    5.33 C++ 查询TF关系,问题异常查询
    ros2 hamble c++ 异常查询
    2.2k
      #include <memory>
      #include <geometry_msgs/msg/transform_stamped.hpp>  // 坐标变换消息
      #include "rclcpp/rclcpp.hpp"
      #include "tf2/LinearMath/Quaternion.h"
      #include"tf2/utils.h"   // 欧拉角转换函数
      #include "tf2_geometry_msgs/tf2_geometry_msgs.hpp"
      #include "tf2_ros/buffer.h"  // 坐标变换缓存器
      #include "tf2_ros/transform_listener.h"  // 坐标变换监听器
      #include <chrono>
      class TFListener : public rclcpp::Node {
       //private:
        //std::shared_ptr<tf2_ros::TransformListener> listener_;
        //rclcpp::TimerBase::SharedPtr timer_;
        //std::shared_ptr<tf2_ros::Buffer> buffer_;
       public:
        TFListener() : Node("tf_listener")
          // 创建 tf2_ros::Buffer 对象和 tf2_ros::TransformListener 对象
          this->buffer_= std::make_shared<tf2_ros::Buffer>(this->get_clock());
          this->listener_ = std::make_shared<tf2_ros::TransformListener>(*buffer_, this);
          timer_ = this->create_wall_timer(5s, std::bind(&TFListener::getTransform, this));
        void getTransform()
           // RCLCPP_INFO(get_logger(),"getTransform");
            try
              // 查找坐标变换
              const auto transform = buffer_->lookupTransform("base_link", "target_point", this->get_clock()->now(), rclcpp::Duration::from_seconds(1.0f));
              //const auto transform = buffer_->lookupTransform("base_link", "target_point", tf2::TimePointZero, rclcpp::Duration::from_seconds(1.0f));
              auto translation = transform.transform.translation;
              auto rotation = transform.transform.rotation;
              double yaw, pitch, roll;
              tf2::getEulerYPR(rotation, yaw, pitch, roll);   // 四元数转换为欧拉角
              RCLCPP_INFO(get_logger(), "平移: (%f, %f, %f)", translation.x, translation.y, translation.z);
              RCLCPP_INFO(get_logger(), "旋转分量: (%f, %f, %f)", yaw, pitch, roll);
           catch(tf2::TransformException &ex)
              RCLCPP_WARN(this->get_logger(), "异常: %s",  ex.what());    // 异常处理
              RCLCPP_WARN(this->get_logger(), "请检查 'base_link' 和 'target_point' 帧是否存在!");
       private:
      int main(int argc, char **argv) {
        rclcpp::init(argc, argv);
        auto node = std::make_shared<TFListener>();
        rclcpp::spin(node);
        rclcpp::shutdown();
        return 0;
      异常查询
      wan@wan-ThinkPad-X1-Yoga-3rd:~/chapt5/chapt5-ws$ ros2 run demo_cpp_tf tf_listener
      [WARN] [1734540892.011489282] [tf_listener]: 异常: "base_link" passed to lookupTransform argument target_frame does not exist.
      [WARN] [1734540892.011951144] [tf_listener]: 请检查 'base_link' 和 'target_point' 帧是否存在!
      [WARN] [1734540897.011437880] [tf_listener]: 异常: "base_link" passed to lookupTransform argument target_frame does not exist.
      [WARN] [1734540897.011647731] [tf_listener]: 请检查 'base_link' 和 'target_point' 帧是否存在!
        从你提供的代码和错误信息来看,你遇到了在使用 ROS 2 和 tf2 库进行坐标变换查询时常见的错误。错误信息表明 base_link 帧或 target_point 帧在 tf 树中不存在。这意味着你的 tf 监听器无法找到从 base_link 到 target_point 的变换关系。
        这里有几个步骤可以帮助你解决这个问题:
        1. 确认帧的存在:
          • 确保你的 ROS 2 系统中确实发布了 base_link 和 target_point 这两个帧的变换信息。
          • 你可以使用 ros2 tf static_list_frames 命令来列出当前所有静态帧。
          • 使用 ros2 tf tree 命令来查看 tf 树的结构,确认 base_link 和 target_point 是否在树中,以及它们之间的连接关系。
        2. 检查发布者:
          • 确认是否有节点正在发布 base_link 到 target_point 的变换。这通常是通过发布 /tf 或 /tf_static 话题来实现的。
          • 使用 ros2 topic list 查看当前所有活跃的话题,使用 ros2 topic echo /tf geometry_msgs/msg/TransformStamped 来查看 /tf 话题的内容,确保包含你需要的变换。
        3. 检查时间戳:
          • 在你的代码中,你使用了当前时间 this->get_clock()->now() 来查询变换。确保发布变换的节点也在使用合理的时间戳。
          • 如果变换是静态的,你也可以尝试使用 tf2::TimePointZero 作为查询的时间戳。
        4. 代码审查:
          • 你的代码看起来基本正确,但确保所有必要的库都已经正确安装和链接。
          • 确保你的环境变量(如 ROS_DOMAIN_ID)在运行节点之前已经正确设置。
        5. 日志和调试:
          • 增加更多的日志输出可以帮助你更好地理解问题所在。例如,你可以在发布变换的节点中添加日志,以确认变换是否正在被发布。
          • 你也可以尝试简化你的代码,例如只查询一个已知的、总是存在的帧对,以确认 tf 监听器的基本功能是否正常。
        6. 重启 ROS 2 环境:
          • 有时候,重启你的 ROS 2 工作空间或整个系统可以解决一些不明确的问题。
        如果以上步骤都不能解决问题,可能需要更深入地检查你的 ROS 2 配置或咨询更具体的社区支持。
          没人解答一下吗!!!!!!!
            2208735873 @261962418
            @261962418 你需要先运行staric_tf_broadcaster 和 dynamic_tf_broadcaster两个节点后,再运行tf_listener,即可正常输出
