    ROS2多线程节点
    ros2 多线程
    4.2k
    • 首飞Kevin首
      首飞Kevin
      下面介绍一下如何在ROS2节点中使用多线程。
      使用多线程就涉及到回调组(CallbackGroup)了。
      使用示例
      创建回调组的函数如下:
        /// Create and return a callback group.
        RCLCPP_PUBLIC
        rclcpp::CallbackGroup::SharedPtr
        create_callback_group(
          rclcpp::CallbackGroupType group_type,
          bool automatically_add_to_executor_with_node = true);
      可以看到,创建回调组时是可以选择使用哪种类型的回调组(CallbackGroup)的。回调组的类型如下:
      enum class CallbackGroupType
        MutuallyExclusive,
        Reentrant
      MutuallyExclusive表示此组的回调函数是互斥的,不能在同一时间被执行。Reentrant表示回调函数是可重入的,允许同一时刻被多次执行。通常使用的还是MutuallyExclusive类型。
      创建回调组回调组的另外一个参数是automatically_add_to_executor_with_node。它的默认值是true。
      这个参数决定了回调组绑定node的方式。
      当automatically_add_to_executor_with_node为true时,采用在节点外部使用add_node的方式绑定node。可查看下面的示例程序。
      examples/rclcpp/executors/multithreaded_executor/multithreaded_executor.cpp
      #include <chrono>
      #include <functional>
      #include <memory>
      #include <string>
      #include <thread>
      #include "rclcpp/rclcpp.hpp"
      #include "std_msgs/msg/string.hpp"
       * A small convenience function for converting a thread ID to a string
      std::string string_thread_id()
        auto hashed = std::hash<std::thread::id>()(std::this_thread::get_id());
        return std::to_string(hashed);
      /* For this example, we will be creating a publishing node like the one in minimal_publisher.
       * We will have a single subscriber node running 2 threads. Each thread loops at different speeds, and
       * just repeats what it sees from the publisher to the screen.
      class PublisherNode : public rclcpp::Node
      public:
        PublisherNode()
        : Node("PublisherNode"), count_(0)
          publisher_ = this->create_publisher<std_msgs::msg::String>("topic", 10);
          auto timer_callback =
            [this]() -> void {
              auto message = std_msgs::msg::String();
              message.data = "Hello World! " + std::to_string(this->count_++);
              // Extract current thread
              auto curr_thread = string_thread_id();
              // Prep display message
              RCLCPP_INFO(
                this->get_logger(), "\n<<THREAD %s>> Publishing '%s'",
                curr_thread.c_str(), message.data.c_str());
              this->publisher_->publish(message);
          timer_ = this->create_wall_timer(500ms, timer_callback);
      private:
        rclcpp::Publisher<std_msgs::msg::String>::SharedPtr publisher_;
        size_t count_;
      class DualThreadedNode : public rclcpp::Node
      public:
        DualThreadedNode()
        : Node("DualThreadedNode")
          /* These define the callback groups
           * They don't really do much on their own, but they have to exist in order to
           * assign callbacks to them. They're also what the executor looks for when trying to run multiple threads
          callback_group_subscriber1_ = this->create_callback_group(
            rclcpp::CallbackGroupType::MutuallyExclusive);
          callback_group_subscriber2_ = this->create_callback_group(
          // Each of these callback groups is basically a thread
          // Everything assigned to one of them gets bundled into the same thread
          auto sub1_opt = rclcpp::SubscriptionOptions();
          sub1_opt.callback_group = callback_group_subscriber1_;
          auto sub2_opt = rclcpp::SubscriptionOptions();
          sub2_opt.callback_group = callback_group_subscriber2_;
          subscription1_ = this->create_subscription<std_msgs::msg::String>(
            "topic",
            rclcpp::QoS(10),
            // std::bind is sort of C++'s way of passing a function
            // If you're used to function-passing, skip these comments
            std::bind(
              &DualThreadedNode::subscriber1_cb,  // First parameter is a reference to the function
              this,                               // What the function should be bound to
              std::placeholders::_1),             // At this point we're not positive of all the
                                                  // parameters being passed
                                                  // So we just put a generic placeholder
                                                  // into the binder
                                                  // (since we know we need ONE parameter)
            sub1_opt);                  // This is where we set the callback group.
