    在命名空间下加载两轮差速控制器controller_manager加载失败
    控制器 gazebo 仿真 差速控制
    3.6k
      在launch文件中加载命名空间下的gazebo机器人模型时控制器无法获取update_rate参数,但是在yaml文件中正常设置了该参数,且在其他非命名空间下的launch文件进行启动就不会有该问题能够正常启动,鱼哥,这是什么问题呢
      日志:
      [gzserver-2] [INFO] [1743648186.768197312] [robot2.gazebo_ros2_control]: connected to service!! robot_state_publisher
      [gzserver-2] [INFO] [1743648186.774441017] [robot2.gazebo_ros2_control]: Received urdf from param server, parsing...
      [gzserver-2] [INFO] [1743648186.774570288] [robot2.gazebo_ros2_control]: Loading parameter files /home/chen/Program/test_car/test_car_ws/install/car_description/share/car_description/config/track_car_ros2_controller.yaml
      [gzserver-2] [INFO] [1743648186.785325792] [robot2.gazebo_ros2_control]: Loading joint: left_wheel_joint
      [gzserver-2] [INFO] [1743648186.785424816] [robot2.gazebo_ros2_control]:        State:
      [gzserver-2] [INFO] [1743648186.785438451] [robot2.gazebo_ros2_control]:                 position
      [gzserver-2] [INFO] [1743648186.785449251] [robot2.gazebo_ros2_control]:                 velocity
      [gzserver-2] [INFO] [1743648186.789883244] [robot2.gazebo_ros2_control]:                 effort
      [gzserver-2] [INFO] [1743648186.789891189] [robot2.gazebo_ros2_control]:        Command:
      [gzserver-2] [INFO] [1743648186.789919331] [robot2.gazebo_ros2_control]:                 velocity
      [gzserver-2] [INFO] [1743648186.790143749] [robot2.gazebo_ros2_control]:                 effort
      [gzserver-2] [INFO] [1743648186.790156363] [robot2.gazebo_ros2_control]: Loading joint: right_wheel_joint
      [gzserver-2] [INFO] [1743648186.790162734] [robot2.gazebo_ros2_control]:        State:
      [gzserver-2] [INFO] [1743648186.790168756] [robot2.gazebo_ros2_control]:                 position
      [gzserver-2] [INFO] [1743648186.790174326] [robot2.gazebo_ros2_control]:                 velocity
      [gzserver-2] [INFO] [1743648186.790179756] [robot2.gazebo_ros2_control]:                 effort
      [gzserver-2] [INFO] [1743648186.790184926] [robot2.gazebo_ros2_control]:        Command:
      [gzserver-2] [INFO] [1743648186.790191789] [robot2.gazebo_ros2_control]:                 velocity
      [gzserver-2] [INFO] [1743648186.790228076] [robot2.gazebo_ros2_control]:                 effort
      [gzserver-2] [INFO] [1743648186.790315619] [resource_manager]: Initialize hardware 'TrackCarGazeboSystem'
      [gzserver-2] [INFO] [1743648186.790485555] [resource_manager]: Successful initialization of hardware 'TrackCarGazeboSystem'
      [gzserver-2] [INFO] [1743648186.790567368] [resource_manager]: 'configure' hardware 'TrackCarGazeboSystem'
      [gzserver-2] [INFO] [1743648186.790576875] [resource_manager]: Successful 'configure' of hardware 'TrackCarGazeboSystem'
      [gzserver-2] [INFO] [1743648186.790582496] [resource_manager]: 'activate' hardware 'TrackCarGazeboSystem'
      [gzserver-2] [INFO] [1743648186.790588126] [resource_manager]: Successful 'activate' of hardware 'TrackCarGazeboSystem'
      [gzserver-2] [INFO] [1743648186.790664048] [robot2.gazebo_ros2_control]: Loading controller_manager
      [gzserver-2] [WARN] [1743648186.821653458] [robot2.controller_manager]: 'update_rate' parameter not set, using default value.
