    ubuntu18.04一键安装ros/ros2出现OsNotDetected: Could not detect OS
    ros2 osnotdetected
    1.0k
    • S
      shwwgrshbd
      wget http://fishros.com/install -O fishros && . fishros 然后选择1安装ros/ros2,最后提示请输入[]内的数字以选择:1
      Run CMD Task:[wget http://mirror.fishros.com/install/tools/tool_install_ros.py -O /tmp/fishinstall/tools/tool_install_ros.py --no-check-certificate]
      [/][0.00s] --2024-12-05 10:49:12-- http://mirror.fishros.com/install/tools/tool[][0.04s] 正在解析主机 mirror.fishros.com (mirror.fishros.com)... 47.119.165.16[|][0.04s] 正在连接 mirror.fishros.com (mirror.fishros.com)|47.119.165.169|:80..[-][0.04s] CMD Result:success
      Run CMD Task:[wget http://mirror.fishros.com/install/tools/tool_config_rosenv.py -O /tmp/fishinstall/tools/tool_config_rosenv.py --no-check-certificate]
      [/][0.00s] --2024-12-05 10:49:12-- http://mirror.fishros.com/install/tools/tool[][0.02s] 正在解析主机 mirror.fishros.com (mirror.fishros.com)... 47.119.165.16[|][0.02s] 正在连接 mirror.fishros.com (mirror.fishros.com)|47.119.165.169|:80..[-][0.02s] CMD Result:success
      Run CMD Task:[wget http://mirror.fishros.com/install/tools/tool_config_system_source.py -O /tmp/fishinstall/tools/tool_config_system_source.py --no-check-certificate]
      [/][0.00s] --2024-12-05 10:49:13-- http://mirror.fishros.com/install/tools/tool[][0.02s] 正在解析主机 mirror.fishros.com (mirror.fishros.com)... 47.119.165.16[|][0.02s] 正在连接 mirror.fishros.com (mirror.fishros.com)|47.119.165.169|:80..[-][0.02s] CMD Result:success
      标题:使用一键安装过程中遇到程序崩溃
      self.install_ros()
      File "/tmp/fishinstall/tools/tool_install_ros.py", line 398, in install_ros
      if not self.support_install(): return False
      File "/tmp/fishinstall/tools/tool_install_ros.py", line 300, in support_install
      if (osversion.get_codename() not in ros_dist_dic.keys()) and (osversion.get_codename() not in ros2_dist_dic.keys()):
      File "/tmp/fishinstall/tools/base.py", line 691, in get_codename
      self.detect_os()
      File "/tmp/fishinstall/tools/base.py", line 651, in detect_os