                                        // This subscription will run with callback group subscriber1
          subscription2_ = this->create_subscription<std_msgs::msg::String>(
            "topic",
            rclcpp::QoS(10),
            std::bind(
              &DualThreadedNode::subscriber2_cb,
              this,
            sub2_opt);
      private:
         * Simple function for generating a timestamp
         * Used for somewhat ineffectually demonstrating that the multithreading doesn't cripple performace
        std::string timing_string()
          rclcpp::Time time = this->now();
          return std::to_string(time.nanoseconds());
         * Every time the Publisher publishes something, all subscribers to the topic get poked
         * This function gets called when Subscriber1 is poked (due to the std::bind we used when defining it)
        void subscriber1_cb(const std_msgs::msg::String::SharedPtr msg)
          auto message_received_at = timing_string();
          RCLCPP_INFO(
            this->get_logger(), "THREAD %s => Heard '%s' at %s",
            string_thread_id().c_str(), msg->data.c_str(), message_received_at.c_str());
         * This function gets called when Subscriber2 is poked
         * Since it's running on a separate thread than Subscriber 1, it will run at (more-or-less) the same time!
        void subscriber2_cb(const std_msgs::msg::String::SharedPtr msg)
          RCLCPP_INFO(
        rclcpp::CallbackGroup::SharedPtr callback_group_subscriber1_;
        rclcpp::CallbackGroup::SharedPtr callback_group_subscriber2_;
        rclcpp::Subscription<std_msgs::msg::String>::SharedPtr subscription1_;
        rclcpp::Subscription<std_msgs::msg::String>::SharedPtr subscription2_;
        rclcpp::init(argc, argv);
        // You MUST use the MultiThreadedExecutor to use, well, multiple threads
        rclcpp::executors::MultiThreadedExecutor executor;
        auto pubnode = std::make_shared<PublisherNode>();
        auto subnode = std::make_shared<DualThreadedNode>();  // This contains BOTH subscriber callbacks.
                                                              // They will still run on different threads
                                                              // One Node. Two callbacks. Two Threads
        executor.add_node(pubnode);
        executor.add_node(subnode);
        executor.spin();
        rclcpp::shutdown();
        return 0;
      当一个节点中有多个线程时,需要用到rclcpp::executors::MultiThreadedExecutor。上面示例程序中,DualThreadedNode是有两个线程的。这两个线程中分别运行一个订阅器的回调函数。两个线程独立运行互不干扰。
      上面示例程序的完整版可使用下面的方式获取:
      git clone https://github.com/shoufei403/ros2_galactic_tutorials.git
      下载编译好后,可使用下面的命令运行测试。
      ros2 run examples_rclcpp_multithreaded_executor
      输出结果:
      [PublisherNode]:
      <<THREAD 6504961969737349918>> Publishing 'Hello World! 0'
      [DualThreadedNode]: THREAD 3314359393590349369 => Heard 'Hello World! 0' at 1657449288147060106
      [DualThreadedNode]: THREAD 6504961969737349918 => Heard 'Hello World! 0' at 1657449288147082759
      [PublisherNode]:
      <<THREAD 16625943778230753959>> Publishing 'Hello World! 1'
      [DualThreadedNode]: THREAD 13431477624131009972 => Heard 'Hello World! 1' at 1657449288646978265
      [DualThreadedNode]: THREAD 16625943778230753959 => Heard 'Hello World! 1' at 1657449288647097545
      [PublisherNode]:
      <<THREAD 12195914629433846612>> Publishing 'Hello World! 2'
      [DualThreadedNode]: THREAD 17256547440473779954 => Heard 'Hello World! 2' at 1657449289146970672
      [DualThreadedNode]: THREAD 12195914629433846612 => Heard 'Hello World! 2' at 1657449289147078711
      可以看到回调函数是执行在不同的线程中的。
      当automatically_add_to_executor_with_node为false时,采用在节点内部使用add_callback_group的方式绑定node。可查看下面的示例程序。
      navigation2/nav2_behavior_tree/plugins/condition/is_battery_low_condition.cpp
      #include <string>
      #include "nav2_behavior_tree/plugins/condition/is_battery_low_condition.hpp"
      namespace nav2_behavior_tree
      IsBatteryLowCondition::IsBatteryLowCondition(
        const std::string & condition_name,
        const BT::NodeConfiguration & conf)
      : BT::ConditionNode(condition_name, conf),
        battery_topic_("/battery_status"),
        min_battery_(0.0),
        is_voltage_(false),
        is_battery_low_(false)
        getInput("min_battery", min_battery_);
        getInput("battery_topic", battery_topic_);