      [gzserver-2] [ERROR] [1743648186.836982336] [robot2.gazebo_ros2_control]: controller manager doesn't have an update_rate parameter
      launch文件代码:
      import launch
      import launch_ros
      import os
      from launch.substitutions import Command, LaunchConfiguration
      import launch_ros.parameter_descriptions
      from ament_index_python.packages import get_package_prefix
      from launch.actions import TimerAction
          # pkg_robot1_path = get_package_share_directory('fishbot_description')
          pkg_robot2_path = get_package_share_directory('car_description')
          # urdf_robot1_path = os.path.join(pkg_robot1_path, 'urdf', 'fishbot', 'fishbot.urdf.xacro')
          urdf_robot2_path = os.path.join(pkg_robot2_path, 'urdf', 'car_urdf', 'trackcar.urdf.xacro')
          #获取模型文件目录
          package_name = 'car_description'
          pkg_share = os.pathsep + os.path.join(get_package_prefix(package_name), 'share')
          if 'GAZEBO_MODEL_PATH' in os.environ:  # 如果你修改了~/.bashrc, 就会执行这个
              os.environ['GAZEBO_MODEL_PATH'] += pkg_share
          else:  # 注意此处gazebo-11修改为你的gazebo版本
              os.environ['GAZEBO_MODEL_PATH'] = "/usr/share/gazebo-11/models" + pkg_share
          default_world_path = os.path.join(pkg_robot2_path, 'world', 'custom_room.world')
          # action_declare_arg_mode1path = launch.actions.DeclareLaunchArgument(
          #     name='robot1',
          #     default_value=urdf_robot1_path
          action_declare_arg_mode2path = launch.actions.DeclareLaunchArgument(
              name='robot2',
              default_value=urdf_robot2_path
          # robot1_description = launch_ros.parameter_descriptions.ParameterValue(
          #     Command(['xacro ', LaunchConfiguration("robot1")])
          robot2_description = launch_ros.parameter_descriptions.ParameterValue(
              Command(['xacro ', LaunchConfiguration("robot2")])
          # robot1_state_publisher_node = launch_ros.actions.Node(
          #     package='robot_state_publisher',
          #     executable='robot_state_publisher',
          #     parameters=[{
          #         'robot_description': robot1_description
          #     namespace='robot1',
          #     output='screen'
          robot2_state_publisher_node = launch_ros.actions.Node(
              parameters=[{
                  'robot_description': robot2_description
              namespace='robot2',
              output='screen'
          action_launch_gazebo = launch.actions.IncludeLaunchDescription(
                  os.path.join(
                      get_package_share_directory('gazebo_ros'),
                      'launch',
                      'gazebo.launch.py'
              launch_arguments=[
                  ('world', default_world_path),
                  ('verbose', 'true'),
                  ('use_sim_time', 'true')
          # action_spawn1_entity = launch_ros.actions.Node(
          #     package='gazebo_ros',
          #     executable='spawn_entity.py',
          #     arguments=[
          #         '-topic', 'robot1/robot_description',
          #         '-entity', 'myrobot1',
          #         '-robot_namespace', 'robot1'
          #     output='screen'
          action_spawn2_entity = launch_ros.actions.Node(
              arguments=[
                  '-topic', 'robot2/robot_description',
                  '-entity', 'myrobot2',
                  '-robot_namespace', 'robot2',
                  '-x','1.0',
                  '-y','0.5',
                  '-z','0.0'
              output='screen'
          # 为每个机器人单独启动 joint_state_publisher
          # joint_state_publisher_robot1 = launch_ros.actions.Node(
          #     package='joint_state_publisher',
          #     executable='joint_state_publisher',
          #     parameters=[{'source_list': ['robot1/joint_states']}]
          joint_state_publisher_robot2 = launch_ros.actions.Node(
              namespace='robot2',
              parameters=[{'source_list': ['/joint_states']}]
          action_robot2node_joint_state = launch.actions.ExecuteProcess(
              cmd=['ros2', 'control', 'load_controller',
                   '--controller-manager', 'robot2/controller_manager', # <--- **指定目标服务**
                   'track_car_joint_state_broadcaster',
                   '--set-state', 'active'],
              output='screen'
          action_robot2node_diff_drive_controller = launch.actions.ExecuteProcess(
                # cmd=['ros2', 'control', 'load_controller', '--set-state', 'active', 'track_car_diff_drive_controller'], # 旧命令,缺少--controller-manager
                   'track_car_diff_drive_controller',
              output='screen'
          # 发
              # action_declare_arg_mode1path,
              action_declare_arg_mode2path,
              # robot1_state_publisher_node,
              robot2_state_publisher_node,
              action_launch_gazebo,
              # action_spawn1_entity,
              action_spawn2_entity,
              # joint_state_publisher_robot1,
              launch.actions.RegisterEventHandler(
                  event_handler=launch.event_handlers.OnProcessExit(
                      target_action=action_spawn2_entity,
                      on_exit=[
                          TimerAction(
                              period=5.0,
                              actions=[action_robot2node_joint_state] # Timer结束后执行加载 broadcaster
                      target_action=action_robot2node_joint_state,
                      on_exit=[action_robot2node_diff_drive_controller],
      控制器URDF文件:
