    wsl Ubuntu22.04使用一键安装过程中遇到程序崩溃
    一键安装失败 wsl2 ubuntu22.04
    • 7645426077
      花信可期
      --2025-04-11 21:11:30-- http://fishros.com/install
      Resolving fishros.com (fishros.com)... 47.119.165.169
      Connecting to fishros.com (fishros.com)|47.119.165.169|:80... connected.
      --2025-04-11 21:11:31-- http://fishros.com/install/
      Length: 957 [application/octet-stream]
      Saving to: ‘fishros’
      fishros 100%[===================================================================================>] 957 --.-KB/s in 0s
      2025-04-11 21:11:31 (255 MB/s) - ‘fishros’ saved [957/957]
      Reading package lists... Done
      python3-distro is already the newest version (1.7.0-1).
      python3-yaml is already the newest version (5.4.1-1ubuntu1).
      0 upgraded, 0 newly installed, 0 to remove and 72 not upgraded.
      --2025-04-11 21:11:31-- http://mirror.fishros.com/install/tools/base.py
      Resolving mirror.fishros.com (mirror.fishros.com)... 47.119.165.169
      Connecting to mirror.fishros.com (mirror.fishros.com)|47.119.165.169|:80... connected.
      Length: 51464 (50K) [application/octet-stream]
      Saving to: ‘/tmp/fishinstall//tools/base.py’
      /tmp/fishinstall//tools/base.py 100%[===================================================================================>] 50.26K 227KB/s in 0.2s
      2025-04-11 21:11:32 (227 KB/s) - ‘/tmp/fishinstall//tools/base.py’ saved [51464/51464]
      [-][0.00s] CMD Result:success
      Run CMD Task:[wget http://mirror.fishros.com/install/tools/translation/translator.py -O /tmp/fishinstall//tools/translation/translator.py --no-check-certificate]
      [-][0.00s] CMD Result:code:1
      标题:使用一键安装过程中遇到程序崩溃
        File "/tmp/fishinstall/install.py", line 68, in main
          importlib.import_module("tools.translation.translator").Linguist()
        File "/usr/lib/python3.10/importlib/__init__.py", line 126, in import_module
        File "<frozen importlib._bootstrap>", line 1050, in _gcd_import
        File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
        File "<frozen importlib._bootstrap>", line 992, in _find_and_load_unlocked
        File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
        File "<frozen importlib._bootstrap>", line 1004, in _find_and_load_unlocked
      ModuleNotFoundError: No module named 'tools.translation'
