    4.2.1自定义服务接口,执行colcon build报错
    ros2 自定义服务接口
    • H
      hunter
      最后由 hunter 编辑
      报错内容如下:
      ~/chapt4/chapt4_ws$ colcon build
      Starting >>> chapt4_interfaces
      --- stderr: chapt4_interfaces
      CMake Error at /opt/ros/humble/share/rosidl_generator_py/cmake/rosidl_generator_py_generate_interfaces.cmake:20 (find_package):
      By not providing "FindPythonInterp.cmake" in CMAKE_MODULE_PATH this project
      has asked CMake to find a package configuration file provided by
      "PythonInterp", but CMake did not find one.
      Could not find a package configuration file provided by "PythonInterp"
      (requested version 3.6) with any of the following names:
      PythonInterpConfig.cmake
      pythoninterp-config.cmake
      Add the installation prefix of "PythonInterp" to CMAKE_PREFIX_PATH or set
      "PythonInterp_DIR" to a directory containing one of the above files. If
      "PythonInterp" provides a separate development package or SDK, be sure it
      has been installed.
      CMakeLists.txt:13 (rosidl_generate_interfaces)
      gmake: *** [Makefile:747:cmake_check_build_system] 错误 1
      Failed <<< chapt4_interfaces [1.72s, exited with code 2]
      Summary: 0 packages finished [1.81s]
      1 package failed: chapt4_interfaces
      1 package had stderr output: chapt4_interfaces
      开始提示Cmake版本<3.10怎么怎么的,于是我就改了CmakeList文件中第一行为:
      cmake_minimum_required(VERSION 4.0)
      就有了上面的报错,请问怎么处理?
