    找不到roscpp
    找不到roscpp 编译问题 catkinmake
    • 10189051621
      红鲤鱼与绿鲤鱼与驴
      已经安装roscpp但编译后出现
      Could not find a package configuration file provided by "rospp" with any of the following names: rosppConfig.cmake rospp-config.cmake
      cmakelists.txt如下:
      cmake_minimum_required(VERSION 3.0.2)
      project(IMUpose)
      set(CMAKE_BUILD_TYPE "Debug")
      Compile as C++11, supported in ROS Kinetic and newer
      add_compile_options(-std=c++11)
      Find catkin macros and libraries
      if COMPONENTS list like find_package(catkin REQUIRED COMPONENTS xyz)
      is used, also find other catkin packages
      rospp
      sensor_msgs
      std_msgs
      find_package(Sophus REQUIRED)
      find_package(Eigen3 REQUIRED)
      System dependencies are found with CMake's conventions
      find_package(Boost REQUIRED COMPONENTS system)
      Uncomment this if the package has a setup.py. This macro ensures
      modules and global scripts declared therein get installed
      See http://ros.org/doc/api/catkin/html/user_guide/setup_dot_py.html
      catkin_python_setup()
      Declare ROS messages, services and actions
      To declare and build messages, services or actions from within this
      package, follow these steps:
      * Let MSG_DEP_SET be the set of packages whose message types you use in
      your messages/services/actions (e.g. std_msgs, actionlib_msgs, ...).
      * In the file package.xml:
      * add a build_depend tag for "message_generation"
      * add a build_depend and a exec_depend tag for each package in MSG_DEP_SET
      * If MSG_DEP_SET isn't empty the following dependency has been pulled in
      but can be declared for certainty nonetheless:
      * add a exec_depend tag for "message_runtime"
      * In this file (CMakeLists.txt):
      * add "message_generation" and every package in MSG_DEP_SET to
      find_package(catkin REQUIRED COMPONENTS ...)
      * add "message_runtime" and every package in MSG_DEP_SET to
      catkin_package(CATKIN_DEPENDS ...)
      * uncomment the add_*_files sections below as needed
      and list every .msg/.srv/.action file to be processed
      * uncomment the generate_messages entry below
      * add every package in MSG_DEP_SET to generate_messages(DEPENDENCIES ...)
      Generate messages in the 'msg' folder
      add_message_files(
      FILES
      Message1.msg
      Message2.msg
      Generate services in the 'srv' folder
      add_service_files(
      FILES
      Service1.srv
      Service2.srv
      Generate actions in the 'action' folder
      add_action_files(
      FILES
      Action1.action
      Action2.action
      Generate added messages and services with any dependencies listed here
      generate_messages(
      DEPENDENCIES
      sensor_msgs# std_msgs
      Declare ROS dynamic reconfigure parameters
      To declare and build dynamic reconfigure parameters within this
      * add a build_depend and a exec_depend tag for "dynamic_reconfigure"
      * add "dynamic_reconfigure" to
      * uncomment the "generate_dynamic_reconfigure_options" section below
      and list every .cfg file to be processed
      Generate dynamic reconfigure parameters in the 'cfg' folder
      generate_dynamic_reconfigure_options(
      cfg/DynReconf1.cfg
      cfg/DynReconf2.cfg
      catkin specific configuration
      The catkin_package macro generates cmake config files for your package
      Declare things to be passed to dependent projects
      INCLUDE_DIRS: uncomment this if your package contains header files
      LIBRARIES: libraries you create in this project that dependent projects also need
      CATKIN_DEPENDS: catkin_packages dependent projects also need
      DEPENDS: system dependencies of this project that dependent projects also need
      catkin_package(
      INCLUDE_DIRS include
      LIBRARIES IMUpose
      CATKIN_DEPENDS rospp sensor_msgs std_msgs
      # DEPENDS system_lib
      Build
      Specify additional locations of header files
      Your package locations should be listed before other locations
