    python编译出现问题gmake[1]: *** 正在等待未完成的任务....
    gmake microrosmsgs
      2075605318 年度VIP
      在编译micro-ROS-Agent和msgs时出现这个问题,疑似是python的,之前也编译过没有问题,在安装yolov5后编译出现问题,不知道有没有关系
      lwb@Lwb:~/code/fishbot_ws$ colcon build
      Starting >>> micro_ros_msgs
      --- stderr: micro_ros_msgs
      File "/home/lwb/code/fishbot_ws/build/micro_ros_msgs/ament_cmake_python/micro_ros_msgs/setup.py", line 4, in <module>
      setup(
      File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/init.py", line 117, in setup
      return distutils.core.setup(**attrs)
      File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 186, in setup
      return run_commands(dist)
      File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 202, in run_commands
      dist.run_commands()
      File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 983, in run_commands
      self.run_command(cmd)
      File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/dist.py", line 999, in run_command
      super().run_command(command)
      File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 1002, in run_command
      cmd_obj.run()
      File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 312, in run
      self.find_sources()
      File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 320, in find_sources
      mm.run()
      File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 548, in run
      self.prune_file_list()
      File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/command/sdist.py", line 162, in prune_file_list
      super().prune_file_list()
      File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/_distutils/command/sdist.py", line 380, in prune_file_list
      base_dir = self.distribution.get_fullname()
      File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/_core_metadata.py", line 272, in get_fullname
      return _distribution_fullname(self.get_name(), self.get_version())
      File "/home/lwb/.local/lib/python3.10/site-packages/setuptools/_core_metadata.py", line 290, in _distribution_fullname
      canonicalize_version(version, strip_trailing_zero=False),
      TypeError: canonicalize_version() got an unexpected keyword argument 'strip_trailing_zero'
      gmake[2]: *** [CMakeFiles/ament_cmake_python_build_micro_ros_msgs_egg.dir/build.make:70:CMakeFiles/ament_cmake_python_build_micro_ros_msgs_egg] 错误 1
      gmake[1]: *** [CMakeFiles/Makefile2:447:CMakeFiles/ament_cmake_python_build_micro_ros_msgs_egg.dir/all] 错误 2
      Failed <<< micro_ros_msgs [0.67s, exited with code 2]
      Summary: 0 packages finished [0.80s]
      1 package failed: micro_ros_msgs
      1 package had stderr output: micro_ros_msgs
      1 package not processed
        2075605318 年度VIP
        https://blog.csdn.net/qq_38196449/article/details/143998597
        已经成功了,就是那个yolo5的问题,pip install setuptools==64后就行了
          从你提供的错误信息来看,问题出现在 micro_ros_msgs 包的编译过程中,特别是与 Python 的 setuptools 库相关。错误提示 TypeError: canonicalize_version() got an unexpected keyword argument 'strip_trailing_zero' 表明 canonicalize_version 函数被调用时传入了一个它不支持的关键字参数 strip_trailing_zero。
          这个问题很可能是由于 setuptools 的版本更新导致的 API 变化。在某些版本的 setuptools 中,canonicalize_version 函数可能不再接受 strip_trailing_zero 参数。
          解决步骤
          1. 检查 setuptools 版本:
            查看当前 setuptools 的版本,并对比之前的版本(如果之前编译成功时你记得版本的话)。
            pip show setuptools
          2. 尝试降级 setuptools:
            如果当前版本较高,可以尝试降级到一个之前工作正常的版本。根据错误提示,可能是在更新 setuptools 后出现了问题。
            pip install setuptools==<旧版本号>
            你需要替换 <旧版本号> 为之前工作正常的版本,比如 58.0.4(这个版本号仅为示例,你需要根据实际情况选择)。
          3. 清理并重新编译:
            在修改了 setuptools 版本后,清理之前的编译结果,并重新编译整个项目。
            cd ~/code/fishbot_ws
            rm -rf build install log
            colcon build
          4. 检查 Python 和 pip 版本:
            确保你的 Python 和 pip 版本与你的项目依赖兼容。有时候,Python 的更新也会带来兼容性问题。
          5. 查看依赖关系:
            如果问题依旧存在,检查 micro_ros_msgs 的依赖是否都正确安装,并且版本兼容。
          6. 查阅文档和社区:
            查看 micro-ROS 的官方文档或者社区,看看是否有其他人遇到并解决了类似的问题。
          通过上述步骤,你应该能够定位并解决问题。如果问题依然存在,可能需要更详细地检查代码或配置,或者考虑在相关的开发社区中寻求帮助。
            小鱼 技术大佬 @2075605318
            @2075605318 大概率是setup版本造成问题,ubuntu22 用 68.0.0 试一试,按照小伊的提示安装
              2075605318 年度VIP
              • 小鱼小 小鱼 将这个主题标记为已解决,在
