    请问[3]:rosdepc遇到这种情况怎么办
    一键安装rosdepc失败 rosdepc安装
    1.3k
      ROS Related:
      [16]:Install: System shipped ROS (!!Warning!! Only for special cases)
      Common Software:
      [6]:一键安装:NodeJS环境
      [7]:一键安装:VsCode开发工具
      [8]:一键安装:Docker
      [10]:一键安装:微信(可以在Linux上使用的微信)
      [15]:一键安装:QQ for Linux
      Configuration Tools:
      [13]:一键配置:python国内源
      Type the number in [] to choose a function:3
      Run CMD Task:[wget http://mirror.fishros.com/install/tools/tool_config_rosdep.py -O /tmp/fishinstall/tools/tool_config_rosdep.py --no-check-certificate]
      [-][0.05s] CMD Result:success
      Welcome to use 模板工程, this tool is brought to you by 小鱼
      Run CMD Task:[sudo apt install python3-pip -y]
      [-][8.58s] CMD Result:success
      Run CMD Task:[sudo pip3 install -i https://pypi.tuna.tsinghua.edu.cn/simple rosdepc]
      [|][1.41s] ERROR: HTTP error 403 while getting https://pypi.tuna.tsinghua.edu.cn/packages/d2/07/fb31bd92c42076000184e34be0212bb9b5a20da3d75ce14288cca4f668cf/rosdepc-1.1.0-py3-none[-][1.49s] ERROR: Could not install requirement rosdepc from https://pypi.tuna.tsinghua.edu.cn/packages/d2/07/fb31bd92c42076000184e34be0212bb9b5a20da3d75ce14288cca4f668cf/rosdepc-1.1.0-py3-none-any.whl#sha256=ddefad1fa7daa104827ad0d30e1f75a6db6848a522294382906325f1fb969a61 because of error 403 Client Error: Forbidden for url: https://pypi.tuna.tsinghua.edu.c[/][1.49s] ERROR: Could not install requirement rosdepc from https://pypi.tuna.tsinghua.edu.cn/packages/d2/07/fb31bd92c42076000184e34be0212bb9b5a20da3d75ce14288cca4f668cf/rosdepc-1.1.0-py3-none-any.whl#sha256=ddefad1fa7daa104827ad0d30e1f75a6db6848a522294382906325f1fb969a61 because of HTTP error 403 Client Error: Forbidden for url: https://pypi.tuna.tsinghua.edu.cn/packages/d2/07/fb31bd92c42076000184e34be0212bb9b5a20da3d75ce14288cca4f668cf/rosdepc-1.1.0-py3-none-any.whl for URL https://pypi.tuna.tsinghua.edu.cn/packages/d2/07/fb31bd92c42076000184e34be0212bb9b5a20da3d75ce14288cca4f668cf/rosdepc-1.1.0-py3-none-any.whl#sha256=ddefad1fa7daa104827ad0d30e1f75a6db6848a522294382906325f1fb969a61 (from https://pypi.tuna.tsing[-][1.49s] CMD Result:code:1
      Run CMD Task:[sudo pip3 install -i https://pypi.tuna.tsinghua.edu.cn/simple rosdepc --break-system-packages]
      [-][0.71s] CMD Result:code:2
      Run CMD Task:[sudo rosdepc init]
      [-][0.00s] CMD Result:code:1
      Run CMD Task:[sudo rosdepc fix-permissions]
      已为您安装好rosdepc,请使用:
      rosdepc update
      进行测试更新,最后欢迎关注微信公众号《鱼香ROS》
      Welcome to join the robot learning exchange QQ group (In Chinese): 438144612 (group password: 一键安装)
      Online shop is now opened! You can get a mobile robot with SLAM and navigation for as low as 499 CNY. Search for '鱼香ROS' on Taobao or visit this link: https://item.taobao.com/item.htm?id=696573635888
      If you encounter any problems, please open: https://fishros.org.cn/forum for feedback
        遇到在尝试一键安装 rosdepc 时出现的 HTTP 403 错误(Forbidden),通常表示访问被禁止。这可能是由于多种原因导致的,例如:
        1. 网络问题:可能你的网络环境(如公司网络、学校网络等)对访问某些外部资源有限制。
        2. 镜像源问题:清华大学(Tsinghua)的 PyPI 镜像源可能存在问题,或者 rosdepc 并未在该镜像源上正确发布。
        3. 包名错误:在错误信息中提到的 rosdepc 可能是一个不存在的包或者是一个笔误。通常,与 ROS 相关的依赖管理工具是 rosdep 而不是 rosdepc。
        解决步骤
        1. 检查包名:
          • 确认你要安装的包名是否正确。对于 ROS 的依赖管理工具,正确的包名应该是 rosdep。
        2. 更换镜像源:
          • 尝试使用默认的 PyPI 源或其他可靠的镜像源,例如阿里云、华为云等。
          • 使用命令 pip install rosdep(注意是 rosdep 而不是 rosdepc)来尝试安装。
        3. 配置 ROSDEP:
          • 安装 rosdep 后,需要初始化它。使用命令 sudo rosdep init,并按照提示完成初始化。
          • 初始化完成后,更新 rosdep 数据库:rosdep update。
        4. 检查网络连接:
          • 确保你的计算机可以访问外部网络,特别是 PyPI 源。
        5. 使用官方推荐的方法:
          • 遵循 ROS 官方或相关社区的推荐方法来安装和配置 rosdep。
        6. 查看日志和反馈:
          • 如果问题仍然存在,查看安装过程中的日志输出,可能会提供更多线索。
          • 访问 鱼香ROS论坛 或其他 ROS 社区论坛,寻求帮助或报告问题。
        7. 手动安装:
          • 如果自动安装工具无法工作,考虑手动下载并安装所需的软件包。
        注意事项
        • 在进行任何更改之前,确保你了解这些更改的潜在影响。
        • 如果你是在一个受限的网络环境中(如公司、学校),可能需要联系网络管理员来获取必要的访问权限。
        • 始终确保你使用的是最新版本的软件和安全补丁。
