    一键安装Cartographer失败
    cartographer 安装,报错
    6
    7
    6.3k
    • 8
      821278820
      [][37.86s] -- Installing: /usr/local/stow/absl/lib/pkgconfig/absl_random_intern[/][37.86s] -- Installing: /usr/local/stow/absl/lib/pkgconfig/absl_strings_inter[-][37.86s] -- Installing: /usr/local/stow/absl/lib/pkgconfig/absl_str_format_in[/][37.86s] -- Installing: /usr/local/stow/absl/lib/libabsl_str_format_internal.[][37.86s] -- Installing: /usr/local/stow/absl/lib/pkgconfig/absl_cord_internal[-][37.87s] -- Installing: /usr/local/stow/absl/lib/pkgconfig/absl_cordz_update_[/][37.87s] -- Installing: /usr/local/stow/absl/lib/pkgconfig/absl_cordz_functio[|][37.87s] -- Installing: /usr/local/stow/absl/lib/pkgconfig/absl_cordz_statist[-][37.87s] -- Installing: /usr/local/stow/absl/lib/pkgconfig/absl_cordz_handle.[-][37.87s] -- Installing: /usr/local/stow/absl/lib/pkgconfig/absl_cordz_sample_[][37.87s] -- Installing: /usr/local/stow/absl/lib/pkgconfig/absl_cordz_update_[/][37.87s] -- Installing: /usr/local/stow/absl/lib/pkgconfig/absl_graphcycles_i[][37.87s] -- Installing: /usr/local/stow/absl/lib/libabsl_graphcycles_internal[|][37.87s] -- Installing: /usr/local/stow/absl/lib/pkgconfig/absl_kernel_timeou[-][37.87s] -- Installing: /usr/local/stow/absl/lib/pkgconfig/absl_synchronizati[/][37.87s] -- Installing: /usr/local/stow/absl/lib/pkgconfig/absl_bad_any_cast.[][37.87s] -- Installing: /usr/local/stow/absl/lib/pkgconfig/absl_bad_any_cast_[][37.87s] -- Installing: /usr/local/stow/absl/lib/pkgconfig/absl_bad_optional_[|][37.87s] -- Installing: /usr/local/stow/absl/lib/libabsl_bad_optional_access.[-][37.87s] -- Installing: /usr/local/stow/absl/lib/pkgconfig/absl_bad_variant_a[-][37.87s] CMD Result:success s.a
      Run CMD Task:[catkin_make_isolated --install --use-ninja]
      [-][0.00s] CMD Result:code:127
      Run CMD Task:[sudo chmod -R 777 cartographer_ws]
      [-][0.00s] CMD Result:success
      1 3 2 条回复 最后回复 回复 引用 0
      • C
        catalpa
        看你上面的都安装正常 catkin_make_isolated --install --use-ninja 应该是编译异常,你直接手动敲编译命令就行
        小 2 条回复 最后回复 回复 引用 0
          从你提供的日志信息来看,一键安装Cartographer的过程中,前面的ABSL(Abseil)库的安装部分是成功的,但在执行 catkin_make_isolated --install --use-ninja 命令时失败了,返回了错误代码127。错误代码127通常表示命令或程序找不到。
          这里有几个可能的解决方案和检查步骤:
          1. 检查Ninja安装:
            • catkin_make_isolated 命令中使用 --use-ninja 选项意味着它依赖于Ninja构建系统。确保Ninja已经正确安装在你的系统上。你可以通过运行 ninja --version 来检查它是否已安装。
            • 如果没有安装Ninja,你可以通过包管理器安装它(例如,在Ubuntu上可以使用 sudo apt-get install ninja-build)。
          2. 检查Catkin和ROS环境:
            • 确保你的ROS(Robot Operating System)环境已正确设置。这包括设置环境变量如 ROS_DISTRO 和 ROS_PACKAGE_PATH。
            • 验证 catkin_make_isolated 命令是否在你的路径中。你可以通过运行 which catkin_make_isolated 来检查。
          3. 检查Cartographer依赖:
            • 确保所有Cartographer的依赖项都已正确安装。Cartographer依赖于许多其他库和工具,如Protobuf, gflags, glog, Ceres Solver等。
            • 你可以查看Cartographer的官方安装指南,确保所有依赖项都已安装并配置正确。
          4. 权限问题:
            • 尽管你尝试通过 sudo chmod -R 777 cartographer_ws 修改了工作区的权限,但这通常不是最佳实践。更安全的做法是确保你的用户账户是ROS工作区的所有者,或者在使用 sudo 时正确地使用它(例如,直接运行 sudo catkin_make_isolated --install --use-ninja)。
          5. 查看详细的错误输出:
            • 错误代码127通常不提供太多具体信息,但 catkin_make_isolated 可能会在工作空间目录下的 logs 文件夹中留下更详细的错误日志。检查这些日志可能会提供更多关于为什么构建失败的线索。
          6. 清理和重新构建:
            • 有时候,完全清理工作空间并从头开始构建可以解决一些看似复杂的问题。你可以尝试删除 build 和 devel 文件夹,然后再次运行构建命令。
          通过上述步骤,你应该能够诊断并解决安装Cartographer时遇到的问题。如果问题仍然存在,可能需要更详细地检查你的系统配置或寻求社区的帮助。
          • C
            catalpa
            • 小鱼小 小鱼 将这个主题标记为已解决,在
              111 @821278820
              @821278820 我也是异常,能问下如何解决
                3307978900 @821278820
                @821278820 我也是失败 127,但我是这个问题,不管自己安装还是一键安装都是这个问题,搞了很久也没解决
                CMake Error in CMakeLists.txt:
                Imported target "Boost::iostreams" includes non-existent path
                "/include"
                in its INTERFACE_INCLUDE_DIRECTORIES. Possible reasons include:
                • The path was deleted, renamed, or moved to another location.
                • An install or uninstall procedure did not complete successfully.
                • The installation package was faulty and references files it does not
                  provide.
                -- Generating done
                CMake Generate step failed. Build files cannot be regenerated correctly.
                <== Failed to process package 'cartographer':
                Command '['cmake', '/mnt/e/ROS/cartographer_ws/cartographer_ws/src/cartographer', '-DCMAKE_INSTALL_PREFIX=/mnt/e/ROS/cartographer_ws/cartographer_ws/install_isolated', '-G', 'Ninja']' returned non-zero exit status 1.
                Reproduce this error by running:
                ==> cd /mnt/e/ROS/cartographer_ws/cartographer_ws/build_isolated/cartographer && cmake /mnt/e/ROS/cartographer_ws/cartographer_ws/src/cartographer -DCMAKE_INSTALL_PREFIX=/mnt/e/ROS/cartographer_ws/cartographer_ws/install_isolated -G Ninja
                Command failed, exiting.
                • 小
                  小蘑苽 @catalpa
                  @catalpa 你好,输入什么命令
                  • 小
                    小蘑苽 @catalpa
                    @catalpa 是不是要在cartographer_ws下输入
