    驱动板子一直重启
    ros2 micro-ros-agent
    • liusiyu_alex_nuaaL
      liusiyu_alex_nuaa
      将以下程序烧录至驱动板后,一直重启,取消laser_joint_puber后,恢复正常
      #include <Arduino.h>
      #include <Esp32McpwmMotor.h>
      #include <Esp32PcntEncoder.h>
      #include "Robot_Vel_Control.h"
      // 引入MicroROS 和 wifi的库
      #include <WiFi.h>
      #include <rcl/rcl.h>
      #include <rclc/rclc.h>
      #include <rclc/executor.h>
      #include <geometry_msgs/msg/twist.h>
      #include <nav_msgs/msg/odometry.h>
      #include <std_msgs/msg/float32.h>
      #include <sensor_msgs/msg/joint_state.h>
      #include <micro_ros_utilities/string_utilities.h>
      rcl_allocator_t allocator;             // 内存分配器,动态内存分配管理
      rclc_support_t support;                // 存储时钟,内存分配器和上下文,用于提供支持
      rclc_executor_t executor;              // 执行器,用于管理订阅和计时器回调的执行
      rcl_node_t node;                       // 节点
      rcl_subscription_t vel_suber;          // 速度订阅者
      geometry_msgs__msg__Twist vel_sub_msg; // 速度订阅消息
      rcl_publisher_t odom_puber;            // 里程计发布者
      nav_msgs__msg__Odometry odom_pub_msg;  // 里程计消息
      rcl_timer_t timer;                     // 定时器,定时调用某个函数
      rcl_publisher_t laser_joint_puber;     // 下位机雷达角度反馈发布者
      Robot_Vel_Control robot_vel_control;
      float angular_speed = 0.0;
      float linear_speed = 0.0;
      float angular = 0.0;
      float laser_angular = 0.234;
      void odom_puber_callback(rcl_timer_t *timer, int64_t last_call_time)
          odom_t odom = robot_vel_control.get_odom();
          int64_t stamp = rmw_uros_epoch_millis(); // 获取当前时间
          odom_pub_msg.header.stamp.sec = static_cast<int32_t>(stamp / 1000);
          odom_pub_msg.header.stamp.nanosec = static_cast<uint32_t>((stamp / 1000) * 10e6);
          odom_pub_msg.pose.pose.position.x = odom.x;
          odom_pub_msg.pose.pose.position.y = odom.y;
          odom_pub_msg.pose.pose.orientation.w = cos(odom.angle * 0.5);
          odom_pub_msg.pose.pose.orientation.x = 0;
          odom_pub_msg.pose.pose.orientation.y = 0;
          odom_pub_msg.pose.pose.orientation.z = sin(odom.angle * 0.5);
          odom_pub_msg.twist.twist.linear.x = odom.linear_speed;
          odom_pub_msg.twist.twist.angular.z = odom.angular_speed;
          if (rcl_publish(&odom_puber, &odom_pub_msg, NULL) != RCL_RET_OK)
              Serial.printf("Error: odom publisher failed!\n");
      // sensor_msgs__msg__JointState类型初始化
      // 发布 laser_joint
      void laser_joint_puber_callback(rcl_timer_t *timer, int64_t last_call_time)
          sensor_msgs__msg__JointState laser_joint;
          laser_joint.header.stamp.sec = static_cast<int32_t>(stamp / 1000);
          laser_joint.header.stamp.nanosec = static_cast<uint32_t>((stamp / 1000) * 10e6);
          laser_joint.header.frame_id = micro_ros_string_utilities_set(laser_joint.header.frame_id, "");
          laser_joint.name.capacity = 2;
          laser_joint.name.size = 2;
