    colcon编译报错
    ros2 报错
    1.0k
    • 5
      525906221
      lyt@lyt-virtual-machine:~/test$ colcon build
      Starting >>> custom_interfaces
      --- stderr: custom_interfaces
      CMake Error at /opt/ros/foxy[表情]/rosidl_adapter/cmake/rosidl_adapt_interfaces.cmake:60 (message):
      execute_process(/usr/bin/python3 -m rosidl_adapter --package-name
      custom_interfaces --arguments-file
      /home/lyt/test[表情]ild/custom_interfaces/rosidl_adapter__arguments__custom_interfaces.json
      --output-dir
      /home/lyt/test[表情]ild/custom_interfaces/rosidl_adapter/custom_interfaces
      --output-file
      /home/lyt/test[表情]ild/custom_interfaces/rosidl_adapter/custom_interfaces.idls)
      returned error code 1:
      Error processing 'custom_interfaces/Shelf[] shelfs_list //货架列表' of
      'custom_interfaces/Layout': 'parsing string values into type
      'custom_interfaces/Shelf[]' is not supported'
      File "/usrb/python3.8/runpy.py", line 194, in _run_module_as_main
        return _run_code(code, main_globals, None,
      File "/usrb/python3.8/runpy.py", line 87, in _run_code
        exec(code, run_globals)
      File "/opt/ros/foxyb/python3.8/site-packages/rosidl_adapter/__main__.py", line 19, in <module>
        sys.exit(main())
      File "/opt/ros/foxyb/python3.8/site-packages/rosidl_adapter/main.py", line 53, in main
        abs_idl_file = convert_to_idl(
      File "/opt/ros/foxyb/python3.8/site-packages/rosidl_adapter/__init__.py", line 19, in convert_to_idl
        return convert_msg_to_idl(
      File "/opt/ros/foxyb/python3.8/site-packages/rosidl_adapter/msg/__init__.py", line 28, in convert_msg_to_idl
        msg = parse_message_string(package_name, input_file.stem, content)
      File "/opt/ros/foxyb/python3.8/site-packages/rosidl_adapter/parser.py", line 515, in parse_message_string
        fields.append(Field(
      File "/opt/ros/foxyb/python3.8/site-packages/rosidl_adapter/parser.py", line 360, in __init__
        self.default_value = parse_value_string(
      File "/opt/ros/foxyb/python3.8/site-packages/rosidl_adapter/parser.py", line 631, in parse_value_string
        raise NotImplementedError(
      NotImplementedError: parsing string values into type
      /opt/ros/foxy[表情]/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:130 (rosidl_adapt_interfaces)
      CMakeLists.txt:23 (rosidl_generate_interfaces)
      Failed <<< custom_interfaces [2.01s, exited with code 1]
      Summary: 0 packages finished [2.87s]
      1 package failed: custom_interfaces
      1 package had stderr output: custom_interfaces
      1 package not processed
        从你提供的错误信息来看,问题出现在 custom_interfaces 包中,特别是在处理消息类型定义时遇到了问题。错误指出 rosidl_adapter 无法解析类型为 custom_interfaces/Shelf[] 的数组字段,具体是在解析 custom_interfaces/Layout 消息中的 shelfs_list 字段时发生的。
        这里的错误 NotImplementedError: parsing string values into type 'custom_interfaces/Shelf[]' is not supported 表明 rosidl_adapter 尚不支持将字符串直接解析为复杂类型(如自定义消息类型的数组)。这通常意味着在消息定义文件中可能错误地尝试将一个字符串直接声明为 Shelf[] 类型,或者在处理该类型时存在某种语法或逻辑错误。
        解决步骤
        1. 检查消息定义文件:
          • 打开 custom_interfaces 包中的消息定义文件(通常是 .msg 文件)。
          • 查找 Layout 消息定义,特别是 shelfs_list 字段。
          • 确保 shelfs_list 字段的类型声明正确。如果 Shelf 是另一个消息类型,确保 shelfs_list 被正确声明为 Shelf[] 而不是一个字符串或其他不兼容类型。
        2. 检查是否有语法错误:
          • 确保所有的消息字段都正确声明,没有遗漏的分号、括号或其他语法错误。
        3. 重新生成消息接口:
          • 修改完消息定义后,确保重新运行 colcon build 以重新生成接口。
        4. 查看 rosidl_adapter 的限制:
          • 如果问题依旧存在,可能需要检查 rosidl_adapter 的文档或源代码,了解是否有关于复杂类型数组处理的特定限制或要求。
        5. 寻求帮助:
          • 如果以上步骤无法解决问题,可以考虑在 ROS 社区论坛或相关 GitHub 仓库中寻求帮助。
        注意事项
        • 确保所有路径和文件名都没有包含特殊字符或表情符号,这些可能导致解析错误。从错误信息来看,路径中似乎包含了一些异常字符(如 [表情]),这可能是复制错误或路径中的实际字符问题。
        • 仔细检查环境设置,确保 ROS 安装和依赖关系正确无误。
        希望这些信息能帮助你解决问题!
