ros2run]: Process exited with failure 127
      这是hello_qt.cpp中的内容:
      #include <QApplication>
      #include <QLabel>
      #include <QString>
      int main(int argc,char argv[])
      QApplication app(argc,argv);
      QLabel
      label = new QLabel();
      QString message = QString::fromStdString("Hello QT!");
      label->setText(message);
      label->show();
      app.exec(); //执行应用
      return 0;
      这是CMakeLists.txt中的内容:
      project(status_display)
      endif()
      find dependencies
      find_package(rclcpp REQUIRED)
      find_package(status_interfaces REQUIRED)
      find_package(Qt5 REQUIRED COMPONENTS Widgets)
      add_executable(hello_qt src/hello_qt.cpp)
      target_link_libraries(hello_qt Qt5::Widgets)
      add_executable(sys_status_display src/sys_status_display.cpp)
      target_link_libraries(sys_status_display Qt5::Widgets)
      ament_target_dependencies(sys_status_display rclcpp status_interfaces)
      if(BUILD_TESTING)
      the following line skips the linter which checks for copyrights
      comment the line when a copyright and license is added to all source files
      the following line skips cpplint (only works in a git repo)
      comment the line when this package is in a git repo and when
      endif()
      install(TARGETS hello_qt sys_status_display
      ament_package()
        小鱼 技术大佬 @19130540668
        @19130540668 在 qt5实验失败 中说:
        是在vscode中运行的吗?怎么安装的vscode
          生欢 @小鱼
          最后由 19130540668 编辑
          @小鱼是在vscode运行的,vscode是安装完系统进入之后推荐安装的,现在发现通过Ubuntu软件安装的凑code无法通过命令卸载,也没有code的图标。在Ubuntu里的软件里卸载后,重新安装的code出现的code的图标但是无法通过命令打开
