    四驱小车V2建图跑飞
    FishBot四驱机器人V2
    slam建图错误 四驱
    1.9k
      每次出现该报错小车在rivz2中就开始旋转漂移,求助!
      [2025-04-02 12:10:47][error] Check Sum 0x477A != 0x7EA2
      [cartographer_node-3] [WARN] [1743595847.976712172] [cartographer logger]: W0402 12:10:47.000000 1335 range_data_collator.cc:82] Dropped 10 earlier points.
      [cartographer_node-3] [WARN] [1743595848.419307060] [cartographer logger]: W0402 12:10:48.000000 1335 range_data_collator.cc:82] Dropped 1 earlier points.
      [rviz2-5] [INFO] [1743595848.492249747] [rviz2]: Trying to create a map of size 234 x 174 using 1 swatches
      [cartographer_node-3] [WARN] [1743595848.712889688] [cartographer logger]: W0402 12:10:48.000000 1335 range_data_collator.cc:82] Dropped 5 earlier points.
      [rviz2-5] [ERROR] [1743595849.036769175] [rviz2]: Lookup would require extrapolation into the future. Requested time 1743595849.059730 but the latest data is at time 1743595849.059730, when looking up transform from frame [laser_frame] to frame [map]
      [cartographer_node-3] [WARN] [1743595849.160105109] [cartographer logger]: W0402 12:10:49.000000 1335 range_data_collator.cc:82] Dropped 139 earlier points.
      [cartographer_node-3] [WARN] [1743595849.457432841] [cartographer logger]: W0402 12:10:49.000000 1335 range_data_collator.cc:82] Dropped 2 earlier points.
      [rviz2-5] [INFO] [1743595849.483899761] [rviz2]: Trying to create a map of size 275 x 187 using 1 swatches
      • 2 2877639376 将这个主题转为问答主题,在
        MeowDWing
        难搞,我也是这个问题,反正小鱼说是网络问题,但我换了路由器和手机的热点都没法解决(手机热点相对稳定,但是隔一段时间,大概不到半分钟,还是会漂移),是不是现代设备都不关注2.4G频段了,或者我感觉他的适配就是有问题
