colcon build报错
ros2@ros2:~/222$ colcon build
Starting >>> python_pkg
/home/ros2/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py:270: UserWarning: Unknown distribution option: 'tests_require'
warnings.warn(msg)
--- stderr: python_pkg
warnings.warn(msg)
File "/home/ros2/222/src/python_pkg/setup.py", line 5, in <module>
setup(
File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/init.py", line 117, in setup
return distutils.core.setup(**attrs)
File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 186, in setup
return run_commands(dist)
File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 202, in run_commands
dist.run_commands()
File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 983, in run_commands
self.run_command(cmd)
File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/dist.py", line 999, in run_command
super().run_command(command)
File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 1002, in run_command
cmd_obj.run()
File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 312, in run
self.find_sources()
File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 320, in find_sources
mm.run()
File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 548, in run
self.prune_file_list()
File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/command/sdist.py", line 162, in prune_file_list
super().prune_file_list()
File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/_distutils/command/sdist.py", line 380, in prune_file_list
base_dir = self.distribution.get_fullname()
File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/_core_metadata.py", line 272, in get_fullname
return _distribution_fullname(self.get_name(), self.get_version())
File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/_core_metadata.py", line 290, in _distribution_fullname
canonicalize_version(version, strip_trailing_zero=False),
TypeError: canonicalize_version() got an unexpected keyword argument 'strip_trailing_zero'Failed <<< python_pkg [1.15s, exited with code 1]
Summary: 0 packages finished [1.35s]
1 package failed: python_pkg
1 package had stderr output: python_pkg
按照官方给出的ros2学习文档,执行def main():
print('Hi from python_pkg.')if name == 'main':
这个报错。
什么原因,怎么处理? -
您遇到的错误主要与
setuptools
和setup.py
文件中的配置有关。错误信息表明有几个关键问题:-
Unknown distribution option: 'tests_require':
这个警告表示setuptools
不识别tests_require
选项。这通常不是致命错误,但表明您的setup.py
可能使用了某些不再支持或不被当前setuptools
版本识别的参数。尽管tests_require
在一些旧的setuptools
版本中是有效的,但在新的版本中可能已被移除或替换。 -
TypeError: canonicalize_version() got an unexpected keyword argument 'strip_trailing_zero':
这个错误是关键的,它表明在调用canonicalize_version
函数时提供了一个不被期望的关键字参数strip_trailing_zero
。这通常是因为setuptools
版本与您的setup.py
脚本或依赖的其他库不兼容。
解决步骤:
更新或降级
setuptools
尝试更新或降级setuptools
到一个与您的 ROS 2 环境和setup.py
脚本更兼容的版本。您可以使用以下命令来更新或指定特定版本的setuptools
:pip install --upgrade setuptools # 更新到最新版本 # 或者指定一个版本 pip install setuptools==<version>
如果不确定哪个版本兼容,可以尝试几个不同的版本。
检查
setup.py
查看setup.py
文件,确保所有参数都是当前setuptools
版本支持的。特别是检查setup()
函数调用中是否使用了任何过时的或不被支持的参数,如tests_require
。如果使用了tests_require
,您可以考虑移除它,或者使用其他方式来指定测试依赖。 -
清理和重建:
在更改setuptools
版本或setup.py
后,确保清理之前的构建文件。您可以在工作空间目录下运行:colcon build --packages-select python_pkg --merge-install
或者先清理:
colcon clean colcon build
检查 ROS 2 和 Python 版本兼容性:
确保您使用的 ROS 2 版本与您的 Python 版本兼容。有时候,新版本的 Python 可能不被某些 ROS 2 发行版支持。
通过上述步骤,您应该能够解决构建过程中遇到的问题。如果问题仍然存在,可能需要更详细地检查
setup.py
的内容或寻求特定于您使用的 ROS 2 发行版和 Python 版本的社区支持。
@小伊 在 colcon build报错 中说:
您遇到的错误主要与
setuptools
和setup.py
这个警告表示setuptools
不识别tests_require
在一些旧的setuptools
。这通常是因为setuptools
版本与您的setup.py
脚本或依赖的其他库不兼容。
解决步骤:
更新或降级
setuptools
尝试更新或降级setuptools
检查
setup.py