          laser_joint.name.data = (rosidl_runtime_c__String *)malloc(laser_joint.name.capacity * sizeof(rosidl_runtime_c__String));
          // laser_joint.name.data[0] = micro_ros_string_utilities_init_with_size(10);
          laser_joint.name.data[0] = micro_ros_string_utilities_set(laser_joint.name.data[0], "wheel_axis_joint");
          // laser_joint.name.data[1] = micro_ros_string_utilities_init_with_size(10);
          laser_joint.name.data[1] = micro_ros_string_utilities_set(laser_joint.name.data[1], "laser_base_joint");
          // 初始化关节速度
          laser_joint.velocity.size = 2;
          laser_joint.velocity.capacity = 2;
          laser_joint.velocity.data = (double *)malloc(laser_joint.velocity.size * sizeof(double));
          laser_joint.velocity.data[0] = 0.0;
          laser_joint.velocity.data[1] = 0.0;
          // 初始化关节力
          laser_joint.effort.size = 2;
          laser_joint.effort.capacity = 2;
          laser_joint.effort.data = (double *)malloc(laser_joint.effort.size * sizeof(double));
          laser_joint.effort.data[0] = 0.0;
          laser_joint.effort.data[1] = 0.0;
          // 初始化关节位置
          laser_joint.position.size = 2;
          laser_joint.position.capacity = 2;
          laser_joint.position.data = (double *)malloc(laser_joint.position.size * sizeof(double));
          laser_joint.position.data[0] = 0.11;
          laser_joint.position.data[1] = 0.22;
          if (rcl_publish(&laser_joint_puber, &laser_joint, NULL) != RCL_RET_OK)
              Serial.printf("Error: laser_joint publisher failed!\n");
      void timer_50_callback(rcl_timer_t *timer, int64_t last_call_time)
          odom_puber_callback(timer, last_call_time);
          laser_joint_puber_callback(timer, last_call_time);
      void microros_task(void *args)
          // 设置传输协议并延迟一段时间等待设置的完成
          IPAddress agent_ip;
          agent_ip.fromString("192.168.1.103");
          uint16_t agent_port = 8888;
          set_microros_wifi_transports("lsy", "12345678", agent_ip, agent_port);
          delay(2000);
          // 初始化内存分配器
          allocator = rcl_get_default_allocator(); // 获取默认的内存分配器
          // 初始化支持
          // 初始化节点
          rclc_node_init_default(&node, "robot_motion_control", "", &support);
          // 初始化执行器
          unsigned int num_handles = 5;
          rclc_executor_init(&executor, &support.context, num_handles, &allocator);
          // 初始化订阅者,将订阅者加入到执行器当中
          rclc_subscription_init_best_effort(&vel_suber, &node,
                                             ROSIDL_GET_MSG_TYPE_SUPPORT(geometry_msgs, msg, Twist), "cmd_vel");
          rclc_executor_add_subscription(&executor, &vel_suber, &vel_sub_msg, &twist_callback, ON_NEW_DATA);
          // 初始化发布者
          odom_pub_msg.child_frame_id = micro_ros_string_utilities_set(odom_pub_msg.child_frame_id, "base_footprint");
          odom_pub_msg.header.frame_id = micro_ros_string_utilities_set(odom_pub_msg.header.frame_id, "odom");