      include_directories(
      include
      ${catkin_INCLUDE_DIRS}
      ${EIGEN3_INCLUDE_DIRS}
      ${Sophus_INCLUDE_DIRS}
      Declare a C++ library
      add_library(${PROJECT_NAME}
      src/${PROJECT_NAME}/IMUpose.cpp
      Add cmake target dependencies of the library
      as an example, code may need to be generated before libraries
      either from message generation or dynamic reconfigure
      add_dependencies(${PROJECT_NAME} ${${PROJECT_NAME}_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
      Declare a C++ executable
      With catkin_make all packages are built within a single CMake context
      The recommended prefix ensures that target names across packages don't collide
      add_executable(IMU_node IMUpose.cpp)
      Rename C++ executable without prefix
      The above recommended prefix causes long target names, the following renames the
      target back to the shorter version for ease of user use
      e.g. "rosrun someones_pkg node" instead of "rosrun someones_pkg someones_pkg_node"
      set_target_properties(${PROJECT_NAME}_node PROPERTIES OUTPUT_NAME node PREFIX "")
      Add cmake target dependencies of the executable
      same as for the library above
      add_dependencies(${PROJECT_NAME}_node ${${PROJECT_NAME}_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
      Specify libraries to link a library or executable target against
      target_link_libraries(IMU_node
      ${catkin_LIBRARIES}
      catkin_LIBRARIES CATKIN_LIBRARIES
      Install
      all install targets should use catkin DESTINATION variables
      See http://ros.org/doc/api/catkin/html/adv_user_guide/variables.html
      Mark executable scripts (Python etc.) for installation
      in contrast to setup.py, you can choose the destination
      catkin_install_python(PROGRAMS
      scripts/my_python_script
      DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
      Mark executables for installation
      See http://docs.ros.org/melodic/api/catkin/html/howto/format1/building_executables.html
      install(TARGETS ${PROJECT_NAME}_node
      RUNTIME DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
      Mark libraries for installation
      See http://docs.ros.org/melodic/api/catkin/html/howto/format1/building_libraries.html
      ARCHIVE DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
      LIBRARY DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
      RUNTIME DESTINATION ${CATKIN_GLOBAL_BIN_DESTINATION}
      Mark cpp header files for installation
      install(DIRECTORY include/${PROJECT_NAME}/
      DESTINATION ${CATKIN_PACKAGE_INCLUDE_DESTINATION}
      FILES_MATCHING PATTERN "*.h"
      PATTERN ".svn" EXCLUDE
      Mark other files for installation (e.g. launch and bag files, etc.)
      install(FILES
      # myfile1
      # myfile2
      DESTINATION ${CATKIN_PACKAGE_SHARE_DESTINATION}
      Testing
      Add gtest based cpp test target and link libraries
      catkin_add_gtest(${PROJECT_NAME}-test test/test_IMUpose.cpp)
      if(TARGET ${PROJECT_NAME}-test)
      target_link_libraries(${PROJECT_NAME}-test ${PROJECT_NAME})
      endif()
      Add folders to be run by python nosetests
      catkin_add_nosetests(test)
        在你的 CMakeLists.txt 文件中,错误出现在你试图找到并依赖一个名为 rospp 的包,但 ROS 中实际上并没有名为 rospp 的包。通常,与 ROS C++ 相关的包是 roscpp。
        为了解决这个问题,你应该将 CMakeLists.txt 文件中所有提到 rospp 的地方替换为 roscpp。下面是修改后的关键部分:
        1. 在 find_package 调用中,将 rospp 改为 roscpp:
          roscpp  # 修改这里
          sensor_msgs
          std_msgs
        2. 在 catkin_package 调用中,同样将 rospp 改为 roscpp:
          catkin_package(
          LIBRARIES IMUpose
          CATKIN_DEPENDS roscpp sensor_msgs std_msgs  # 修改这里
        3. 确保其他部分(如依赖项和编译选项)已经正确设置,并且没有其他拼写错误。
        修改这些之后,你的 CMakeLists.txt 应该能够正确找到 roscpp 包,并且你的项目应该能够编译。如果你仍然遇到问题,请检查你的 ROS 环境是否正确设置,以及所有相关的包是否都已正确安装。
        此外,还有一些其他的注意事项:
        • 确保你的 ROS 版本(如 Kinetic, Melodic 等)与你的项目设置相匹配。
        • 清理旧的构建文件(例如使用 catkin_make clean),然后重新构建项目。
        • 确保你的 package.xml 文件也正确声明了对 roscpp 的依赖。