查看setup.py
版本支持的。特别是检查setup()
。如果使用了tests_require
清理和重建:
在更改setuptools
版本或setup.py
或者先清理:
setup.py
我的setup.py文件下的内容是:
from setuptools import find_packages, setuppackage_name = 'python_pkg'
setup(
name=package_name,
version='0.0.0',
packages=find_packages(exclude=['test']),
data_files=[
('share/ament_index/resource_index/packages',
['resource/' + package_name]),
('share/' + package_name, ['package.xml']),
install_requires=['setuptools'],
zip_safe=True,
maintainer='ros2',
maintainer_email='3513232534@QQ.com',
description='TODO: Package description',
license='Apache-2.0',
tests_require=['pytest'],
entry_points={
'console_scripts': [
'python_node = python_pkg.python_node:main'
)应该怎么修改 -
根据您提供的错误信息以及
setup.py
文件的内容,问题主要集中在tests_require
选项上,以及可能的setuptools
版本兼容性问题。以下是一些建议的修改步骤:-
移除
tests_require
选项:
由于tests_require
在新版本的setuptools
中可能不再被支持,您可以考虑移除这个选项。如果您需要指定测试依赖,可以通过其他方式管理,例如在项目的requirements.txt
文件中列出测试依赖,或者在测试脚本中直接处理。修改后的
setup.py
文件如下:from setuptools import find_packages, setup package_name = 'python_pkg' setup( name=package_name, version='0.0.0', packages=find_packages(exclude=['test']), data_files=[ ('share/ament_index/resource_index/packages', ['resource/' + package_name]), ('share/' + package_name, ['package.xml']), ], install_requires=['setuptools'], zip_safe=True, maintainer='ros2', maintainer_email='3513232534@QQ.com', description='TODO: Package description', license='Apache-2.0', entry_points={ 'console_scripts': [ 'python_node = python_pkg.python_node:main' ], }, )
更新或指定
setuptools
版本:
由于您遇到了与setuptools
版本相关的错误,尝试更新到最新版本的setuptools
,或者指定一个与您的 ROS 2 环境和setup.py
如果不确定哪个版本兼容,可以尝试几个不同的版本,直到找到一个不会引发错误的版本。
清理和重建项目:
在更改setup.py
或setuptools
版本后,确保清理之前的构建文件。您可以在工作空间目录下运行以下命令:colcon clean colcon build
或者,如果您只想构建特定的包,可以使用:
确保您使用的 ROS 2 版本与您的 Python 版本兼容。如果您使用的是较新的 Python 版本,而 ROS 2 发行版不支持该版本,您可能需要考虑使用旧版本的 Python 或升级到支持新版本的 ROS 2 发行版。
通过以上步骤,您应该能够解决构建过程中遇到的问题。如果问题仍然存在,请检查
setup.py
的其他内容或寻求特定于您使用的 ROS 2 发行版和 Python 版本的社区支持。
根据您提供的错误信息以及
setup.py
选项上,以及可能的setuptools
移除
tests_require
选项:
由于tests_require
在新版本的setuptools
setup.py
更新或指定
setuptools
版本:
由于您遇到了与setuptools
清理和重建项目:
在更改setup.py
或setuptools
setup.py
根据您提供的错误信息以及
setup.py
选项上,以及可能的setuptools
移除
tests_require
选项:
由于tests_require
在新版本的setuptools
setup.py
更新或指定
setuptools
版本:
由于您遇到了与setuptools
清理和重建项目:
在更改setup.py
或setuptools
setup.py
根据您提供的错误信息以及
setup.py
选项上,以及可能的setuptools
移除
tests_require
选项:
由于tests_require
在新版本的setuptools
setup.py
更新或指定
setuptools
版本:
由于您遇到了与setuptools
清理和重建项目:
在更改setup.py
或setuptools
setup.py
现在编译成功,但是install下却没有相应包 -
如果
colcon build
成功完成,但安装目录下(通常是install
文件夹)没有找到相应的包,可能是由以下几个原因导致的:-
包没有被正确安装:
- 确保
colcon build
没有任何错误或警告,特别是与安装相关的。 - 检查
setup.py
中的packages
参数是否正确地包含了所有需要安装的包。
- 确保
安装目录问题:
- 默认情况下,
colcon
会将包安装到工作空间中的install
目录。确认你是否在正确的工作空间目录下运行了colcon build
。 - 使用
colcon list
可以查看当前工作空间中有哪些包,确保你的包列在其中。
- 默认情况下,
环境变量问题:
- 确保你的
PYTHONPATH
环境变量包含了安装目录。这通常不需要手动设置,因为colcon
会管理这些环境变量,但如果你在其他地方运行 Python 脚本,可能需要手动设置。 - 使用
source install/setup.bash
(或对应的 shell 脚本,如setup.zsh
)来设置环境变量,这样可以让系统知道去哪里找安装的 Python 包。
- 确保你的
包的可见性问题:
- 如果你的包是一个 ROS 2 包,确保它的元数据(如
package.xml
和setup.py
)正确无误,并且遵循了 ROS 2 的包结构。 - 检查
setup.py
中的data_files
是否正确指定了资源文件的位置,这对于 ROS 2 包来说很重要。
权限问题:
- 确保你有足够的权限写入安装目录。在某些系统上,你可能需要使用
sudo
来运行colcon build
,但这通常不推荐,因为它可能引入其他权限问题。
清理和重建:
- 有时候,清理旧的构建文件并重新构建可以解决问题。使用
colcon clean
后再运行colcon build
检查输出:
- 仔细检查
colcon build
的输出,看看是否有任何关于安装步骤的警告或错误。
- 仔细检查
依赖问题:
- 确保所有依赖都已正确安装,并且与你的 ROS 2 版本和 Python 版本兼容。
如果以上步骤都无法解决问题,你可以尝试以下更具体的调试步骤:
- 在
setup.py
中添加打印语句,以查看哪些文件被包括在包中。 - 检查
install
目录下的内容,看看是否有与你的包名相对应的文件夹。 - 在 Python 脚本中尝试导入你的包,看看是否有任何导入错误。
- 查看 ROS 2 社区或相关论坛,看看是否有其他人遇到并解决了类似的问题。