          rclc_publisher_init_best_effort(&odom_puber, &node,
                                          ROSIDL_GET_MSG_TYPE_SUPPORT(nav_msgs, msg, Odometry), "/odom");
          rclc_publisher_init_best_effort(&laser_joint_puber, &node,
                                          ROSIDL_GET_MSG_TYPE_SUPPORT(sensor_msgs, msg, JointState), "/joint_states");
          // 时间同步
          while (!rmw_uros_epoch_synchronized()) // 如果时间不同步
              rmw_uros_sync_session(1000); // 同步时间
              delay(10);
          // 将发布者加入到定时器
          rclc_timer_init_default(&timer, &support, RCL_MS_TO_NS(50), timer_50_callback);
          // 将定时器加入到执行器中
          rclc_executor_add_timer(&executor, &timer);
          // 循环执行器
          rclc_executor_spin(&executor);
      void setup()
          // 初始化串口0通信,波特率为115200,8个数据位,偶校验,停止位2 串口监视器
          Serial.begin(115200, SERIAL_8E2);
          // 初始化串口1通信,波特率为115200,8个数据位,无校验,停止位1,rx22,tx23
          Serial2.setRxBufferSize(1024);
          Serial2.begin(115200, SERIAL_8N1, 22, 23);
          // 注册串口1的中断服务函数
          Serial2.onReceive(Serial2_Receive_Callback);
          Serial.onReceive(Serial_Receive_Callback);
          // 创建一个任务启动 micro_ROS
          // 第一个参数,运行的函数;第二个参数,任务的名字;第三个参数,分配内存的大小(字节);第五个参数,优先级
          xTaskCreate(microros_task, "microros_task", 20480, NULL, 1, NULL);
      void loop()
          delay(10); // 等待10毫秒
          robot_vel_control.update_odom(millis(), linear_speed, angular_speed, angular);
          // Serial.printf("OUT:out_left_speed=%d,out_right_speed=%d\n", kinematics.get_motor_speed(0),kinematics.get_motor_speed(1));
          // Serial.printf("x=%f,y=%f,yaw=%f\n", robot_vel_control.get_odom().x, robot_vel_control.get_odom().y, robot_vel_control.get_odom().angle);
        根据你提供的代码和问题描述,当laser_joint_puber(雷达角度反馈发布者)启用时,驱动板一直重启,而取消该发布者后系统恢复正常。这种情况通常指示存在内存管理、资源分配或消息处理上的问题。以下是一些可能的原因和解决方案:
        1. 内存泄漏或分配不足:
          • 在laser_joint_puber_callback中,你为laser_joint消息的name和velocity、effort、position数组动态分配了内存。如果这些内存没有被正确释放,可能会导致内存泄漏。虽然Arduino/ESP32通常具有垃圾回收机制(在MicroPython等环境中更常见),但在C++中手动管理内存是很重要的。
          • 解决方案:在不再需要这些消息时(例如,在microros_task函数结束或某个清理函数中),释放这些动态分配的内存。使用free()函数来释放之前通过malloc()分配的内存。
        2. 发布消息过大:
          • 如果laser_joint消息因为包含大量数据而变得过大,它可能会超出系统能够处理或传输的极限。
          • 解决方案:检查laser_joint消息的大小,确保它不会过大。如果必要,减少消息中的数据量或增加系统的处理能力(例如,增加内存或优化通信协议)。
        3. Micro-ROS配置问题:
          • 可能是Micro-ROS的配置或初始化过程中存在问题,导致在尝试使用laser_joint_puber时系统不稳定。
          • 解决方案:检查Micro-ROS的初始化代码,确保所有组件都正确配置和初始化。此外,检查是否有任何与WiFi通信或代理节点相关的配置错误。
        4. 硬件问题:
          • 硬件故障(如电源不稳定、内存芯片故障等)也可能导致系统重启。
          • 解决方案:检查硬件连接和电源供应。如果可能,尝试在不同的硬件上运行相同的代码以排除硬件故障。
        5. 调试和日志:
          • 增加更多的调试输出和日志记录,特别是在与laser_joint_puber相关的代码部分。这可以帮助识别问题发生的具体位置。
          • 解决方案:在关键代码路径中添加Serial.printf()语句来打印变量值和函数返回结果,从而跟踪程序的执行流程。
        6. 软件依赖和库:
          • 确保所有使用的库都与你的开发环境和硬件兼容,并且是最新版本。
          • 解决方案:检查并更新所有相关的库和依赖项。
        通过上述步骤,你应该能够定位并解决问题。如果问题依旧存在,可能需要更深入地分析代码或寻求来自Micro-ROS社区或ESP32开发者的帮助。