        getInput("is_voltage", is_voltage_);
        node_ = config().blackboard->get<rclcpp::Node::SharedPtr>("node");
        callback_group_ = node_->create_callback_group(
          rclcpp::CallbackGroupType::MutuallyExclusive,
          false);
        callback_group_executor_.add_callback_group(callback_group_, node_->get_node_base_interface());
        rclcpp::SubscriptionOptions sub_option;
        sub_option.callback_group = callback_group_;
        battery_sub_ = node_->create_subscription<sensor_msgs::msg::BatteryState>(
          battery_topic_,
          rclcpp::SystemDefaultsQoS(),
          std::bind(&IsBatteryLowCondition::batteryCallback, this, std::placeholders::_1),
          sub_option);
      BT::NodeStatus IsBatteryLowCondition::tick()
        callback_group_executor_.spin_some();
        if (is_battery_low_) {
          return BT::NodeStatus::SUCCESS;
        return BT::NodeStatus::FAILURE;
      void IsBatteryLowCondition::batteryCallback(sensor_msgs::msg::BatteryState::SharedPtr msg)
        if (is_voltage_) {
          is_battery_low_ = msg->voltage <= min_battery_;
        } else {
          is_battery_low_ = msg->percentage <= min_battery_;
      }  // namespace nav2_behavior_tree
      #include "behaviortree_cpp_v3/bt_factory.h"
      BT_REGISTER_NODES(factory)
        factory.registerNodeType<nav2_behavior_tree::IsBatteryLowCondition>("IsBatteryLow");
      navigation2/nav2_behavior_tree/include/nav2_behavior_tree/plugins/condition/is_battery_low_condition.hpp
      #ifndef NAV2_BEHAVIOR_TREE__PLUGINS__CONDITION__IS_BATTERY_LOW_CONDITION_HPP_
      #define NAV2_BEHAVIOR_TREE__PLUGINS__CONDITION__IS_BATTERY_LOW_CONDITION_HPP_
      #include <string>
      #include <memory>
      #include <mutex>
      #include "sensor_msgs/msg/battery_state.hpp"
      #include "behaviortree_cpp_v3/condition_node.h"
       * @brief A BT::ConditionNode that listens to a battery topic and
       * returns SUCCESS when battery is low and FAILURE otherwise
      class IsBatteryLowCondition : public BT::ConditionNode
      public:
         * @brief A constructor for nav2_behavior_tree::IsBatteryLowCondition
         * @param condition_name Name for the XML tag for this node
         * @param conf BT node configuration
          const BT::NodeConfiguration & conf);
        IsBatteryLowCondition() = delete;
         * @brief The main override required by a BT action
         * @return BT::NodeStatus Status of tick execution
        BT::NodeStatus tick() override;
         * @brief Creates list of BT ports
         * @return BT::PortsList Containing node-specific ports
        static BT::PortsList providedPorts()
          return {
            BT::InputPort<double>("min_battery", "Minimum battery percentage/voltage"),
            BT::InputPort<std::string>(
              "battery_topic", std::string("/battery_status"), "Battery topic"),
            BT::InputPort<bool>(
              "is_voltage", false, "If true voltage will be used to check for low battery"),
      private:
         * @brief Callback function for battery topic
         * @param msg Shared pointer to sensor_msgs::msg::BatteryState message
        void batteryCallback(sensor_msgs::msg::BatteryState::SharedPtr msg);
        rclcpp::Node::SharedPtr node_;
        rclcpp::CallbackGroup::SharedPtr callback_group_;
        rclcpp::executors::SingleThreadedExecutor callback_group_executor_;
        rclcpp::Subscription<sensor_msgs::msg::BatteryState>::SharedPtr battery_sub_;
        std::string battery_topic_;
        double min_battery_;
        bool is_voltage_;
        bool is_battery_low_;
      #endif  // NAV2_BEHAVIOR_TREE__PLUGINS__CONDITION__IS_BATTERY_LOW_CONDITION_HPP_
      可以看到,这里使用的是rclcpp::executors::SingleThreadedExecutor(单线程执行器)。
      我是首飞,一位帮大家填坑的机器人开发攻城狮。
      1 条回复 最后回复 回复 引用 3
      • 首飞Kevin首 首飞Kevin 在 中 引用了 这个主题
      • 22090995542
        这个冬天不太冷
        您好,非常感谢您提供的代码,我这个根据您的代码写了一个ROS2的相关程序,可是在实际使用时遇到一些问题,我这边订阅的节点有的时候会出现不响应的情况,所以想请问您两个问题
        1.订阅器应该是一个订阅器占用一个线程吗,这样的话如果我在一个节点里面写个几十个订阅器需要开几十个线程吗。
        2.程序的线程数和电脑本身的线程数有没有关系,如果电脑本身只有四个线程,我在程序里开个多于四个线程可以吗?
        非常感谢!
        我的代码地址
        https://github.com/RealManRobot/ros2_rm_robot/blob/main/rm_driver/src/rm_driver.cpp
        • 16287993151
          早点睡晚安吧
          请教一下,如果我想实现 一个线程 函数 发布( a 的值 ),一个函数做其他的(比如 只实现 a ++) 怎么实现呢?
