    ros2 humble控制插件无法加载到gazebo中
    ros2humble gazebo-ros2
    • P
      pg
      做了几个控制插件对gazebo的模型进行控制然后进行仿真,但是发现好像插件识别不了gazebo的宏,打开gazebo的时候加载不出插件,请问有什么注意的点吗?以下是其中一个插件
      #include "flapping_controller.hpp"
      #include <gazebo/physics/Joint.hh>
      #include <chrono>
      #include <rclcpp/rclcpp.hpp>
      using namespace gazebo;
      FlappingController::FlappingController()
      std::cout << "[FlappingController] Constructor called." << std::endl;
      FlappingController::~FlappingController() {}
      void FlappingController::Load(physics::ModelPtr model, sdf::ElementPtr sdf)
      std::cout << "[FlappingController] Load() start." << std::endl;
      if (!model)
      std::cout << "[FlappingController] Model pointer is null!" << std::endl;
      return;
      this->model_ = model;
      this->start_time_ = model->GetWorld()->SimTime().Double();
      this->last_time_ = this->start_time_;
      if (sdf->HasElement("namespace_model"))
      this->ns_ = sdf->Getstd::string("namespace_model");
      else
      this->ns_ = "bird2";
      try
      this->ros_node_ = rclcpp::Node::make_shared(this->ns_ + "_flap_node");
      catch (const std::exception &e)
      std::cout << "[FlappingController] Failed to create ROS2 node: " << e.what() << std::endl;
      return;
      RCLCPP_INFO(this->ros_node_->get_logger(), "Creating subscriptions and publishers...");
      this->flap_freq_sub_ = this->ros_node_->create_subscription<std_msgs::msg::Float32>(
      "/" + ns_ + "/frequency", 10,
      std::bind(&FlappingController::OnFlapFreqMsg, this, std::placeholders::_1));
      this->height_sub_ = this->ros_node_->create_subscription<std_msgs::msg::Float32>(
      "/" + ns_ + "/height", 10,
      std::bind(&FlappingController::OnHeightMsg, this, std::placeholders::_1));
      this->speed_pub_ = this->ros_node_->create_publisher<std_msgs::msg::Float32>(
      "/" + ns_ + "/speed", 10);
      this->update_connection_ = event::Events::ConnectWorldUpdateBegin(
      std::bind(&FlappingController::OnUpdate, this));
      RCLCPP_INFO(this->ros_node_->get_logger(), "FlappingController loaded.");
      void FlappingController::OnFlapFreqMsg(const std_msgs::msg::Float32::SharedPtr msg)
      this->SetFlappingFrequency(msg->data);
      void FlappingController::SetFlappingFrequency(double freq)
      this->flapping_freq_ = freq;
      void FlappingController::OnHeightMsg(const std_msgs::msg::Float32::SharedPtr msg)
      if (msg->data < 0.1)
      this->flap_enabled_ = false;
      else
      this->flap_enabled_ = true;
      void FlappingController::OnUpdate()
      if (!this->model_)
      return;
      double now = model_->GetWorld()->SimTime().Double();
      if (!flap_enabled_)
      return;
      double elapsed = now - this->start_time_;
      double left = flapping_amp_ * sin(2 * M_PI * flapping_freq_ * elapsed);
      double right = -left;
      auto joint_left = model_->GetJoint("joint_4");
      auto joint_right = model_->GetJoint("joint_6");
      if (!joint_left || !joint_right)
      std::cerr << "[FlappingController] Failed to find joint_4 or joint_6!" << std::endl;
      return;
      joint_left->SetPosition(0, left);
      joint_right->SetPosition(0, right);
      std_msgs::msg::Float32 speed_msg;
      speed_msg.data = left;
      this->speed_pub_->publish(speed_msg);
      GZ_REGISTER_MODEL_PLUGIN(FlappingController)
