    建图导航问题集合
    导航图 问题记录 求助贴
    4.4k
      1117 年度VIP
      1.9.5.1章节在驱动雷达节点的时候,点云数据可以正常显示。但是会出现红色字体。如下所示;
      (我使用的是串口电脑连接雷达。波特率是115200,之前换过921600 但是没啥反应,结构一样)
      2.在9.55章的时候,出现如下问题:
      (我使用的是串口,然后驱动launch 文件)
      li@ubantu:~/navigation_project/bot_ws$ ros2 launch bringup bringup.launch.py
      [INFO] [launch]: All log files can be found below /home/li/.ros/log/2025-04-29-00-17-18-478907-ubantu-7199
      [INFO] [joint_state_publisher-1]: process started with pid [7201]
      [INFO] [robot_state_publisher-2]: process started with pid [7203]
      [INFO] [odom2tf-3]: process started with pid [7205]
      [INFO] [micro_ros_agent-4]: process started with pid [7207]
      [robot_state_publisher-2] [INFO] [1745857038.701965528] [robot_state_publisher]: got segment base_footprint
      [robot_state_publisher-2] [INFO] [1745857038.702253980] [robot_state_publisher]: got segment base_link
      [robot_state_publisher-2] [INFO] [1745857038.702289228] [robot_state_publisher]: got segment laser_link
      [micro_ros_agent-4] [1745857039.582356] info | TermiosAgentLinux.cpp | init | running... | fd: 3
      [micro_ros_agent-4] [1745857039.583524] info | Root.cpp | set_verbose_level | logger setup | verbose_level: 6
      [joint_state_publisher-1] [INFO] [1745857039.762095517] [joint_state_publisher]: Waiting for robot_description to be published on the robot_description topic...
      [INFO] [ydlidar_node-5]: process started with pid [7252]
      [ydlidar_node-5] [INFO] [1745857044.257399143] [ydlidar_node]: [YDLIDAR INFO] Current ROS Driver Version: 1.0.1
      [ydlidar_node-5]
      [ydlidar_node-5] [2025-04-29 00:17:24][info] SDK initializing
      [ydlidar_node-5] [2025-04-29 00:17:24][info] SDK has been initialized
      [ydlidar_node-5] [2025-04-29 00:17:24][info] SDK Version: 1.2.9
      [ydlidar_node-5] [2025-04-29 00:17:24][info] Connect elapsed time 5 ms
      [ydlidar_node-5] [2025-04-29 00:17:24][info] Lidar successfully connected [/dev/ttyUSB0:115200]
      [ydlidar_node-5] [2025-04-29 00:17:24][info] Lidar running correctly! The health status good
      [ydlidar_node-5] [2025-04-29 00:17:24][info] Current Lidar Model Code 12
      [ydlidar_node-5] [2025-04-29 00:17:24][info] Check status, Elapsed time 1 ms
      [ydlidar_node-5] [2025-04-29 00:17:24][info] Lidar init success, Elapsed time [7]ms
      [ydlidar_node-5] [2025-04-29 00:17:24][info] Start to getting intensity flag
      [ydlidar_node-5] [2025-04-29 00:17:25][info] [YDLIDAR] End to getting intensity flag
      [ydlidar_node-5] [2025-04-29 00:17:25][info] [YDLIDAR] Create thread 0xC5261640
      [ydlidar_node-5] [2025-04-29 00:17:26][info] Successed to start scan mode, Elapsed time 1900 ms
      [ydlidar_node-5] [2025-04-29 00:17:26][error] Timeout count: 1
      [ydlidar_node-5] [2025-04-29 00:17:27][error] Timeout count: 2
      [ydlidar_node-5] [2025-04-29 00:17:28][error] Timeout count: 1
      [ydlidar_node-5] [2025-04-29 00:17:29][error] Timeout count: 2
      [ydlidar_node-5] [2025-04-29 00:17:30][error] Timeout count: 3
      [ydlidar_node-5] [2025-04-29 00:17:33][error] Timeout count: 1
      [ydlidar_node-5] [2025-04-29 00:17:34][error] Timeout count: 2
      [ydlidar_node-5] [2025-04-29 00:17:35][error] Timeout count: 3
      [ydlidar_node-5] [INFO] [1745857056.449131595] [rclcpp]: signal_handler(signum=2)
      [robot_state_publisher-2] [INFO] [1745857056.449596325] [rclcpp]: signal_handler(signum=2)
      [ERROR] [micro_ros_agent-4]: process has died [pid 7207, exit code -2, cmd '/home/li/navigation_project/bot_ws/install/micro_ros_agent/lib/micro_ros_agent/micro_ros_agent serial -b 115200 --dev /dev/ttyUSB0 -v6 --ros-args'].
