    6.2章节的机器人launch文件启动错误,无法正常启动[ERROR] [rviz2-3]: process has died [pid 12107, exit code 127, cmd '/opt/ros/humble/lib/rviz2/rviz2 -d /home/wasd/chapt6/chapt6_ws/install/fishbot_description/share/fishbot_description/rviz/display.rviz --ros-args'].
    ros2 launch.py 启动报错 rviz2 error
    408
      lwx359162567
      wasd@wasd-virtual-machine:~/chapt6/chapt6_ws$ ros2 launch fishbot_description display_robot.lauch.py
      [INFO] [launch]: All log files can be found below /home/wasd/.ros/log/2025-05-13-11-26-42-773028-wasd-virtual-machine-12101
      [INFO] [robot_state_publisher-1]: process started with pid [12103]
      [INFO] [joint_state_publisher-2]: process started with pid [12105]
      [INFO] [rviz2-3]: process started with pid [12107]
      [robot_state_publisher-1] [INFO] [1747106802.833965744] [robot_state_publisher]: got segment base
      [robot_state_publisher-1] [INFO] [1747106802.834038713] [robot_state_publisher]: got segment imu
      [rviz2-3] /opt/ros/humble/lib/rviz2/rviz2: symbol lookup error: /snap/core20/current/lib/x86_64-linux-gnu/libpthread.so.0: undefined symbol: __libc_pthread_init, version GLIBC_PRIVATE
      [joint_state_publisher-2] [INFO] [1747106803.065341028] [joint_state_publisher]: Waiting for robot_description to be published on the robot_description topic...
      [robot_state_publisher-1] [INFO] [1747106805.722844186] [rclcpp]: signal_handler(signum=2)
      [INFO] [robot_state_publisher-1]: process has finished cleanly [pid 12103]
      [INFO] [joint_state_publisher-2]: process has finished cleanly [pid 12105]
        2534041965 @lwx359162567
        @lwx359162567 一样,我这边运行不了了
        L 3 条回复 最后回复 回复 引用 0
          lwx359162567 @2534041965
          @2534041965 你解决了吗?
            @2534041965 我打算试试单独一个启动rviz的功能包
              @2534041965 在 6.2章节的机器人launch文件启动错误,无法正常启动[ERROR] [rviz2-3]: process has died [pid 12107, exit code 127, cmd '/opt/ros/humble/lib/rviz2/rviz2 -d /home/wasd/chapt6/chapt6_ws/install/fishbot_description/share/fishbot_description/rviz/display.rviz --ros-args']. 中说:
              ok了,我解决了在编辑功能包的 package.xml 文件,添加对 rviz2 的依赖:
              <exec_depend>rviz2</exec_depend>
              然后 重新编译一下就可以了
              27648385562 1 条回复 最后回复 回复 引用 0
              • 27648385562
                阿 V @lwx359162567
                @lwx359162567 请问以下,我按照你这个方法,也添加了依赖,但是launch还是运行不起来rviz2是怎么会是?