      <?xml version="1.0"?>
          <xacro:macro name="track_car_ros2_control">
          <ros2_control name="TrackCarGazeboSystem" type="system">
                  <hardware>
                      <plugin>gazebo_ros2_control/GazeboSystem</plugin>
                  </hardware>
                  <joint name="left_wheel_joint">
                  <!-- 命令接口 -->
                      <command_interface name="velocity">
                          <param name="min">-1</param>
                          <param name="max">1</param>
                      </command_interface>
                      <command_interface name="effort">
                          <param name="min">-0.1</param>
                          <param name="max">0.1</param>
                      <!-- 状态接口 -->
                      <state_interface name="position" />
                      <state_interface name="velocity" />
                      <state_interface name="effort" />
                  </joint>
                  <joint name="right_wheel_joint">
                  </joint>
              </ros2_control>
              <gazebo>
                  <plugin filename="libgazebo_ros2_control.so" name="gazebo_ros2_control">
                      <robot_namespace>/robot2</robot_namespace>
                      <parameters>$(find car_description)/config/track_car_ros2_controller.yaml</parameters>
                       <ros>
                          <remapping>/track_car_diff_drive_controller/odom:=/odom</remapping>
                          <remapping>/track_car_diff_drive_controller/cmd_vel_unstamped:=/cmd_vel</remapping>
                       </ros>
                  </plugin>
              </gazebo>
          </xacro:macro>
      </robot>
      param参数文件:
      controller_manager:
        ros__parameters:
          update_rate: 1000 # Hz
          use_sim_time: true
          track_car_joint_state_broadcaster:
            type: joint_state_broadcaster/JointStateBroadcaster
          track_car_effort_controller:
            type: effort_controllers/JointGroupEffortController
          track_car_diff_drive_controller:
            type: diff_drive_controller/DiffDriveController
        ros__parameters:
          joints:
            - left_wheel_joint
            - right_wheel_joint
          command_interfaces:
            - effort
          state_interfaces:
            - position
            - velocity
            - effort
        ros__parameters:
          left_wheel_names: ["left_wheel_joint"]
          right_wheel_names: ["right_wheel_joint"]
          wheel_separation: 0.20
          #wheels_per_side: 1  # actually 2, but both are controlled by 1 signal
          wheel_radius: 0.05
          wheel_separation_multiplier: 1.0
          left_wheel_radius_multiplier: 1.0
          right_wheel_radius_multiplier: 1.0
          publish_rate: 50.0
          odom_frame_id: odom
          base_frame_id: base_footprint
          pose_covariance_diagonal : [0.001, 0.001, 0.0, 0.0, 0.0, 0.01]
          twist_covariance_diagonal: [0.001, 0.0, 0.0, 0.0, 0.0, 0.01]
          open_loop: true
          enable_odom_tf: true
          cmd_vel_timeout: 0.5
          #publish_limited_velocity: true
          use_stamped_vel: false
          #velocity_rolling_window_size: 10
        2118561423 @sdcdacqdiuhoiwgaciba
        @sdcdacqdiuhoiwgaciba 目前看来解决了,在参数文件中加入对应的命名空间就行,例如
        /robot1/controller_manager:
          ros__parameters:
            use_sim_time: true
        /robot1/track_car_effort_controller:
          ros__parameters:
            joints:
              - left_wheel_joint
              - right_wheel_joint
            command_interfaces:
              - effort
            state_interfaces:
              - position
              - velocity
              - effort
        /robot1/track_car_diff_drive_controller:
          ros__parameters:
            wheel_radius: 0.05
            publish_rate: 50.0
            odom_frame_id: odom
            open_loop: true
        S 2 条回复 最后回复 回复 引用 1
        • S
          你好,请问解决了吗,我也遇到了一样的问题
              ros__parameters:
                use_sim_time: true
              ros__parameters:
                joints:
                  - left_wheel_joint
                  - right_wheel_joint
                command_interfaces:
                  - effort
                state_interfaces:
                  - position
                  - velocity
                  - effort
              ros__parameters:
                wheel_radius: 0.05
                publish_rate: 50.0
                odom_frame_id: odom
                open_loop: true
            • S
              sdcdacqdiuhoiwgaciba @2118561423
              @2118561423 谢谢谢谢,我也解决了
              • 2 2118561423 将这个主题标记为已解决,在
              • S
                @2118561423 但是我出现了一个问题,每当编译的时候我的命名空间会自动被截断,如从
                /fishbot/controller_manager:
                  ros__parameters:
                    update_rate: 100  # Hz
                    use_sim_time: true
                    fishbot_joint_state_broadcaster:
                      use_sim_time: true
                    fishbot_effort_controller:
                    fishbot_diff_drive_controller:
                变成
                controller_manager:
                  ros__parameters:
                    use_sim_time: true
                      use_sim_time: true
                请问这个问题您遇到过吗
                  @sdcdacqdiuhoiwgaciba 你这个是不是在share目录下修改的文件,应该要在src目录下修改,或者是修改后没有保存就进行了编译?
                  S 1 条回复 最后回复 回复 引用 0
                  • S
                    @2118561423 感谢感谢 已经解决了