      [INFO] [robot_state_publisher-2]: process has finished cleanly [pid 7203]
      [INFO] [odom2tf-3]: process has finished cleanly [pid 7205]
      [INFO] [joint_state_publisher-1]: process has finished cleanly [pid 7201]
      [odom2tf-3] [INFO] [1745857056.450243764] [rclcpp]: signal_handler(signum=2)
      [ydlidar_node-5] [2025-04-29 00:17:36][error] Failed to turn on the Lidar, because the lidar is [Operation timed out].
      [ydlidar_node-5] terminate called after throwing an instance of 'rclcpp::exceptions::RCLError'
      [ydlidar_node-5] what(): could not create publisher: rcl node's context is invalid, at ./src/rcl/node.c:428
      [ERROR] [ydlidar_node-5]: process has died [pid 7252, exit code -6, cmd '/home/li/navigation_project/bot_ws/install/ydlidar/lib/ydlidar/ydlidar_node --ros-args -r __node:=ydlidar_node -r __ns:=/ --params-file /home/li/navigation_project/bot_ws/install/ydlidar/share/ydlidar/params/ydlidar.yaml'].
      [ydlidar_node-5]
      然后是没有scan话题的(如上),我的启动的launch文件如下:
      import launch
      import launch_ros
      bringup_dir = get_package_share_directory(
      'bringup')
      ydlidar_ros2_dir = get_package_share_directory(
      'ydlidar')
      urdf2tf = launch.actions.IncludeLaunchDescription(
              [bringup_dir, '/launch', '/urdf2tf.launch.py']),
      odom2tf = launch_ros.actions.Node(
          package='bringup',
          executable='odom2tf',
          output='screen'
      microros_agent = launch_ros.actions.Node(
          package='micro_ros_agent',
          executable='micro_ros_agent',
          arguments=[
              'serial',                 # 切换为串口模式
              '-b', '115200',           # 波特率参数(需字符串类型)
              '--dev', '/dev/ttyUSB0',  # 设备路径
              '-v6'                     # 日志详细级别
          output='screen'              # 保持终端输出可见
      ydlidar = launch.actions.IncludeLaunchDescription(
              [ydlidar_ros2_dir, '/launch', '/ydlidar_launch.py']),
      # 使用 TimerAction 启动后 5 秒执行 ydlidar 节点
      ydlidar_delay = launch.actions.TimerAction(period=5.0, actions=[ydlidar])
          urdf2tf,
          odom2tf,
          microros_agent,
          ydlidar_delay
      我的雷达yaml文件如下:
      然后我后面单独驱动雷达节点如下:
      我应该怎么修改呢?
      3 1 条回复 最后回复 回复 引用 0
        3215456057 年度VIP @1117
        @1117 兄弟,这个问题解决了吗?我也有这个问题,不知道是什么原因,成功连上后再连就连不上了,雷达板那边显示ping timeout,之前连上的时候是running😧
        小鱼小 1 2 条回复 最后回复 回复 引用 1
          小鱼 技术大佬 @3215456057
          @3215456057 正在更换最新驱动,明天再重新拉取测试
            1117 年度VIP @3215456057
            @3215456057 最后我是老老实实的一个一个的启动(就是把相关的节点全部一个一个启动),最后可以建图导航。
