    订阅者不能接收到第二次的数据
    回调函数 异步回调
      为什么我的节点 只能接收到一次数据 第二次就接收不到了 请大神帮我解决一下!以下是我的代码
      import rclpy
      from rclpy.node import Node
      from nav2_simple_commander.robot_navigator import BasicNavigator,TaskResult
      from geometry_msgs.msg import PolygonStamped
      from demeter_adas_path_controller.utils.gps_utils import latLonYaw2Geopose
      from robot_localization.srv import FromLL
      import math
      from rclpy.callback_groups import MutuallyExclusiveCallbackGroup
      from geometry_msgs.msg import PoseStamped
      class PathFollowerCommander(Node):
          def __init__(self, name):
              super().__init__(name)
              # 初始化导航器和回调组
              self.navigator = BasicNavigator("basic_navigator")
              self.client_cb_group = MutuallyExclusiveCallbackGroup()
              self.sub_cb_group = MutuallyExclusiveCallbackGroup()
              # 订阅地图点数据
              self.mapviz_wp_sub = self.create_subscription(
                  PolygonStamped, "/way_point_list_data", self.mapviz_wp_cb, 100, callback_group=self.sub_cb_group)
              # 创建 FromLL 服务客户端
              self.localizer = self.create_client(FromLL, '/fromLL', callback_group=self.client_cb_group)
              while not self.localizer.wait_for_service(timeout_sec=1.0):
                  self.get_logger().info('Service not available, waiting again...')
              self.get_logger().info('PathFollowerCommander Node Initialized Successfully.')
          def mapviz_wp_cb(self, msg: PolygonStamped):
              self.get_logger().info('Receive Points Data Successfully!')
              self.navigator.waitUntilNav2Active(localizer='controller_server')
              if msg.header.frame_id != "wgs84":
                  self.get_logger().warning(
                      "Received point from mapviz that is not in wgs84 frame. This is not a gps point and won't be followed")
                  return
              gepose_wps = []
              points = msg.polygon.points
              yaw = 0
              for i, point in enumerate(points):
                  latitude, longitude = point.y, point.x
                  if i < len(points) - 1:  # 如果不是最后一个点
                      next_point = points[i + 1]
                      delta_x = next_point.x - point.x
                      delta_y = next_point.y - point.y
                      # 计算朝向的角度(在平面上)
                      yaw = math.atan2(delta_y,delta_x)
                  gepose_wps.append(latLonYaw2Geopose(latitude, longitude, yaw))
              wpl = []
              goals = []
              for wp in gepose_wps:
                  self.req = FromLL.Request()
                  self.req.ll_point.longitude = wp.position.longitude
                  self.req.ll_point.latitude = wp.position.latitude
                  self.req.ll_point.altitude = wp.position.altitude
                  log = 'lon={:f}, lat={:f}, alt={:f}'.format(self.req.ll_point.longitude, self.req.ll_point.latitude,
                                                             self.req.ll_point.altitude)
                  self.get_logger().info(log)
                  # 发送请求
                  future = self.localizer.call_async(self.req)
                  rclpy.spin_until_future_complete(self, future)
                  if future.result() is not None:
                      self.resp = PoseStamped()
                      self.resp.header.frame_id = 'map'
                      self.resp.header.stamp = self.get_clock().now().to_msg()
                      self.resp.pose.position = future.result().map_point
                      log = 'x={:f}, y={:f}, z={:f}'.format(future.result().map_point.x, future.result().map_point.y, future.result().map_point.z)
                      self.resp.pose.orientation = wp.orientation
                      wpl += [self.resp]
                      goals += [self.resp]
                  else:
                      self.get_logger().error('Service call failed.')
              # 发送目标点列表给导航器
              # self.navigator.goThroughWaypoints(goals)
              self.get_logger().info("Start Follow Path!")
              initial_pose = PoseStamped()
              initial_pose = goals[0]
              self.navigator.setInitialPose(initial_pose)
              result_path = [x for i, x in enumerate(goals) if i % 2 != 0]
              path = self.navigator.getPathThroughPoses(initial_pose, goals=result_path)
              smoothed_path = self.navigator.smoothPath(path)
              self.navigator.followPath(smoothed_path)
              self.get_logger().info("Follow Path Completed Successfully!")
              i = 0
              while not self.navigator.isTaskComplete():
                  i += 1
                  feedback = self.navigator.getFeedback()
                  if feedback and i % 5 == 0:
                      self.get_logger().info('Estimated distance remaining to goal position: ' +
                          '{0:.3f}'.format(feedback.distance_to_goal) +
                          '\nCurrent speed of the robot: ' +
                          '{0:.3f}'.format(feedback.speed))
              result = self.navigator.getResult()
              if result == TaskResult.SUCCEEDED:
                  self.get_logger().info('Goal succeeded!')
              elif result == TaskResult.CANCELED:
                  self.get_logger().info('Goal was canceled!')
              elif result == TaskResult.FAILED:
                  self.get_logger().info('Goal failed!')
              else:
                  self.get_logger().info('Goal has an invalid return status!')
              self.get_logger().info('return')
      def main():
          rclpy.init()
          executor = rclpy.executors.MultiThreadedExecutor()
          lc_node = PathFollowerCommander("gps_path_follower")
          executor.add_node(lc_node)
          try:
              executor.spin()
              # rclpy.spin(lc_node)
          except (KeyboardInterrupt, rclpy.executors.ExternalShutdownException):
              pass
          finally:
              lc_node.destroy_node()
              # lc_node.shutdown()
      if __name__ == "__main__":
      我已经确保了第一次的回调已经成功结束,已经输出return,所以这里应该没有异步阻塞的问题
